Gnome not recognizing HDMI port NVIDIA GPU
So my GPU is recognized by yet the HDMI port is not working. Whenever I plug the extra monitor it's as if I didn't plug anything at all.
I've read plenty of similar posts but none seem to fix the problem...this is also due to my lack of technical knowledge when dealing with drivers. I've read about bumblebeed and few other services used to initiate the port but I'm still not understanding.
I would really appreciate any help at all in understanding how these drivers work and what's preventing it from displaying to the HDMI port.
Welcome to Manjaro! Are you using the proprietary NVIDIA driver and is this on a laptop? Bumblebee is really only needed for a laptop and might not always work with your card. Also, what model is your card (i. e. GTX 1050, RTX 2070, etc)?
Please post
inxi -SMGxxaz
mhwd -li
xrandr
for Xconf in $(ls /etc/X11/xorg.conf.d/*.conf); do echo -e "\n" $Xconf ; cat $Xconf ; done
journalctl -b -p3 --no-pager --no-hostname
for Xlog in $(ls /var/log/Xorg.?.log); do echo -e "\n" $Xlog ; grep -E "(EE)|(WW)|failed|Time" $Xlog ; done
I don't think I am...the computer isn't recognizing the GPU and it's GTX 1660 Ti
inxi -SMGxxaz
  Host: Stealth Kernel: 5.3.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.3-x86_64
  root=UUID=8233b166-a6b9-40ba-9109-0ac1067af3a8 rw quiet apparmor=1
  Desktop: Gnome 3.34.1 wm: gnome-shell dm: GDM, LightDM Distro: Manjaro Linux
  Type: Laptop System: Micro-Star product: GS65 Stealth 9SD v: REV:1.0
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: Micro-Star model: MS-16Q4 v: REV:1.0 serial: <filter>
  UEFI [Legacy]: American Megatrends v: E16Q4IMS.110 date: 04/02/2019
  Device-1: Intel UHD Graphics 630 vendor: Micro-Star MSI driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:3e9b
  Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] driver: N/A
  bus ID: 01:00.0 chip ID: 10de:2191
  Display: wayland server: X.Org 1.20.5 driver: intel unloaded: modesetting
  alternate: fbdev,vesa compositor: gnome-shell resolution: 1920x1080~144Hz
  OpenGL: renderer: Mesa DRI Intel UHD Graphics 630 (Coffeelake 3x8 GT2)
  v: 4.5 Mesa 19.2.6 compat-v: 3.0 direct render: Yes
mhwd -li
> Installed PCI configs:
video-hybrid-intel-nvidia-430xx-bumblebee            2019.10.25               false            PCI
           video-linux            2018.05.04                true            PCI
xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 8192 x 8192
XWAYLAND0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 340mm x 190mm
   1920x1080    143.88*+
 /etc/X11/xorg.conf.d/00-keyboard.conf
# Read and parsed by systemd-localed. It's probably wise not to edit this file
# manually too freely.
Section "InputClass"
        Identifier "system-keyboard"
        MatchIsKeyboard "on"
        Option "XkbLayout" "us"
        Option "XkbModel" "pc105"
EndSection
 /etc/X11/xorg.conf.d/90-mhwd.conf
## Generated by mhwd - Manjaro Hardware Detection
Section "Device"
    Identifier  "Device0"
    Driver      "intel"
    BusID       "PCI:0:2:0"
    Option      "AccelMethod" "sna"
	Option      "DRI"    "true"
EndSection
Section "DRI"
        Group  "video"
        Mode   0666
EndSection
Section "Extensions"
    Option "Composite" "Enable"
    Option "RENDER"    "Enable"
EndSection
    Identifier          "Keyboard Defaults"
    MatchIsKeyboard        "yes"
    Option              "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
--Only output the tail because the full was really long
                                        #4  0x00007f78b99a9c11 n/a (libglib-2.0.so.0)
                                        #5  0x00007f78b42d04cf start_thread (libpthread.so.0)
                                        #6  0x00007f78ba9232d3 __clone (libc.so.6)
dic 01 23:26:55 kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x71b
dic 01 23:39:07 kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x71b
dic 01 23:39:16 kernel: ACPI Error: No handler for Region [VRTC] (0000000031e2bae4) [SystemCMOS] (20190703/evregion-127)
dic 01 23:39:16 kernel: ACPI Error: Region SystemCMOS (ID=5) has no handler (20190703/exfldio-261)
dic 01 23:39:16 kernel: ACPI Error: Aborting method \_SB.PCI0.LPCB.EC._Q9A due to previous error (AE_NOT_EXIST) (20190703/psparse-529)
 /var/log/Xorg.0.log
[     3.966] Current Operating System: Linux Stealth 5.3.11-1-MANJARO #1 SMP PREEMPT Wed Nov 13 12:21:14 UTC 2019 x86_64
[     3.966] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Nov 23 10:47:22 2019
[     3.969] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     3.969] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     3.969] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[     3.969] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[     3.992] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     4.001] (WW) Warning, couldn't open module fbdev
[     4.001] (EE) Failed to load module "fbdev" (module does not exist, 0)
[     4.002] (WW) Warning, couldn't open module vesa
[     4.002] (EE) Failed to load module "vesa" (module does not exist, 0)
[     4.019] (WW) Falling back to old probe method for modesetting
[     4.025] (II) Initializing extension MIT-SCREEN-SAVER
 /var/log/Xorg.1.log
[  2330.963] Current Operating System: Linux Stealth 5.3.11-1-MANJARO #1 SMP PREEMPT Wed Nov 13 12:21:14 UTC 2019 x86_64
[  2330.964] (==) Log file: "/var/log/Xorg.1.log", Time: Sat Nov 23 00:34:49 2019
[  2330.965] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[  2330.965] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[  2330.965] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[  2330.965] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[  2330.969] (EE) /dev/dri/card0: failed to set DRM interface version 1.4: Permission denied
[  2330.977] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[  2330.984] (WW) Warning, couldn't open module fbdev
[  2330.984] (EE) Failed to load module "fbdev" (module does not exist, 0)
[  2330.985] (WW) Warning, couldn't open module vesa
[  2330.985] (EE) Failed to load module "vesa" (module does not exist, 0)
[  2331.600] (WW) Falling back to old probe method for modesetting
[  2331.613] (II) Initializing extension MIT-SCREEN-SAVER
[  2332.076] (EE) /dev/dri/card0: failed to set DRM interface version 1.4: Permission denied
 /var/log/Xorg.8.log
[  5082.966] Current Operating System: Linux Stealth 5.3.12-1-MANJARO #1 SMP PREEMPT Thu Nov 21 10:55:53 UTC 2019 x86_64
[  5082.966] (==) Log file: "/var/log/Xorg.8.log", Time: Sun Nov 24 16:53:21 2019
[  5082.967] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[  5082.967] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[  5082.967] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[  5082.967] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[  5082.968] (EE) /dev/dri/card0: failed to set DRM interface version 1.4: Permission denied
[  5082.969] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[  5083.921] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[  5084.021] (WW) NVIDIA(0): Option "NoLogo" is not used
[  5084.022] (II) Initializing extension MIT-SCREEN-SAVER
[  5084.047] (EE) /dev/dri/card0: failed to set DRM interface version 1.4: Permission denied
[  7074.090] (WW) NVIDIA(0): Failed to set DPMS to on
[  7074.092] (WW) NVIDIA(0): Failed to set DPMS to on
The easiest recommended way to see the external monitor when using bumblebee (and monitor output is attached to nvidia gpu) is with intel-virtual-output.
