Gnome randomly freezes for a few seconds
Hello!
I’m experiencing temporary freezes on gnome. They always happen after logging in/waking up from sleep and sometimes just randomly. The freezes only last for 3-10 secs, so they’re annoying, but not critical. I can’t find the exact reason in the journalctl, maybe you guys can help me out.
This is the output of inxi --full --admin --filter --width:
  Kernel: 6.1.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=362dba36-9769-4d29-b98c-be797827dd51 rw quiet splash
    mem_sleep_default=deep ibt=off intel_iommu=off init_on_alloc=0 apparmor=1
    security=apparmor resume=UUID=7a64ef38-0f26-4a26-b2bc-18c08f0a447c
    udev.log_priority=3
  Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
  Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X513EAN_K513EA
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: X513EAN v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: X513EAN.301 date: 11/01/2021
  ID-1: BAT0 charge: 34.9 Wh (100.0%) condition: 34.9/42.1 Wh (82.9%)
    volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: not charging cycles: 182
  Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xAA
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
    desc: 1x8 MiB
  Speed (MHz): avg: 1153 high: 1200 min/max: 400/4200 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1143 2: 1186 3: 1142
    4: 1095 5: 1182 6: 1184 7: 1200 8: 1098 bogomips: 38720
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
    driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
    ports: active: eDP-1 empty: HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:9a49 class-ID: 0300
  Device-2: Quanta USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 0408:30dd
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: Samsung 0x4161 built: 2020 res: 1920x1080 dpi: 142
    gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
    modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel Xe Graphics (TGL GT2)
    direct-render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
  API: ALSA v: k6.1.41-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.75 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active 3: pipewire-alsa
    type: plugin tools: pactl,pw-cat,pw-cli
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:a0f0 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 8087:0026
    class-ID: e001
  Local Storage: total: 476.94 GiB used: 115.76 GiB (24.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2210 MTFDHBA512QFD
    lanes: 4 tech: SSD serial: <filter> fw-rev: P6MA007 temp: 41.9 C
    scheme: GPT
  ID-1: / raw-size: 459.78 GiB size: 451.49 GiB (98.20%)
    used: 115.75 GiB (25.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: partition size: 16.86 GiB used: 3.2 MiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
  System Temperatures: cpu: 40.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 2500
  Processes: 359 Uptime: 4h 15m wakeups: 2 Memory: total: 16 GiB note: est.
  available: 15.33 GiB used: 12.43 GiB (81.1%) Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
  Packages: 1650 pm: pacman pkgs: 1640 libs: 439
  tools: gnome-software,pamac,yay pm: flatpak pkgs: 10 Shell: Zsh v: 5.9
  running-in: gnome-terminal inxi: 3.3.28
If any additional info is needed, please let me know! thanks in advance!
why are you using these kernel parameters:
you definitely dont need ibt=off since you dont have nvidia…
the two other parameters could have something to do with your issue, but seeing that you are using wayland, switch to xorg and test with it first…
hi thanks for replying!
these variables are leftover from an old issue i was troubleshooting (the system was unable to wake up from sleep due to an i/o error). however, both removing the variables and switchting to xorg didn’t work.
ok, so try with different kernels, for example the 5.15 and the 6.4 …
also check if you are on RAID, instead of AHCI:
inxi -R
also create a new test user, reboot, log in with it and see if it has the same issue…
and when the freeze happens again, provide logs:
journalctl -b-1 -p4 --no-pager
hi!
switching kernels did not work, however a freshly created account does not encounter freezes, so it’s a good hint.
below i’m posting the logs of a freeze that always happens after login for 10 seconds. it lasted from 23:37:40 to :50.
