Whenever I hit printscreen the output file is completely white. This wasn’t a problem before the latest stable patch. Is there a fix for this? I’ve tried reinstalling the screenshot software but that didn’t work. I can take screenshots of most apps but not games.
Here's the inxi -Fazi
Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=685209db-9e73-475a-bfda-c4827e96da89 rw quiet apparmor=1
Desktop: GNOME 3.38.1 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.38.1
Distro: Manjaro Linux
Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
Mobo: ASUSTeK model: PRIME B550M-A v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 0310 date: 04/29/2020
Info: Quad Core model: AMD Ryzen 3 3100 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701021
L2 cache: 2048 KiB
bogomips: 57517
Speed: 2133 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 2464 2: 2795 3: 2794 4: 1863 5: 3081 6: 2532 7: 2794 8: 1863
conditional, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: PC Partner Limited driver: amdgpu v: kernel bus ID: 0a:00.0
chip ID: 1002:67df
Display: x11 server: X.org 1.20.9 compositor: gnome-shell driver: amdgpu,ati
unloaded: modesetting,radeon alternate: fbdev,vesa
resolution: <xdpyinfo missing>
OpenGL: renderer: AMD Radeon RX 480 Graphics (POLARIS10 DRM 3.38.0
5.8.18-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.2.1 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: PC Partner Limited driver: snd_hda_intel v: kernel bus ID: 0a:00.1
chip ID: 1002:aaf0
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 0c:00.4 chip ID: 1022:1487
Device-3: Kingston HyperX Cloud Revolver S type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-2:3 chip ID: 0951:16ad
serial: <filter>
Sound Server: ALSA v: k5.8.18-1-MANJARO
vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus ID: 09:00.0
chip ID: 10ec:8168
IF: enp9s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.34 TiB used: 836.09 GiB (34.9%)
ID-1: /dev/sda vendor: SanDisk model: SDSSDP064G size: 59.63 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> scheme: GPT
ID-2: /dev/sdb vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 022 scheme: GPT
ID-3: /dev/sdc vendor: Seagate model: ST2000DL003-9VT166 size: 1.82 TiB
rotation: 5900 rpm serial: <filter> rev: CC32 scheme: MBR
ID-4: /dev/sdd type: USB vendor: Kingston model: DataTraveler G3
size: 7.46 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: 1.00 scheme: MBR
ID-1: / raw size: 465.46 GiB size: 457.16 GiB (98.22%)
used: 224.79 GiB (49.2%) fs: ext4 dev: /dev/sdb2
System Temperatures: cpu: 38.1 C mobo: N/A gpu: amdgpu temp: 33.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 695
Processes: 291 Uptime: 21h 59m Memory: 15.60 GiB used: 3.76 GiB (24.1%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1483 lib: 450
flatpak: 0 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.1.08
And the dmesg with emergencies and alerts.
0.320306] __common_interrupt: 1.55 No irq handler for vector
[ 0.540805] #2
[ 0.320306] __common_interrupt: 2.55 No irq handler for vector
[ 0.542973] #3
[ 0.320306] __common_interrupt: 3.55 No irq handler for vector
[ 0.544209] #4
[ 0.320306] __common_interrupt: 4.55 No irq handler for vector
[ 0.547585] #5
[ 0.320306] __common_interrupt: 5.55 No irq handler for vector
[ 0.549707] #6
[ 0.320306] __common_interrupt: 6.55 No irq handler for vector
[ 0.550881] #7
[ 0.320306] __common_interrupt: 7.55 No irq handler for vector
[ 0.567295] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP8._DSM], AE_ALREADY_EXISTS (20200528/dswload2-326)
[ 0.567300] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200528/psobject-220)
[ 0.709175] PPR X2APIC NX GT IA GA PC GA_vAPIC
[ 1.678199] ata2.00: supports DRM functions and may not be fully accessible
[ 1.679367] ata2.00: supports DRM functions and may not be fully accessible
[ 4.300792] vboxdrv: loading out-of-tree module taints kernel.
[ 4.341994] VBoxNetAdp: Successfully started.
[ 4.343749] VBoxNetFlt: Successfully started.