Try one of these (first the... 1st)
##  or
optirun intel-virtual-output
Else try another optimus method
In Gnome the Xorg logs are at
~/.local/share/xorg/*.log
The monitor recognized the signal yet its not displaying anything. Given the command specified the output is No VIRTUAL outputs on ":0". for both.
The logs specified are these.
[    15.131] (--) Log file renamed from "/home/cinta/.local/share/xorg/Xorg.pid-1441.log" to "/home/cinta/.local/share/xorg/Xorg.0.log"
[    15.131] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[    15.132]
X.Org X Server 1.20.5
[    15.132] Build Operating System: Linux Arch Linux
[    15.132] Current Operating System: Linux Stealth 5.3.12-1-MANJARO #1 SMP PREEMPT Thu Nov 21 10:55:53 UTC 2019 x86_64
[    15.132] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.3-x86_64 root=UUID=8233b166-a6b9-40ba-9109-0ac1067af3a8 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[    15.132] Build Date: 27 October 2019  08:49:23AM
[    15.132]
[    15.132] Current version of pixman: 0.38.4
[    15.132] 	Before reporting problems, check http://wiki.x.org
[    15.132] Markers: (--) probed, (**) from config file, (==) default setting,
[    15.132] (==) Log file: "/home/cinta/.local/share/xorg/Xorg.0.log", Time: Sat Nov 23 17:49:10 2019
[    15.133] (==) Using config file: "/etc/X11/xorg.conf"
[    15.133] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    15.133] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    15.134] (==) ServerLayout "Layout0"
[    15.134] (**) |-->Screen "Screen0" (0)
[    15.134] (**) |   |-->Monitor "Monitor0"
[    15.134] (**) |   |-->Device "Device0"
[    15.134] (**) |   |-->GPUDevice "Device0"
[    15.135] (**) |-->Input Device "Keyboard0"
[    15.135] (**) |-->Input Device "Mouse0"
[    15.135] (==) Automatically adding devices
[    15.135] (==) Automatically enabling devices
[    15.135] (==) Automatically adding GPU devices
[    15.135] (==) Automatically binding GPU devices
[    15.135] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    15.135] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    15.135] 	Entry deleted from font path.
[    15.135] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    15.135] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[    15.135] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[    15.135] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[    15.135] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[    15.135] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[    15.135] (==) ModulePath set to "/usr/lib/xorg/modules"
[    15.135] (**) Extension "Composite" is enabled
[    15.135] (**) Extension "RENDER" is enabled
[    15.135] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[    15.135] (WW) Disabling Keyboard0
[    15.135] (WW) Disabling Mouse0
[    15.135] (II) Module ABI versions:
[    15.135] 	X.Org ANSI C Emulation: 0.4
[    15.135] 	X.Org Video Driver: 24.0
[    15.135] 	X.Org XInput driver : 24.1
[    15.135] 	X.Org Server Extension : 10.0
[    15.135] (++) using VT number 2
[    15.137] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_32
[    15.137] (II) xfree86: Adding drm device (/dev/dri/card0)
[    15.138] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
[    15.140] (--) PCI:*(0@0:2:0) 8086:3e9b:1462:1274 rev 0, Mem @ 0xab000000/16777216, 0x40000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[    15.140] (--) PCI: (1@0:0:0) 10de:2191:1462:1274 rev 161, Mem @ 0xac000000/16777216, 0x80000000/268435456, 0x90000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[    15.140] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    15.140] (II) LoadModule: "glx"
[    15.141] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    15.143] (II) Module glx: vendor="X.Org Foundation"
[    15.143] 	compiled for 1.20.5, module version = 1.0.0
[    15.143] 	ABI class: X.Org Server Extension, version 10.0
[    15.143] (II) LoadModule: "intel"
[    15.143] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[    15.144] (II) Module intel: vendor="X.Org Foundation"
[    15.144] 	compiled for 1.20.5, module version = 2.99.917
[    15.144] 	Module class: X.Org Video Driver
[    15.144] 	ABI class: X.Org Video Driver, version 24.0
[    15.144] (II) LoadModule: "nvidia"
[    15.144] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    15.147] (II) Module nvidia: vendor="NVIDIA Corporation"
[    15.147] 	compiled for 1.6.99.901, module version = 1.0.0
[    15.147] 	Module class: X.Org Video Driver
[    15.148] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
	i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
	915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
	Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
	GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[    15.148] (II) intel: Driver for Intel(R) HD Graphics
[    15.148] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[    15.148] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[    15.148] (II) NVIDIA dlloader X Driver  430.64  Sun Oct 27 11:10:43 UTC 2019
[    15.148] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    15.149] xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)
[    15.149] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20190619
[    15.149] (II) intel(0): SNA compiled from 2.99.917-893-gbff5eca4
[    15.164] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[    15.165] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics
[    15.165] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 6 threads
[    15.165] (**) intel(0): Depth 24, (--) framebuffer bpp 32
[    15.165] (==) intel(0): RGB weight 888
[    15.165] (==) intel(0): Default visual is TrueColor
[    15.165] (**) intel(0): Option "AccelMethod" "sna"
[    15.165] (**) intel(0): Option "DRI" "true"
[    15.165] (II) intel(0): Output eDP1 using monitor section Monitor0
[    15.166] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[    15.166] (II) intel(0): Enabled output eDP1
[    15.166] (II) intel(0): Output DP1 has no monitor section
[    15.166] (II) intel(0): Enabled output DP1
[    15.166] (II) intel(0): Output HDMI1 has no monitor section
[    15.166] (II) intel(0): Enabled output HDMI1
[    15.166] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[    15.167] (II) intel(0): Output VIRTUAL1 has no monitor section
[    15.167] (II) intel(0): Enabled output VIRTUAL1
[    15.167] (--) intel(0): Output eDP1 using initial mode 1920x1080 on pipe 0
[    15.167] (==) intel(0): TearFree disabled
[    15.167] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[    15.167] (==) intel(0): DPI set to (96, 96)
[    15.167] (II) Loading sub module "dri3"
[    15.167] (II) LoadModule: "dri3"
[    15.167] (II) Module "dri3" already built-in
[    15.167] (II) Loading sub module "dri2"
[    15.167] (II) LoadModule: "dri2"
[    15.167] (II) Module "dri2" already built-in