i hope something can be found here ;))
ie 29 23:37:36 ibm-5100 gnome-shell[1210]: loading default theme (Adwaita)
sie 29 23:37:36 ibm-5100 gnome-shell[1210]: [x11gestures@joseexposito.github.io] Extension enabled
sie 29 23:37:36 ibm-5100 gnome-shell[1210]: [x11gestures@joseexposito.github.io] This extension is only for X11
sie 29 23:37:36 ibm-5100 at-spi-bus-launcher[1296]: dbus-daemon[1296]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=1000 pid=1210 comm="/usr/bin/gnome-shell")
sie 29 23:37:36 ibm-5100 at-spi-bus-launcher[1296]: dbus-daemon[1296]: Successfully activated service 'org.a11y.atspi.Registry'
sie 29 23:37:36 ibm-5100 at-spi-bus-launcher[1453]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
sie 29 23:37:36 ibm-5100 systemd[1096]: Started GNOME Shell on Wayland.
sie 29 23:37:36 ibm-5100 systemd[1096]: Reached target GNOME Session is initialized.
sie 29 23:37:36 ibm-5100 systemd[1096]: GNOME session X11 services is inactive.
sie 29 23:37:36 ibm-5100 systemd[1096]: Dependency failed for GNOME XSettings service.
sie 29 23:37:36 ibm-5100 systemd[1096]: org.gnome.SettingsDaemon.XSettings.service: Job org.gnome.SettingsDaemon.XSettings.service/start failed with result 'dependency'.
sie 29 23:37:36 ibm-5100 systemd[1096]: gnome-session-x11-services-ready.target: Job gnome-session-x11-services-ready.target/verify-active failed with result 'dependency'.
sie 29 23:37:36 ibm-5100 systemd[1096]: Reached target GNOME Session (session: gnome).
sie 29 23:37:36 ibm-5100 systemd[1096]: Reached target GNOME XSettings target.
sie 29 23:37:36 ibm-5100 systemd[1096]: Starting Signal initialization done to GNOME Session Manager...
sie 29 23:37:36 ibm-5100 systemd[1096]: Starting IBus Daemon for GNOME...
sie 29 23:37:36 ibm-5100 systemd[1096]: Starting GNOME accessibility service...
sie 29 23:37:36 ibm-5100 systemd[1096]: Starting GNOME color management service...
sie 29 23:37:36 ibm-5100 systemd[1096]: Starting GNOME date & time service...
sie 29 23:37:36 ibm-5100 systemd[1096]: Starting GNOME maintenance of expirable data service...
sie 29 23:37:36 ibm-5100 systemd[1096]: Starting GNOME keyboard configuration service...
sie 29 23:37:36 ibm-5100 systemd[1096]: Starting GNOME keyboard shortcuts service...
sie 29 23:37:36 ibm-5100 systemd[1096]: Starting GNOME power management service...
sie 29 23:37:36 ibm-5100 systemd[1096]: Starting GNOME printer notifications service...
sie 29 23:37:36 ibm-5100 systemd[1096]: Starting GNOME RFKill support service...
sie 29 23:37:36 ibm-5100 systemd[1096]: Starting GNOME FreeDesktop screensaver service...
sie 29 23:37:36 ibm-5100 systemd[1096]: Starting GNOME file sharing service...
sie 29 23:37:36 ibm-5100 systemd[1096]: Starting GNOME smartcard service...
sie 29 23:37:36 ibm-5100 systemd[1096]: Starting GNOME sound sample caching service...
sie 29 23:37:36 ibm-5100 systemd[1096]: Starting GNOME USB protection service...
sie 29 23:37:36 ibm-5100 systemd[1096]: Starting GNOME Wacom tablet support service...
sie 29 23:37:36 ibm-5100 systemd[1096]: Finished Signal initialization done to GNOME Session Manager.
sie 29 23:37:36 ibm-5100 systemd[1096]: Started Application launched by gnome-session-binary.
sie 29 23:37:36 ibm-5100 systemd[1096]: Started GNOME accessibility service.
sie 29 23:37:36 ibm-5100 systemd[1096]: Reached target GNOME accessibility target.
sie 29 23:37:36 ibm-5100 systemd[1096]: Started GNOME date & time service.