[ 4.679449] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 4.679530] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 4.679578] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 4.679710] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 4.752016] sp5100-tco sp5100-tco: Watchdog hardware is disabled
[ 5.365678] amdgpu 0000:0a:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
[ 5.577274] kauditd_printk_skb: 24 callbacks suppressed
[ 10.289890] usb 1-6: config 1 has an invalid interface number: 2 but max is 1
[ 10.289894] usb 1-6: config 1 has no interface number 1
[ 10.620945] kauditd_printk_skb: 20 callbacks suppressed
[ 68.296353] kauditd_printk_skb: 6 callbacks suppressed
[10054.883135] blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 3 prio class 0
[10054.883164] blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[10054.883165] Buffer I/O error on dev sr0, logical block 0, async page read
[10054.883172] blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[10054.883172] Buffer I/O error on dev sr0, logical block 1, async page read
[10054.883177] blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[10054.883177] Buffer I/O error on dev sr0, logical block 2, async page read
[10054.883181] blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[10054.883182] Buffer I/O error on dev sr0, logical block 3, async page read
[10054.883186] blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[10054.883187] Buffer I/O error on dev sr0, logical block 4, async page read
[10054.883191] blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[10054.883191] Buffer I/O error on dev sr0, logical block 5, async page read
[10054.883196] blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[10054.883196] Buffer I/O error on dev sr0, logical block 6, async page read
[10054.883200] blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[10054.883201] Buffer I/O error on dev sr0, logical block 7, async page read
[73944.344746] kauditd_printk_skb: 18 callbacks suppressed
[74886.219655] sd 6:0:0:0: [sdd] No Caching mode page found
[74886.219657] sd 6:0:0:0: [sdd] Assuming drive cache: write through
Can’t get the Xorg log. Terminal says ‘no such file or directory’. What do I do?
Here’s the journalctl -f output.
Logs begin at Tue 2020-10-27 16:06:24 CET. --
Nov 07 08:47:27 Morgana caffeine.desktop[1931]: INFO:caffeine.core:XorgInhibitor is applicable, running it.
Nov 07 08:47:30 Morgana dbus-daemon[1485]: [session uid=1000 pid=1485] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.123' (uid=1000 pid=3897 comm="/usr/lib/tracker-miner-fs-3 " label="unconfined")
Nov 07 08:47:30 Morgana systemd[1447]: Starting Tracker metadata extractor...
Nov 07 08:47:30 Morgana tracker-extract[4519]: tracker-extract-3 running as org.freedesktop.Tracker3.Miner.Extract. The service will exit when org.freedesktop.Tracker3.Miner.Files disappears from the bus.
Nov 07 08:47:30 Morgana dbus-daemon[1485]: [session uid=1000 pid=1485] Successfully activated service 'org.freedesktop.Tracker3.Miner.Extract'
Nov 07 08:47:30 Morgana systemd[1447]: Started Tracker metadata extractor.
Nov 07 08:47:40 Morgana systemd[1447]: tracker-extract-3.service: Succeeded.
Nov 07 08:48:12 Morgana systemd[1447]: Started Application launched by gnome-shell.
Nov 07 08:48:12 Morgana systemd[1447]: Started VTE child process 4549 launched by gnome-terminal-server process 3130.
Nov 07 08:48:12 Morgana systemd[1447]: app-gnome-org.gnome.Terminal-4541.scope: Succeeded.
Nov 07 08:49:13 Morgana dbus-daemon[1485]: [session uid=1000 pid=1485] Activating via systemd: service name='org.freedesktop.Tracker3.Miner.Extract' unit='tracker-extract-3.service' requested by ':1.123' (uid=1000 pid=3897 comm="/usr/lib/tracker-miner-fs-3 " label="unconfined")
Nov 07 08:49:13 Morgana systemd[1447]: Starting Tracker metadata extractor...
Nov 07 08:49:13 Morgana tracker-extract[4627]: tracker-extract-3 running as org.freedesktop.Tracker3.Miner.Extract. The service will exit when org.freedesktop.Tracker3.Miner.Files disappears from the bus.
Nov 07 08:49:13 Morgana dbus-daemon[1485]: [session uid=1000 pid=1485] Successfully activated service 'org.freedesktop.Tracker3.Miner.Extract'
Nov 07 08:49:13 Morgana systemd[1447]: Started Tracker metadata extractor.
Nov 07 08:49:15 Morgana gnome-shell[1580]: Ignoring excess values in shadow definition
Nov 07 08:49:24 Morgana systemd[1447]: tracker-extract-3.service: Succeeded.
The last part saying ‘ignoring excess values in shadow definition’ came up when I tried taking a screenshot with the printscreen button.
Happening to me as well it seems, however, it seems to only be happening in games. Taking screenshots of the OS works fine. Tried it in Rise of the Tomb Raider which is a Linux native title running through Steam as well as FFXIV running through Lutris with Wine. As a note, the screenshots are corrupt when taken by using the Print Screen button (so Gnome default tool) as well as using Steam’s screenshotting functionality.
I tried posting logs but I’m getting errors that I can’t post links and I can’t include media in posts to supply screenshots of inxi or journalctl.