[    15.167] (II) Loading sub module "present"
[    15.167] (II) LoadModule: "present"
[    15.167] (II) Module "present" already built-in
[    15.167] (II) UnloadModule: "nvidia"
[    15.167] (II) Unloading nvidia
[    15.168] (II) intel(0): SNA initialized with Coffeelake (gen9) backend
[    15.168] (==) intel(0): Backing store enabled
[    15.168] (==) intel(0): Silken mouse disabled
[    15.168] (II) intel(0): HW Cursor enabled
[    15.169] (**) intel(0): DPMS enabled
[    15.169] (==) intel(0): Display hotplug detection enabled
[    15.169] (II) intel(0): [DRI2] Setup complete
[    15.169] (II) intel(0): [DRI2]   DRI driver: i965
[    15.169] (II) intel(0): [DRI2]   VDPAU driver: va_gl
[    15.169] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[    15.169] (II) intel(0): hardware support for Present enabled
[    15.169] (II) Initializing extension Generic Event Extension
[    15.169] (II) Initializing extension SHAPE
[    15.169] (II) Initializing extension MIT-SHM
[    15.169] (II) Initializing extension XInputExtension
[    15.169] (II) Initializing extension XTEST
[    15.169] (II) Initializing extension BIG-REQUESTS
[    15.169] (II) Initializing extension SYNC
[    15.169] (II) Initializing extension XKEYBOARD
[    15.169] (II) Initializing extension XC-MISC
[    15.169] (II) Initializing extension SECURITY
[    15.169] (II) Initializing extension XFIXES
[    15.169] (II) Initializing extension RENDER
[    15.169] (II) Initializing extension RANDR
[    15.169] (II) Initializing extension COMPOSITE
[    15.169] (II) Initializing extension DAMAGE
[    15.169] (II) Initializing extension MIT-SCREEN-SAVER
[    15.169] (II) Initializing extension DOUBLE-BUFFER
[    15.169] (II) Initializing extension RECORD
[    15.169] (II) Initializing extension DPMS
[    15.169] (II) Initializing extension Present
[    15.170] (II) Initializing extension DRI3
[    15.170] (II) Initializing extension X-Resource
[    15.170] (II) Initializing extension XVideo
[    15.170] (II) Initializing extension XVideo-MotionCompensation
[    15.170] (II) Initializing extension GLX
[    15.180] (II) AIGLX: Loaded and initialized i965
[    15.180] (II) GLX: Initialized DRI2 GL provider for screen 0
[    15.180] (II) Initializing extension XFree86-VidModeExtension
[    15.180] (II) Initializing extension XFree86-DGA
[    15.180] (II) Initializing extension XFree86-DRI
[    15.180] (II) Initializing extension DRI2
[    15.184] (II) intel(0): switch to mode 1920x1080@144.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[    15.187] (II) intel(0): Setting screen physical size to 508 x 285
[    15.228] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[    15.228] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    15.228] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    15.228] (**) Power Button: Applying InputClass "system-keyboard"
[    15.228] (**) Power Button: Applying InputClass "Keyboard Defaults"
[    15.228] (II) LoadModule: "libinput"
[    15.228] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    15.230] (II) Module libinput: vendor="X.Org Foundation"
[    15.230] 	compiled for 1.20.5, module version = 0.29.0
[    15.230] 	Module class: X.Org XInput Driver
[    15.230] 	ABI class: X.Org XInput driver, version 24.1
[    15.230] (II) Using input driver 'libinput' for 'Power Button'
[    15.231] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 16 paused 0
[    15.231] (**) Power Button: always reports core events
[    15.231] (**) Option "Device" "/dev/input/event3"
[    15.231] (**) Option "_source" "server/udev"
[    15.233] (II) event3  - Power Button: is tagged by udev as: Keyboard
[    15.233] (II) event3  - Power Button: device is a keyboard
[    15.234] (II) event3  - Power Button: device removed
[    15.234] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[    15.234] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    15.234] (**) Option "xkb_model" "pc105"
[    15.234] (**) Option "xkb_layout" "us"
[    15.234] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    15.254] (II) event3  - Power Button: is tagged by udev as: Keyboard
[    15.254] (II) event3  - Power Button: device is a keyboard
[    15.254] (II) config/udev: Adding input device Video Bus (/dev/input/event9)
[    15.254] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    15.254] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    15.254] (**) Video Bus: Applying InputClass "system-keyboard"
[    15.254] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[    15.254] (II) Using input driver 'libinput' for 'Video Bus'
[    15.255] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 19 paused 0
[    15.255] (**) Video Bus: always reports core events
[    15.255] (**) Option "Device" "/dev/input/event9"
[    15.255] (**) Option "_source" "server/udev"
[    15.256] (II) event9  - Video Bus: is tagged by udev as: Keyboard
[    15.256] (II) event9  - Video Bus: device is a keyboard
[    15.256] (II) event9  - Video Bus: device removed
[    15.256] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input16/event9"
[    15.256] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    15.256] (**) Option "xkb_model" "pc105"
[    15.256] (**) Option "xkb_layout" "us"
[    15.256] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    15.258] (II) event9  - Video Bus: is tagged by udev as: Keyboard
[    15.258] (II) event9  - Video Bus: device is a keyboard
[    15.258] (II) config/udev: Adding input device Video Bus (/dev/input/event10)
[    15.258] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    15.258] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    15.258] (**) Video Bus: Applying InputClass "system-keyboard"
[    15.258] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[    15.258] (II) Using input driver 'libinput' for 'Video Bus'
[    15.259] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 20 paused 0
[    15.259] (**) Video Bus: always reports core events
[    15.259] (**) Option "Device" "/dev/input/event10"
[    15.259] (**) Option "_source" "server/udev"
[    15.261] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[    15.261] (II) event10 - Video Bus: device is a keyboard
[    15.261] (II) event10 - Video Bus: device removed
[    15.261] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:13/LNXVIDEO:01/input/input17/event10"
[    15.261] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[    15.261] (**) Option "xkb_model" "pc105"
[    15.261] (**) Option "xkb_layout" "us"
[    15.261] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    15.262] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[    15.262] (II) event10 - Video Bus: device is a keyboard
[    15.263] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[    15.263] (II) No input driver specified, ignoring this device.
[    15.263] (II) This device may have been added with another device file.