sie 29 23:37:36 ibm-5100 systemd[1096]: Reached target GNOME date & time target.
sie 29 23:37:36 ibm-5100 systemd[1096]: Started GNOME maintenance of expirable data service.
sie 29 23:37:36 ibm-5100 systemd[1096]: Reached target GNOME maintenance of expirable data target.
sie 29 23:37:36 ibm-5100 systemd[1096]: Started GNOME FreeDesktop screensaver service.
sie 29 23:37:36 ibm-5100 systemd[1096]: Reached target GNOME FreeDesktop screensaver target.
sie 29 23:37:36 ibm-5100 systemd[1096]: Started GNOME USB protection service.
sie 29 23:37:36 ibm-5100 systemd[1096]: Reached target GNOME USB protection target.
sie 29 23:37:36 ibm-5100 systemd[1096]: Started GNOME file sharing service.
sie 29 23:37:36 ibm-5100 systemd[1096]: Reached target GNOME file sharing target.
sie 29 23:37:36 ibm-5100 dbus-daemon[1119]: [session uid=1000 pid=1119] Activating service name='org.gnome.ScreenSaver' requested by ':1.49' (uid=1000 pid=1493 comm="/usr/lib/gsd-usb-protection")
sie 29 23:37:36 ibm-5100 kernel: rfkill: input handler disabled
sie 29 23:37:36 ibm-5100 systemd[1096]: Started GNOME RFKill support service.
sie 29 23:37:36 ibm-5100 systemd[1096]: Reached target GNOME RFKill support target.
sie 29 23:37:36 ibm-5100 dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service' requested by ':1.92' (uid=1000 pid=1478 comm="/usr/lib/gsd-print-notifications")
sie 29 23:37:36 ibm-5100 dbus-daemon[473]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.Avahi.service': Unit dbus-org.freedesktop.Avahi.service not found.
sie 29 23:37:36 ibm-5100 systemd[1096]: Started GNOME smartcard service.
sie 29 23:37:36 ibm-5100 systemd[1096]: Reached target GNOME smartcard target.
sie 29 23:37:36 ibm-5100 systemd[1096]: Started GNOME sound sample caching service.
sie 29 23:37:36 ibm-5100 systemd[1096]: Reached target GNOME sound sample caching target.
sie 29 23:37:36 ibm-5100 systemd[1096]: Started GNOME printer notifications service.
sie 29 23:37:36 ibm-5100 systemd[1096]: Reached target GNOME printer notifications target.
sie 29 23:37:36 ibm-5100 dbus-daemon[1119]: [session uid=1000 pid=1119] Activating service name='org.freedesktop.portal.IBus' requested by ':1.60' (uid=1000 pid=1463 comm="/usr/bin/ibus-daemon --panel disable")
sie 29 23:37:36 ibm-5100 systemd[1096]: Started IBus Daemon for GNOME.
sie 29 23:37:36 ibm-5100 gnome-shell[1210]: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
sie 29 23:37:36 ibm-5100 dbus-daemon[1119]: [session uid=1000 pid=1119] Successfully activated service 'org.freedesktop.portal.IBus'
sie 29 23:37:36 ibm-5100 gnome-session-binary[1195]: Entering running state
sie 29 23:37:36 ibm-5100 touchegg.desktop[1618]: Touchégg v2.0.16.
sie 29 23:37:36 ibm-5100 touchegg.desktop[1618]: Starting Touchégg in client mode
sie 29 23:37:36 ibm-5100 dbus-daemon[1119]: [session uid=1000 pid=1119] Successfully activated service 'org.gnome.ScreenSaver'
sie 29 23:37:36 ibm-5100 gnome-session[1195]: gnome-session-binary[1195]: GnomeDesktop-WARNING: Could not create transient scope for PID 1604: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 1604 does not exist.
sie 29 23:37:36 ibm-5100 gnome-session-binary[1195]: GnomeDesktop-WARNING: Could not create transient scope for PID 1604: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Process with ID 1604 does not exist.