[    15.264] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    15.264] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    15.264] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    15.264] (**) Power Button: Applying InputClass "system-keyboard"
[    15.264] (**) Power Button: Applying InputClass "Keyboard Defaults"
[    15.264] (II) Using input driver 'libinput' for 'Power Button'
[    15.264] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 21 paused 0
[    15.264] (**) Power Button: always reports core events
[    15.264] (**) Option "Device" "/dev/input/event2"
[    15.264] (**) Option "_source" "server/udev"
[    15.265] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    15.266] (II) event2  - Power Button: device is a keyboard
[    15.266] (II) event2  - Power Button: device removed
[    15.266] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2/event2"
[    15.266] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[    15.266] (**) Option "xkb_model" "pc105"
[    15.266] (**) Option "xkb_layout" "us"
[    15.266] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    15.267] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    15.267] (II) event2  - Power Button: device is a keyboard
[    15.268] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[    15.268] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    15.268] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[    15.268] (**) Sleep Button: Applying InputClass "system-keyboard"
[    15.268] (**) Sleep Button: Applying InputClass "Keyboard Defaults"
[    15.268] (II) Using input driver 'libinput' for 'Sleep Button'
[    15.268] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 22 paused 0
[    15.268] (**) Sleep Button: always reports core events
[    15.268] (**) Option "Device" "/dev/input/event1"
[    15.268] (**) Option "_source" "server/udev"
[    15.269] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[    15.269] (II) event1  - Sleep Button: device is a keyboard
[    15.270] (II) event1  - Sleep Button: device removed
[    15.270] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[    15.270] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[    15.270] (**) Option "xkb_model" "pc105"
[    15.270] (**) Option "xkb_layout" "us"
[    15.270] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    15.271] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[    15.271] (II) event1  - Sleep Button: device is a keyboard
[    15.272] (II) config/udev: Adding input device HD Webcam: HD Webcam (/dev/input/event23)
[    15.272] (**) HD Webcam: HD Webcam: Applying InputClass "evdev keyboard catchall"
[    15.272] (**) HD Webcam: HD Webcam: Applying InputClass "libinput keyboard catchall"
[    15.272] (**) HD Webcam: HD Webcam: Applying InputClass "system-keyboard"
[    15.272] (**) HD Webcam: HD Webcam: Applying InputClass "Keyboard Defaults"
[    15.272] (II) Using input driver 'libinput' for 'HD Webcam: HD Webcam'
[    15.272] (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 23 paused 0
[    15.272] (**) HD Webcam: HD Webcam: always reports core events
[    15.272] (**) Option "Device" "/dev/input/event23"
[    15.272] (**) Option "_source" "server/udev"
[    15.274] (II) event23 - HD Webcam: HD Webcam: is tagged by udev as: Keyboard
[    15.274] (II) event23 - HD Webcam: HD Webcam: device is a keyboard
[    15.274] (II) event23 - HD Webcam: HD Webcam: device removed
[    15.274] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.0/input/input30/event23"
[    15.274] (II) XINPUT: Adding extended input device "HD Webcam: HD Webcam" (type: KEYBOARD, id 11)
[    15.274] (**) Option "xkb_model" "pc105"
[    15.274] (**) Option "xkb_layout" "us"
[    15.274] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    15.275] (II) event23 - HD Webcam: HD Webcam: is tagged by udev as: Keyboard
[    15.275] (II) event23 - HD Webcam: HD Webcam: device is a keyboard
[    15.276] (II) config/udev: Adding input device Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse (/dev/input/event17)
[    15.276] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse: Applying InputClass "evdev pointer catchall"
[    15.276] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse: Applying InputClass "libinput pointer catchall"
[    15.276] (II) Using input driver 'libinput' for 'Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse'
[    15.276] (II) systemd-logind: got fd for /dev/input/event17 13:81 fd 24 paused 0
[    15.277] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse: always reports core events
[    15.277] (**) Option "Device" "/dev/input/event17"
[    15.277] (**) Option "_source" "server/udev"
[    15.278] (II) event17 - Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse: is tagged by udev as: Mouse
[    15.278] (II) event17 - Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse: device is a pointer
[    15.278] (II) event17 - Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse: device removed
[    15.278] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/0003:1B1C:1B74.0002/input/input24/event17"
[    15.278] (II) XINPUT: Adding extended input device "Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse" (type: MOUSE, id 12)
[    15.278] (**) Option "AccelerationScheme" "none"
[    15.278] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse: (accel) selected scheme none/0
[    15.278] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse: (accel) acceleration factor: 2.000
[    15.278] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse: (accel) acceleration threshold: 4
[    15.279] (II) event17 - Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse: is tagged by udev as: Mouse
[    15.280] (II) event17 - Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse: device is a pointer
[    15.280] (II) config/udev: Adding input device Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse (/dev/input/js0)
[    15.280] (II) No input driver specified, ignoring this device.
[    15.280] (II) This device may have been added with another device file.
[    15.281] (II) config/udev: Adding input device Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse (/dev/input/mouse1)
[    15.281] (II) No input driver specified, ignoring this device.
[    15.281] (II) This device may have been added with another device file.
[    15.281] (II) config/udev: Adding input device Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control (/dev/input/event18)
[    15.281] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[    15.281] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[    15.281] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
[    15.281] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control: Applying InputClass "Keyboard Defaults"
[    15.281] (II) Using input driver 'libinput' for 'Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control'
[    15.282] (II) systemd-logind: got fd for /dev/input/event18 13:82 fd 25 paused 0
[    15.282] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control: always reports core events
[    15.282] (**) Option "Device" "/dev/input/event18"
[    15.282] (**) Option "_source" "server/udev"
[    15.283] (II) event18 - Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
[    15.283] (II) event18 - Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control: device is a keyboard
[    15.283] (II) event18 - Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control: device removed
[    15.283] (II) libinput: Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control: needs a virtual subdevice
[    15.283] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/0003:1B1C:1B74.0002/input/input25/event18"
[    15.283] (II) XINPUT: Adding extended input device "Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control" (type: MOUSE, id 13)
[    15.283] (**) Option "AccelerationScheme" "none"
[    15.283] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control: (accel) selected scheme none/0
[    15.283] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control: (accel) acceleration factor: 2.000
[    15.283] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control: (accel) acceleration threshold: 4
[    15.284] (II) event18 - Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
[    15.284] (II) event18 - Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control: device is a keyboard
[    15.285] (II) config/udev: Adding input device Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse (/dev/input/event19)
[    15.285] (II) No input driver specified, ignoring this device.
[    15.285] (II) This device may have been added with another device file.
[    15.285] (II) config/udev: Adding input device Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse (/dev/input/event20)
[    15.286] (II) config/udev: Adding input device Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Keyboard (/dev/input/event21)
[    15.286] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Keyboard: Applying InputClass "evdev keyboard catchall"
[    15.286] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[    15.286] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[    15.286] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Keyboard: Applying InputClass "Keyboard Defaults"
[    15.286] (II) Using input driver 'libinput' for 'Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Keyboard'
[    15.286] (II) systemd-logind: got fd for /dev/input/event21 13:85 fd 26 paused 0
[    15.286] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Keyboard: always reports core events
[    15.286] (**) Option "Device" "/dev/input/event21"
[    15.286] (**) Option "_source" "server/udev"
[    15.287] (II) event21 - Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[    15.287] (II) event21 - Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Keyboard: device is a keyboard
[    15.288] (II) event21 - Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Keyboard: device removed
[    15.288] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/0003:1B1C:1B74.0002/input/input28/event21"
[    15.288] (II) XINPUT: Adding extended input device "Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Keyboard" (type: KEYBOARD, id 14)
[    15.288] (**) Option "xkb_model" "pc105"
[    15.288] (**) Option "xkb_layout" "us"
[    15.288] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    15.289] (II) event21 - Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[    15.289] (II) event21 - Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Keyboard: device is a keyboard
[    15.289] (II) config/udev: Adding input device SteelSeries SteelSeries KLC (/dev/input/event22)
[    15.289] (**) SteelSeries SteelSeries KLC: Applying InputClass "evdev keyboard catchall"
[    15.289] (**) SteelSeries SteelSeries KLC: Applying InputClass "libinput keyboard catchall"
[    15.289] (**) SteelSeries SteelSeries KLC: Applying InputClass "system-keyboard"
[    15.289] (**) SteelSeries SteelSeries KLC: Applying InputClass "Keyboard Defaults"
[    15.289] (II) Using input driver 'libinput' for 'SteelSeries SteelSeries KLC'
[    15.290] (II) systemd-logind: got fd for /dev/input/event22 13:86 fd 27 paused 0
[    15.290] (**) SteelSeries SteelSeries KLC: always reports core events
[    15.290] (**) Option "Device" "/dev/input/event22"
[    15.290] (**) Option "_source" "server/udev"
[    15.291] (II) event22 - SteelSeries SteelSeries KLC: is tagged by udev as: Keyboard
[    15.291] (II) event22 - SteelSeries SteelSeries KLC: device is a keyboard
[    15.291] (II) event22 - SteelSeries SteelSeries KLC: device removed
[    15.291] (II) libinput: SteelSeries SteelSeries KLC: needs a virtual subdevice
[    15.291] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:1038:1122.0005/input/input29/event22"
[    15.291] (II) XINPUT: Adding extended input device "SteelSeries SteelSeries KLC" (type: MOUSE, id 15)
[    15.291] (**) Option "AccelerationScheme" "none"
[    15.291] (**) SteelSeries SteelSeries KLC: (accel) selected scheme none/0
[    15.291] (**) SteelSeries SteelSeries KLC: (accel) acceleration factor: 2.000
[    15.291] (**) SteelSeries SteelSeries KLC: (accel) acceleration threshold: 4
[    15.292] (II) event22 - SteelSeries SteelSeries KLC: is tagged by udev as: Keyboard
[    15.292] (II) event22 - SteelSeries SteelSeries KLC: device is a keyboard
[    15.293] (II) config/udev: Adding input device CUST0001:00 06CB:CDAD Touchpad (/dev/input/event8)
[    15.293] (**) CUST0001:00 06CB:CDAD Touchpad: Applying InputClass "evdev touchpad catchall"
[    15.293] (**) CUST0001:00 06CB:CDAD Touchpad: Applying InputClass "libinput touchpad catchall"
[    15.293] (II) Using input driver 'libinput' for 'CUST0001:00 06CB:CDAD Touchpad'
[    15.293] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 28 paused 0
[    15.293] (**) CUST0001:00 06CB:CDAD Touchpad: always reports core events
[    15.293] (**) Option "Device" "/dev/input/event8"
[    15.293] (**) Option "_source" "server/udev"
[    15.294] (II) event8  - CUST0001:00 06CB:CDAD Touchpad: is tagged by udev as: Touchpad
[    15.296] (II) event8  - CUST0001:00 06CB:CDAD Touchpad: device is a touchpad
[    15.296] (II) event8  - CUST0001:00 06CB:CDAD Touchpad: device removed
[    15.296] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.2/i2c_designware.1/i2c-3/i2c-CUST0001:00/0018:06CB:CDAD.0001/input/input14/event8"
[    15.296] (II) XINPUT: Adding extended input device "CUST0001:00 06CB:CDAD Touchpad" (type: TOUCHPAD, id 16)
[    15.297] (**) Option "AccelerationScheme" "none"
[    15.297] (**) CUST0001:00 06CB:CDAD Touchpad: (accel) selected scheme none/0
[    15.297] (**) CUST0001:00 06CB:CDAD Touchpad: (accel) acceleration factor: 2.000
[    15.297] (**) CUST0001:00 06CB:CDAD Touchpad: (accel) acceleration threshold: 4
[    15.298] (II) event8  - CUST0001:00 06CB:CDAD Touchpad: is tagged by udev as: Touchpad
[    15.299] (II) event8  - CUST0001:00 06CB:CDAD Touchpad: device is a touchpad
[    15.300] (II) config/udev: Adding input device CUST0001:00 06CB:CDAD Touchpad (/dev/input/mouse0)
[    15.300] (II) No input driver specified, ignoring this device.
[    15.300] (II) This device may have been added with another device file.
[    15.300] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event11)
[    15.300] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event12)
[    15.300] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event13)
[    15.301] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event14)
[    15.301] (II) No input driver specified, ignoring this device.
[    15.301] (II) This device may have been added with another device file.
[    15.301] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event15)
[    15.301] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event16)
[    15.301] (II) config/udev: Adding input device gpio-keys (/dev/input/event6)
[    15.302] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[    15.302] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    15.302] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[    15.302] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[    15.302] (**) AT Translated Set 2 keyboard: Applying InputClass "Keyboard Defaults"
[    15.302] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[    15.302] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 29 paused 0
[    15.302] (**) AT Translated Set 2 keyboard: always reports core events
[    15.302] (**) Option "Device" "/dev/input/event4"
[    15.302] (**) Option "_source" "server/udev"
[    15.303] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    15.303] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[    15.304] (II) event4  - AT Translated Set 2 keyboard: device removed
[    15.304] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[    15.304] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 17)
[    15.304] (**) Option "xkb_model" "pc105"
[    15.304] (**) Option "xkb_layout" "us"
[    15.304] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    15.305] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    15.305] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[    15.306] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/event24)
[    15.306] (**) PS/2 Generic Mouse: Applying InputClass "evdev pointer catchall"
[    15.306] (**) PS/2 Generic Mouse: Applying InputClass "libinput pointer catchall"
[    15.306] (II) Using input driver 'libinput' for 'PS/2 Generic Mouse'
[    15.306] (II) systemd-logind: got fd for /dev/input/event24 13:88 fd 30 paused 0
[    15.306] (**) PS/2 Generic Mouse: always reports core events
[    15.306] (**) Option "Device" "/dev/input/event24"
[    15.306] (**) Option "_source" "server/udev"
[    15.308] (II) event24 - PS/2 Generic Mouse: is tagged by udev as: Mouse
[    15.308] (II) event24 - PS/2 Generic Mouse: device is a pointer
[    15.308] (II) event24 - PS/2 Generic Mouse: device removed
[    15.308] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input8/event24"
[    15.308] (II) XINPUT: Adding extended input device "PS/2 Generic Mouse" (type: MOUSE, id 18)
[    15.308] (**) Option "AccelerationScheme" "none"
[    15.308] (**) PS/2 Generic Mouse: (accel) selected scheme none/0
[    15.308] (**) PS/2 Generic Mouse: (accel) acceleration factor: 2.000
[    15.308] (**) PS/2 Generic Mouse: (accel) acceleration threshold: 4
[    15.309] (II) event24 - PS/2 Generic Mouse: is tagged by udev as: Mouse
[    15.309] (II) event24 - PS/2 Generic Mouse: device is a pointer
[    15.309] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/mouse2)
[    15.309] (II) No input driver specified, ignoring this device.
[    15.309] (II) This device may have been added with another device file.
[    15.309] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[    15.310] (II) config/udev: Adding input device MSI WMI hotkeys (/dev/input/event7)
[    15.310] (**) MSI WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[    15.310] (**) MSI WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[    15.310] (**) MSI WMI hotkeys: Applying InputClass "system-keyboard"
[    15.310] (**) MSI WMI hotkeys: Applying InputClass "Keyboard Defaults"
[    15.310] (II) Using input driver 'libinput' for 'MSI WMI hotkeys'
[    15.310] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 31 paused 0
[    15.310] (**) MSI WMI hotkeys: always reports core events
[    15.310] (**) Option "Device" "/dev/input/event7"
[    15.310] (**) Option "_source" "server/udev"
[    15.311] (II) event7  - MSI WMI hotkeys: is tagged by udev as: Keyboard
[    15.311] (II) event7  - MSI WMI hotkeys: device is a keyboard
[    15.311] (II) event7  - MSI WMI hotkeys: device removed
[    15.311] (**) Option "config_info" "udev:/sys/devices/virtual/input/input9/event7"
[    15.311] (II) XINPUT: Adding extended input device "MSI WMI hotkeys" (type: KEYBOARD, id 19)
[    15.311] (**) Option "xkb_model" "pc105"
[    15.311] (**) Option "xkb_layout" "us"
[    15.311] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    15.312] (II) event7  - MSI WMI hotkeys: is tagged by udev as: Keyboard
[    15.312] (II) event7  - MSI WMI hotkeys: device is a keyboard
[    15.318] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[    15.318] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[    15.318] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
[    15.318] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control: Applying InputClass "Keyboard Defaults"
[    15.318] (II) Using input driver 'libinput' for 'Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control'
[    15.318] (II) systemd-logind: returning pre-existing fd for /dev/input/event18 13:82
[    15.319] (**) Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control: always reports core events
[    15.319] (**) Option "Device" "/dev/input/event18"
[    15.319] (**) Option "_source" "_driver/libinput"
[    15.319] (II) libinput: Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control: is a virtual subdevice
[    15.319] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/0003:1B1C:1B74.0002/input/input25/event18"
[    15.319] (II) XINPUT: Adding extended input device "Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control" (type: KEYBOARD, id 20)
[    15.319] (**) Option "xkb_model" "pc105"
[    15.319] (**) Option "xkb_layout" "us"
[    15.319] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    15.319] (**) SteelSeries SteelSeries KLC: Applying InputClass "evdev keyboard catchall"
[    15.319] (**) SteelSeries SteelSeries KLC: Applying InputClass "libinput keyboard catchall"
[    15.319] (**) SteelSeries SteelSeries KLC: Applying InputClass "system-keyboard"
[    15.319] (**) SteelSeries SteelSeries KLC: Applying InputClass "Keyboard Defaults"
[    15.319] (II) Using input driver 'libinput' for 'SteelSeries SteelSeries KLC'
[    15.319] (II) systemd-logind: returning pre-existing fd for /dev/input/event22 13:86
[    15.319] (**) SteelSeries SteelSeries KLC: always reports core events
[    15.319] (**) Option "Device" "/dev/input/event22"
[    15.319] (II) libinput: SteelSeries SteelSeries KLC: is a virtual subdevice
[    15.319] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:1038:1122.0005/input/input29/event22"
[    15.319] (II) XINPUT: Adding extended input device "SteelSeries SteelSeries KLC" (type: KEYBOARD, id 21)
[    15.719] (II) intel(0): EDID vendor "AUO", prod id 33005
[    15.719] (II) intel(0): DDCModeFromDetailedTiming: 1920x1080 Warning: We only handle separate sync.