sie 29 23:37:36 ibm-5100 systemd[1096]: app-gnome-no\x2dgnome\x2dtour-1637.scope: Couldn't move process 1637 to requested cgroup '/user.slice/user-1000.slice/user@1000.service/app.slice/app-gnome-no\x2dgnome\x2dtour-1637.scope': No such process
sie 29 23:37:36 ibm-5100 systemd[1096]: app-gnome-no\x2dgnome\x2dtour-1637.scope: Failed to add PIDs to scope's control group: No such process
sie 29 23:37:36 ibm-5100 systemd[1096]: app-gnome-no\x2dgnome\x2dtour-1637.scope: Failed with result 'resources'.
sie 29 23:37:36 ibm-5100 systemd[1096]: Failed to start Application launched by gnome-session-binary.
sie 29 23:37:36 ibm-5100 NetworkManager[484]: <info>  [1693345056.7286] agent-manager: agent[1e3eaf98c6e19fd6,:1.71/org.gnome.Shell.NetworkAgent/1000]: agent registered
sie 29 23:37:37 ibm-5100 gsd-usb-protect[1493]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
sie 29 23:37:37 ibm-5100 systemd[1096]: Started GNOME color management service.
sie 29 23:37:37 ibm-5100 systemd[1096]: Reached target GNOME color management target.
sie 29 23:37:37 ibm-5100 systemd[1096]: Started GNOME keyboard configuration service.
sie 29 23:37:37 ibm-5100 systemd[1096]: Reached target GNOME keyboard configuration target.
sie 29 23:37:37 ibm-5100 systemd[1096]: Started GNOME Wacom tablet support service.
sie 29 23:37:37 ibm-5100 systemd[1096]: Reached target GNOME Wacom tablet support target.
sie 29 23:37:37 ibm-5100 systemd[1096]: Reached target GNOME session X11 services.
sie 29 23:37:37 ibm-5100 gnome-shell[1749]: The XKEYBOARD keymap compiler (xkbcomp) reports:
sie 29 23:37:37 ibm-5100 gnome-shell[1749]: > Warning:          Unsupported maximum keycode 708, clipping.
sie 29 23:37:37 ibm-5100 gnome-shell[1749]: >                   X11 cannot support keycodes above 255.
sie 29 23:37:37 ibm-5100 gnome-shell[1749]: Errors from xkbcomp are not fatal to the X server
sie 29 23:37:37 ibm-5100 systemd[1096]: Starting GNOME XSettings service...
sie 29 23:37:37 ibm-5100 systemd[1096]: Started GNOME keyboard shortcuts service.
sie 29 23:37:37 ibm-5100 systemd[1096]: Started GNOME power management service.
sie 29 23:37:37 ibm-5100 systemd[1096]: Reached target GNOME keyboard shortcuts target.
sie 29 23:37:37 ibm-5100 systemd[1096]: Reached target GNOME power management target.
sie 29 23:37:37 ibm-5100 gsd-media-keys[1474]: Failed to grab accelerator for keybinding settings:hibernate
sie 29 23:37:37 ibm-5100 gsd-media-keys[1474]: Failed to grab accelerator for keybinding settings:playback-repeat
sie 29 23:37:38 ibm-5100 systemd[1096]: Started GNOME XSettings service.
sie 29 23:37:38 ibm-5100 systemd[1096]: Reached target GNOME session X11 services.
sie 29 23:37:38 ibm-5100 systemd[1096]: Reached target GNOME Session.
sie 29 23:37:38 ibm-5100 systemd[1096]: Reached target GNOME Wayland Session (session: gnome).
sie 29 23:37:38 ibm-5100 systemd[1096]: Reached target Current graphical user session.
sie 29 23:37:38 ibm-5100 touchegg.desktop[1618]: Parsing your configuration file...