[    15.719] (II) intel(0): Printing DDC gathered Modelines:
[    15.719] (II) intel(0): Modeline "1920x1080"x0.0  368.14  1920 1968 2000 2102  1080 1090 1095 1216 -hsync -vsync (175.1 kHz eP)
[    15.719] (II) intel(0): Modeline "1920x1080"x0.0  368.14  1920 1968 2000 2102  1080 1090 1095 2915 -hsync -vsync (175.1 kHz e)
[   157.986] (**) Option "fd" "16"
[   157.986] (II) event3  - Power Button: device removed
[   157.986] (**) Option "fd" "19"
[   157.986] (II) event9  - Video Bus: device removed
[   157.986] (**) Option "fd" "20"
[   157.986] (II) event10 - Video Bus: device removed
[   157.986] (**) Option "fd" "21"
[   157.986] (II) event2  - Power Button: device removed
[   157.986] (**) Option "fd" "22"
[   157.986] (II) event1  - Sleep Button: device removed
[   157.986] (**) Option "fd" "23"
[   157.986] (II) event23 - HD Webcam: HD Webcam: device removed
[   157.986] (**) Option "fd" "24"
[   157.986] (II) event17 - Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse: device removed
[   157.986] (**) Option "fd" "25"
[   157.986] (**) Option "fd" "26"
[   157.986] (II) event21 - Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Keyboard: device removed
[   157.986] (**) Option "fd" "27"
[   157.986] (**) Option "fd" "28"
[   157.986] (II) event8  - CUST0001:00 06CB:CDAD Touchpad: device removed
[   157.986] (**) Option "fd" "29"
[   157.986] (II) event4  - AT Translated Set 2 keyboard: device removed
[   157.986] (**) Option "fd" "30"
[   157.986] (II) event24 - PS/2 Generic Mouse: device removed
[   157.987] (**) Option "fd" "31"
[   157.987] (II) event7  - MSI WMI hotkeys: device removed
[   157.987] (**) Option "fd" "25"
[   157.987] (II) event18 - Corsair CORSAIR GLAIVE RGB PRO Gaming Mouse Consumer Control: device removed
[   157.987] (**) Option "fd" "27"
[   157.987] (II) event22 - SteelSeries SteelSeries KLC: device removed
[   157.987] (II) UnloadModule: "libinput"
[   157.987] (II) systemd-logind: not releasing fd for 13:86, still in use
[   157.987] (II) systemd-logind: not releasing fd for 13:82, still in use
[   157.987] (II) systemd-logind: releasing fd for 13:71
[   158.064] (II) UnloadModule: "libinput"
[   158.064] (II) systemd-logind: releasing fd for 13:88
[   158.130] (II) UnloadModule: "libinput"
[   158.130] (II) systemd-logind: releasing fd for 13:68
[   158.170] (II) UnloadModule: "libinput"
[   158.170] (II) systemd-logind: releasing fd for 13:72
[   158.224] (II) UnloadModule: "libinput"
[   158.224] (II) systemd-logind: releasing fd for 13:86
[   158.250] (II) UnloadModule: "libinput"
[   158.250] (II) systemd-logind: releasing fd for 13:85
[   158.277] (II) UnloadModule: "libinput"
[   158.277] (II) systemd-logind: releasing fd for 13:82
[   158.317] (II) UnloadModule: "libinput"
[   158.317] (II) systemd-logind: releasing fd for 13:81
[   158.384] (II) UnloadModule: "libinput"
[   158.384] (II) systemd-logind: releasing fd for 13:87
[   158.450] (II) UnloadModule: "libinput"
[   158.450] (II) systemd-logind: releasing fd for 13:65
[   158.490] (II) UnloadModule: "libinput"
[   158.490] (II) systemd-logind: releasing fd for 13:66
[   158.530] (II) UnloadModule: "libinput"
[   158.530] (II) systemd-logind: releasing fd for 13:74
[   158.637] (II) UnloadModule: "libinput"
[   158.637] (II) systemd-logind: releasing fd for 13:73
[   158.704] (II) UnloadModule: "libinput"
[   158.704] (II) systemd-logind: releasing fd for 13:67
[   158.752] (II) Server terminated successfully (0). Closing log file.
[    99.585] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[    99.585] _XSERVTransMakeAllCOTSServerListeners: server already running
[    99.585] (--) Log file renamed from "/home/cinta/.local/share/xorg/Xorg.pid-2057.log" to "/home/cinta/.local/share/xorg/Xorg.1.log"
[    99.585] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[    99.586]
[    99.586] Build Operating System: Linux Arch Linux
[    99.586] Current Operating System: Linux Stealth 5.3.12-1-MANJARO #1 SMP PREEMPT Thu Nov 21 10:55:53 UTC 2019 x86_64
[    99.586] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.3-x86_64 root=UUID=8233b166-a6b9-40ba-9109-0ac1067af3a8 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[    99.586] Build Date: 27 October 2019  08:49:23AM
[    99.586]
[    99.586] Current version of pixman: 0.38.4
[    99.586] 	Before reporting problems, check http://wiki.x.org
[    99.586] Markers: (--) probed, (**) from config file, (==) default setting,
[    99.586] (==) Log file: "/home/cinta/.local/share/xorg/Xorg.1.log", Time: Tue Nov 26 20:58:20 2019
[    99.586] (==) Using config file: "/etc/X11/xorg.conf"
[    99.586] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    99.586] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    99.586] (==) ServerLayout "Layout0"
[    99.586] (**) |-->Screen "Screen0" (0)
[    99.586] (**) |   |-->Monitor "Monitor0"
[    99.586] (**) |   |-->Device "Device0"
[    99.586] (**) |   |-->GPUDevice "Device0"
[    99.586] (**) |-->Input Device "Keyboard0"
[    99.586] (**) |-->Input Device "Mouse0"
[    99.586] (==) Automatically adding devices
[    99.586] (==) Automatically enabling devices
[    99.586] (==) Automatically adding GPU devices
[    99.586] (==) Automatically binding GPU devices
[    99.586] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    99.586] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    99.586] 	Entry deleted from font path.
[    99.586] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    99.586] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[    99.586] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[    99.586] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[    99.587] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[    99.587] (==) FontPath set to:
[    99.587] (==) ModulePath set to "/usr/lib/xorg/modules"
[    99.587] (**) Extension "Composite" is enabled
[    99.587] (**) Extension "RENDER" is enabled
[    99.587] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[    99.587] (WW) Disabling Keyboard0
[    99.587] (WW) Disabling Mouse0
[    99.587] (II) Module ABI versions:
[    99.587] 	X.Org ANSI C Emulation: 0.4
[    99.587] 	X.Org Video Driver: 24.0
[    99.587] 	X.Org XInput driver : 24.1
[    99.587] 	X.Org Server Extension : 10.0
[    99.587] (++) using VT number 2
[    99.589] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_32
[    99.589] (II) xfree86: Adding drm device (/dev/dri/card0)
[    99.589] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 12 paused 0
[    99.591] (--) PCI:*(0@0:2:0) 8086:3e9b:1462:1274 rev 0, Mem @ 0xab000000/16777216, 0x40000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[    99.591] (--) PCI: (1@0:0:0) 10de:2191:1462:1274 rev 161, Mem @ 0xac000000/16777216, 0x80000000/268435456, 0x90000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[    99.591] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    99.591] (II) LoadModule: "glx"
[    99.591] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    99.592] (II) Module glx: vendor="X.Org Foundation"
[    99.592] 	compiled for 1.20.5, module version = 1.0.0
[    99.592] 	ABI class: X.Org Server Extension, version 10.0
[    99.592] (II) LoadModule: "intel"
[    99.592] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[    99.592] (II) Module intel: vendor="X.Org Foundation"
[    99.592] 	compiled for 1.20.5, module version = 2.99.917
[    99.592] 	Module class: X.Org Video Driver
[    99.592] 	ABI class: X.Org Video Driver, version 24.0
[    99.592] (II) LoadModule: "nvidia"
[    99.592] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    99.593] (II) Module nvidia: vendor="NVIDIA Corporation"
[    99.593] 	compiled for 1.6.99.901, module version = 1.0.0
[    99.593] 	Module class: X.Org Video Driver
[    99.593] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
[    99.593] (II) intel: Driver for Intel(R) HD Graphics
[    99.593] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[    99.593] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[    99.593] (II) NVIDIA dlloader X Driver  430.64  Sun Oct 27 11:10:43 UTC 2019
[    99.593] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    99.593] xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)
[    99.593] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20190619
[    99.593] (II) intel(0): SNA compiled from 2.99.917-893-gbff5eca4
[    99.610] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[    99.610] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics
[    99.610] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 6 threads
[    99.610] (**) intel(0): Depth 24, (--) framebuffer bpp 32
[    99.610] (==) intel(0): RGB weight 888
[    99.610] (==) intel(0): Default visual is TrueColor
[    99.610] (**) intel(0): Option "AccelMethod" "sna"
[    99.610] (**) intel(0): Option "DRI" "true"
[    99.611] (II) intel(0): Output eDP1 using monitor section Monitor0
[    99.611] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[    99.611] (II) intel(0): Enabled output eDP1
[    99.611] (II) intel(0): Output DP1 has no monitor section
[    99.611] (II) intel(0): Enabled output DP1
[    99.611] (II) intel(0): Output HDMI1 has no monitor section
[    99.611] (II) intel(0): Enabled output HDMI1
[    99.611] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[    99.611] (II) intel(0): Output VIRTUAL1 has no monitor section
[    99.611] (II) intel(0): Enabled output VIRTUAL1
[    99.611] (--) intel(0): Output eDP1 using initial mode 1920x1080 on pipe 0
[    99.612] (==) intel(0): TearFree disabled
[    99.612] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[    99.612] (==) intel(0): DPI set to (96, 96)
[    99.612] (II) Loading sub module "dri3"
[    99.612] (II) LoadModule: "dri3"
[    99.612] (II) Module "dri3" already built-in
[    99.612] (II) Loading sub module "dri2"
[    99.612] (II) LoadModule: "dri2"
[    99.612] (II) Module "dri2" already built-in
[    99.612] (II) Loading sub module "present"
[    99.612] (II) LoadModule: "present"
[    99.612] (II) Module "present" already built-in
[    99.612] (II) UnloadModule: "nvidia"
[    99.612] (II) Unloading nvidia
[    99.612] (II) intel(0): SNA initialized with Coffeelake (gen9) backend
[    99.612] (==) intel(0): Backing store enabled
[    99.612] (==) intel(0): Silken mouse disabled
[    99.612] (II) intel(0): HW Cursor enabled
[    99.612] (**) intel(0): DPMS enabled
[    99.612] (==) intel(0): Display hotplug detection enabled
[    99.612] (II) intel(0): [DRI2] Setup complete
[    99.612] (II) intel(0): [DRI2]   DRI driver: i965
[    99.612] (II) intel(0): [DRI2]   VDPAU driver: va_gl
[    99.612] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[    99.612] (II) intel(0): hardware support for Present enabled
[    99.612] (II) Initializing extension Generic Event Extension
[    99.612] (II) Initializing extension SHAPE
[    99.612] (II) Initializing extension MIT-SHM
[    99.612] (II) Initializing extension XInputExtension
[    99.612] (II) Initializing extension XTEST
[    99.612] (II) Initializing extension BIG-REQUESTS
[    99.612] (II) Initializing extension SYNC
[    99.612] (II) Initializing extension XKEYBOARD
[    99.612] (II) Initializing extension XC-MISC
[    99.612] (II) Initializing extension SECURITY
[    99.612] (II) Initializing extension XFIXES
[    99.612] (II) Initializing extension RENDER
[    99.612] (II) Initializing extension RANDR
[    99.612] (II) Initializing extension COMPOSITE
[    99.612] (II) Initializing extension DAMAGE
[    99.612] (II) Initializing extension MIT-SCREEN-SAVER
[    99.612] (II) Initializing extension DOUBLE-BUFFER
[    99.612] (II) Initializing extension RECORD
[    99.612] (II) Initializing extension DPMS
[    99.612] (II) Initializing extension Present
[    99.612] (II) Initializing extension DRI3
[    99.612] (II) Initializing extension X-Resource
[    99.612] (II) Initializing extension XVideo
[    99.612] (II) Initializing extension XVideo-MotionCompensation
[    99.612] (II) Initializing extension GLX
[    99.619] (II) AIGLX: Loaded and initialized i965
[    99.619] (II) GLX: Initialized DRI2 GL provider for screen 0
[    99.619] (II) Initializing extension XFree86-VidModeExtension
[    99.619] (II) Initializing extension XFree86-DGA
[    99.619] (II) Initializing extension XFree86-DRI
[    99.619] (II) Initializing extension DRI2
[    99.621] (II) intel(0): switch to mode 1920x1080@144.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[    99.622] (II) intel(0): Setting screen physical size to 508 x 285
[    99.645] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[    99.645] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    99.645] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    99.645] (**) Power Button: Applying InputClass "system-keyboard"
[    99.645] (**) Power Button: Applying InputClass "Keyboard Defaults"
[    99.645] (II) LoadModule: "libinput"
[    99.645] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    99.646] (II) Module libinput: vendor="X.Org Foundation"
[    99.646] 	compiled for 1.20.5, module version = 0.29.0
[    99.646] 	Module class: X.Org XInput Driver
[    99.646] 	ABI class: X.Org XInput driver, version 24.1
[    99.646] (II) Using input driver 'libinput' for 'Power Button'
[    99.647] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 17 paused 0