sie 29 23:37:38 ibm-5100 touchegg.desktop[1618]: Using configuration file "/home/miloszek/.config/touchegg/touchegg.conf"
sie 29 23:37:38 ibm-5100 touchegg.desktop[1618]: Configuration parsed successfully
sie 29 23:37:38 ibm-5100 touchegg.desktop[1618]: Connecting to Touchégg daemon...
sie 29 23:37:38 ibm-5100 touchegg.desktop[1618]: Connection with Touchégg established
sie 29 23:37:38 ibm-5100 touchegg[476]: New client connection request
sie 29 23:37:38 ibm-5100 touchegg[476]: New client connected
sie 29 23:37:38 ibm-5100 gnome-shell[1210]: GNOME Shell started at Tue Aug 29 2023 23:37:35 GMT+0200 (Central European Summer Time)
sie 29 23:37:38 ibm-5100 gnome-shell[1210]: Registering session with GDM
sie 29 23:37:38 ibm-5100 systemd[1]: Stopping Session 1 of User gdm...
sie 29 23:37:38 ibm-5100 systemd[1]: session-1.scope: Deactivated successfully.
sie 29 23:37:38 ibm-5100 gdm[516]: Gdm: Child process -597 was already dead.
sie 29 23:37:38 ibm-5100 systemd[1]: Stopped Session 1 of User gdm.
sie 29 23:37:38 ibm-5100 systemd[1]: session-1.scope: Consumed 8.800s CPU time.
sie 29 23:37:38 ibm-5100 systemd-logind[475]: Removed session 1.
sie 29 23:37:38 ibm-5100 polkitd[474]: Unregistered Authentication Agent for unix-session:1 (system bus name :1.23, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8) (disconnected from bus)
sie 29 23:37:38 ibm-5100 kernel: warning: `QThread' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
sie 29 23:37:39 ibm-5100 gnome-shell[1210]: Window manager warning: Invalid WM_TRANSIENT_FOR window 0xa00007 specified for 0xa0002e.
sie 29 23:37:40 ibm-5100 bluetoothd[472]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
sie 29 23:37:42 ibm-5100 dbus-daemon[1119]: [session uid=1000 pid=1119] Activating via systemd: service name='org.freedesktop.portal.Desktop' unit='xdg-desktop-portal.service' requested by ':1.91' (uid=1000 pid=1611 comm="./jetbrains-toolbox --minimize")
sie 29 23:37:42 ibm-5100 systemd[1096]: Starting Portal service...
sie 29 23:37:42 ibm-5100 dbus-daemon[1119]: [session uid=1000 pid=1119] Activating via systemd: service name='org.freedesktop.portal.Documents' unit='xdg-document-portal.service' requested by ':1.92' (uid=1000 pid=1960 comm="/usr/lib/xdg-desktop-portal")
sie 29 23:37:42 ibm-5100 systemd[1096]: Starting flatpak document portal service...
sie 29 23:37:42 ibm-5100 dbus-daemon[1119]: [session uid=1000 pid=1119] Successfully activated service 'org.freedesktop.portal.Documents'
sie 29 23:37:42 ibm-5100 systemd[1096]: Started flatpak document portal service.
sie 29 23:37:42 ibm-5100 dbus-daemon[1119]: [session uid=1000 pid=1119] Activating via systemd: service name='org.freedesktop.impl.portal.desktop.gnome' unit='xdg-desktop-portal-gnome.service' requested by ':1.92' (uid=1000 pid=1960 comm="/usr/lib/xdg-desktop-portal")
sie 29 23:37:42 ibm-5100 systemd[1096]: Starting Portal service (GNOME implementation)...
sie 29 23:37:43 ibm-5100 dbus-daemon[1119]: [session uid=1000 pid=1119] Successfully activated service 'org.freedesktop.impl.portal.desktop.gnome'
sie 29 23:37:43 ibm-5100 systemd[1096]: Started Portal service (GNOME implementation).
sie 29 23:37:43 ibm-5100 rtkit-daemon[694]: Supervising 10 threads of 6 processes of 2 users.
sie 29 23:37:43 ibm-5100 dbus-daemon[1119]: [session uid=1000 pid=1119] Activating via systemd: service name='org.freedesktop.impl.portal.desktop.gtk' unit='xdg-desktop-portal-gtk.service' requested by ':1.92' (uid=1000 pid=1960 comm="/usr/lib/xdg-desktop-portal")
sie 29 23:37:43 ibm-5100 systemd[1096]: Starting Portal service (GTK/GNOME implementation)...
sie 29 23:37:48 ibm-5100 systemd[1]: Stopping User Manager for UID 120...
sie 29 23:37:48 ibm-5100 systemd[577]: Activating special unit Exit the Session...
sie 29 23:37:48 ibm-5100 systemd[577]: Stopped target Main User Target.
sie 29 23:37:48 ibm-5100 systemd[577]: Stopping D-Bus User Message Bus...
sie 29 23:37:48 ibm-5100 systemd[577]: Stopping PipeWire PulseAudio...
sie 29 23:37:48 ibm-5100 systemd[577]: Stopped D-Bus User Message Bus.
sie 29 23:37:48 ibm-5100 systemd[577]: Stopped PipeWire PulseAudio.
sie 29 23:37:48 ibm-5100 systemd[577]: Stopping PipeWire Media Session Manager...
sie 29 23:37:48 ibm-5100 systemd[577]: Stopped PipeWire Media Session Manager.
sie 29 23:37:48 ibm-5100 systemd[577]: Stopping PipeWire Multimedia Service...
sie 29 23:37:48 ibm-5100 systemd[577]: Stopped PipeWire Multimedia Service.
sie 29 23:37:48 ibm-5100 systemd[577]: Removed slice User Core Session Slice.
sie 29 23:37:48 ibm-5100 systemd[577]: Stopped target Basic System.
sie 29 23:37:48 ibm-5100 systemd[577]: Stopped target Paths.
sie 29 23:37:48 ibm-5100 systemd[577]: Stopped target Sockets.
sie 29 23:37:48 ibm-5100 systemd[577]: Stopped target Timers.
sie 29 23:37:48 ibm-5100 systemd[577]: Closed D-Bus User Message Bus Socket.
sie 29 23:37:48 ibm-5100 systemd[577]: Closed GnuPG network certificate management daemon.
sie 29 23:37:48 ibm-5100 systemd[577]: Closed GCR ssh-agent wrapper.
sie 29 23:37:48 ibm-5100 systemd[577]: Closed GNOME Keyring daemon.
sie 29 23:37:48 ibm-5100 systemd[577]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
sie 29 23:37:48 ibm-5100 systemd[577]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
sie 29 23:37:48 ibm-5100 systemd[577]: Closed GnuPG cryptographic agent (ssh-agent emulation).
sie 29 23:37:48 ibm-5100 systemd[577]: Closed GnuPG cryptographic agent and passphrase cache.
sie 29 23:37:48 ibm-5100 systemd[577]: Closed p11-kit server.
sie 29 23:37:48 ibm-5100 systemd[577]: Closed PipeWire PulseAudio.
sie 29 23:37:48 ibm-5100 systemd[577]: Closed PipeWire Multimedia System Socket.
sie 29 23:37:48 ibm-5100 systemd[577]: Removed slice User Application Slice.
sie 29 23:37:48 ibm-5100 systemd[577]: Reached target Shutdown.
sie 29 23:37:48 ibm-5100 systemd[577]: Finished Exit the Session.
sie 29 23:37:48 ibm-5100 systemd[577]: Reached target Exit the Session.
sie 29 23:37:48 ibm-5100 (sd-pam)[579]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[gdm] ruser=[<unknown>] rhost=[<unknown>]
sie 29 23:37:48 ibm-5100 systemd[1]: user@120.service: Deactivated successfully.
sie 29 23:37:48 ibm-5100 systemd[1]: Stopped User Manager for UID 120.
sie 29 23:37:48 ibm-5100 systemd[1]: Stopping User Runtime Directory /run/user/120...
sie 29 23:37:48 ibm-5100 systemd[1]: run-user-120.mount: Deactivated successfully.
sie 29 23:37:48 ibm-5100 systemd[1]: user-runtime-dir@120.service: Deactivated successfully.
sie 29 23:37:48 ibm-5100 systemd[1]: Stopped User Runtime Directory /run/user/120.
sie 29 23:37:48 ibm-5100 systemd[1]: Removed slice User Slice of UID 120.
sie 29 23:37:48 ibm-5100 systemd[1]: user-120.slice: Consumed 9.247s CPU time.
sie 29 23:37:51 ibm-5100 systemd[1096]: Started Application launched by gsd-media-keys.
sie 29 23:37:52 ibm-5100 dbus-daemon[1119]: [session uid=1000 pid=1119] Successfully activated service 'org.freedesktop.impl.portal.desktop.gtk'
sie 29 23:37:52 ibm-5100 systemd[1096]: Started Portal service (GTK/GNOME implementation).
sie 29 23:37:52 ibm-5100 dbus-daemon[1119]: [session uid=1000 pid=1119] Successfully activated service 'org.freedesktop.portal.Desktop'
sie 29 23:37:52 ibm-5100 systemd[1096]: Started Portal service.
sie 29 23:37:52 ibm-5100 dbus-daemon[1119]: [session uid=1000 pid=1119] Activating via systemd: service name='org.gnome.Terminal' unit='gnome-terminal-server.service' requested by ':1.97' (uid=1000 pid=2014 comm="/usr/bin/gnome-terminal")
sie 29 23:37:52 ibm-5100 systemd[1096]: Created slice Slice /app/org.gnome.Terminal.
sie 29 23:37:52 ibm-5100 systemd[1096]: Starting GNOME Terminal Server...
sie 29 23:37:52 ibm-5100 gnome-shell[1210]: Received property WindowId with type u does not match expected type i in the expected interface
sie 29 23:37:52 ibm-5100 gnome-shell[1210]: Received property Menu with type s does not match expected type o in the expected interface
sie 29 23:37:52 ibm-5100 dbus-daemon[1119]: [session uid=1000 pid=1119] Successfully activated service 'org.gnome.Terminal'
sie 29 23:37:52 ibm-5100 systemd[1096]: Started GNOME Terminal Server.
sie 29 23:37:52 ibm-5100 systemd[1096]: Started Application launched by gsd-media-keys.
sie 29 23:37:52 ibm-5100 systemd[1096]: Started VTE child process 2064 launched by gnome-terminal-server process 2029.
sie 29 23:37:53 ibm-5100 systemd[1096]: Started VTE child process 2080 launched by gnome-terminal-server process 2029.
sie 29 23:37:53 ibm-5100 gnome-shell[1210]: Trying to set property Menu of type s but according to the expected interface the type is o
sie 29 23:37:54 ibm-5100 gnome-shell[1210]: Trying to set property Menu of type s but according to the expected interface the type is o
sie 29 23:37:54 ibm-5100 systemd-timesyncd[468]: Contacted time server 162.159.200.1:123 (2.manjaro.pool.ntp.org).
sie 29 23:37:54 ibm-5100 systemd-timesyncd[468]: Initial clock synchronization to Tue 2023-08-29 23:37:55.095251 CEST.
sie 29 23:37:55 ibm-5100 gnome-shell[1210]: Trying to set property Menu of type s but according to the expected interface the type is o
sie 29 23:37:58 ibm-5100 systemd[1]: fprintd.service: Deactivated successfully.
peace!
so in your main user rename the following folders:
.cache to .cache.bak
reboot and see if it helped, if not, rename this:
.config ro .config.bak
reboot and see… if it helped, copy from the bak folder, to the newly created .config folder your browser folder/s if you dont want to set them up again…
hi!
getting rid of the .local folder helped. i have no exact idea why, but the lag is now gone
peace and thanks for helping me!