[    99.647] (**) Power Button: always reports core events
[    99.647] (**) Option "Device" "/dev/input/event3"
[    99.647] (**) Option "_source" "server/udev"
[    99.648] (II) event3  - Power Button: is tagged by udev as: Keyboard
[    99.648] (II) event3  - Power Button: device is a keyboard
[    99.648] (II) event3  - Power Button: device removed
[    99.648] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[    99.648] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    99.648] (**) Option "xkb_model" "pc105"
[    99.649] (**) Option "xkb_layout" "us"
[    99.649] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    99.663] (II) event3  - Power Button: is tagged by udev as: Keyboard
[    99.663] (II) event3  - Power Button: device is a keyboard
[    99.663] (II) config/udev: Adding input device Video Bus (/dev/input/event10)
[    99.663] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    99.663] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    99.663] (**) Video Bus: Applying InputClass "system-keyboard"
[    99.663] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[    99.663] (II) Using input driver 'libinput' for 'Video Bus'
[    99.664] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 20 paused 0
[    99.664] (**) Video Bus: always reports core events
[    99.664] (**) Option "Device" "/dev/input/event10"
[    99.664] (**) Option "_source" "server/udev"
[    99.665] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[    99.665] (II) event10 - Video Bus: device is a keyboard
[    99.665] (II) event10 - Video Bus: device removed
[    99.665] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input17/event10"
[    99.665] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    99.665] (**) Option "xkb_model" "pc105"
[    99.665] (**) Option "xkb_layout" "us"
[    99.665] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    99.666] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[    99.666] (II) event10 - Video Bus: device is a keyboard
[    99.666] (II) config/udev: Adding input device Video Bus (/dev/input/event11)
[    99.666] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    99.667] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    99.667] (**) Video Bus: Applying InputClass "system-keyboard"
[    99.667] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[    99.667] (II) Using input driver 'libinput' for 'Video Bus'
[    99.667] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 21 paused 0
[    99.667] (**) Video Bus: always reports core events
[    99.667] (**) Option "Device" "/dev/input/event11"
[    99.667] (**) Option "_source" "server/udev"
[    99.668] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[    99.668] (II) event11 - Video Bus: device is a keyboard
[    99.668] (II) event11 - Video Bus: device removed
[    99.668] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:13/LNXVIDEO:01/input/input18/event11"
[    99.668] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[    99.668] (**) Option "xkb_model" "pc105"
[    99.668] (**) Option "xkb_layout" "us"
[    99.668] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    99.669] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[    99.669] (II) event11 - Video Bus: device is a keyboard
[    99.670] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[    99.670] (II) No input driver specified, ignoring this device.
[    99.670] (II) This device may have been added with another device file.
[    99.670] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    99.670] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    99.670] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    99.670] (**) Power Button: Applying InputClass "system-keyboard"
[    99.670] (**) Power Button: Applying InputClass "Keyboard Defaults"
[    99.670] (II) Using input driver 'libinput' for 'Power Button'
[    99.671] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 22 paused 0
[    99.671] (**) Power Button: always reports core events
[    99.671] (**) Option "Device" "/dev/input/event2"
[    99.671] (**) Option "_source" "server/udev"
[    99.672] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    99.672] (II) event2  - Power Button: device is a keyboard
[    99.672] (II) event2  - Power Button: device removed
[    99.672] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2/event2"
[    99.672] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[    99.672] (**) Option "xkb_model" "pc105"
[    99.672] (**) Option "xkb_layout" "us"
[    99.672] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    99.673] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    99.673] (II) event2  - Power Button: device is a keyboard
[    99.673] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[    99.673] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    99.673] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[    99.673] (**) Sleep Button: Applying InputClass "system-keyboard"
[    99.673] (**) Sleep Button: Applying InputClass "Keyboard Defaults"
[    99.673] (II) Using input driver 'libinput' for 'Sleep Button'
[    99.674] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 23 paused 0
[    99.674] (**) Sleep Button: always reports core events
[    99.674] (**) Option "Device" "/dev/input/event1"
[    99.674] (**) Option "_source" "server/udev"
[    99.675] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[    99.675] (II) event1  - Sleep Button: device is a keyboard
[    99.675] (II) event1  - Sleep Button: device removed
[    99.675] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[    99.675] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[    99.675] (**) Option "xkb_model" "pc105"
[    99.675] (**) Option "xkb_layout" "us"
[    99.675] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    99.676] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[    99.676] (II) event1  - Sleep Button: device is a keyboard
[    99.677] (II) config/udev: Adding input device SteelSeries SteelSeries KLC (/dev/input/event9)
[    99.677] (**) SteelSeries SteelSeries KLC: Applying InputClass "evdev keyboard catchall"
[    99.677] (**) SteelSeries SteelSeries KLC: Applying InputClass "libinput keyboard catchall"
[    99.677] (**) SteelSeries SteelSeries KLC: Applying InputClass "system-keyboard"
[    99.677] (**) SteelSeries SteelSeries KLC: Applying InputClass "Keyboard Defaults"
[    99.677] (II) Using input driver 'libinput' for 'SteelSeries SteelSeries KLC'
[    99.677] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 24 paused 0
[    99.677] (**) SteelSeries SteelSeries KLC: always reports core events
[    99.677] (**) Option "Device" "/dev/input/event9"
[    99.677] (**) Option "_source" "server/udev"
[    99.678] (II) event9  - SteelSeries SteelSeries KLC: is tagged by udev as: Keyboard
[    99.679] (II) event9  - SteelSeries SteelSeries KLC: device is a keyboard
[    99.679] (II) event9  - SteelSeries SteelSeries KLC: device removed
[    99.679] (II) libinput: SteelSeries SteelSeries KLC: needs a virtual subdevice
[    99.679] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:1038:1122.0003/input/input13/event9"
[    99.679] (II) XINPUT: Adding extended input device "SteelSeries SteelSeries KLC" (type: MOUSE, id 11)
[    99.679] (**) Option "AccelerationScheme" "none"
[    99.679] (**) SteelSeries SteelSeries KLC: (accel) selected scheme none/0
[    99.679] (**) SteelSeries SteelSeries KLC: (accel) acceleration factor: 2.000
[    99.679] (**) SteelSeries SteelSeries KLC: (accel) acceleration threshold: 4
[    99.680] (II) event9  - SteelSeries SteelSeries KLC: is tagged by udev as: Keyboard
[    99.680] (II) event9  - SteelSeries SteelSeries KLC: device is a keyboard
[    99.681] (II) config/udev: Adding input device CUST0001:00 06CB:CDAD Touchpad (/dev/input/event8)
[    99.681] (**) CUST0001:00 06CB:CDAD Touchpad: Applying InputClass "evdev touchpad catchall"
[    99.681] (**) CUST0001:00 06CB:CDAD Touchpad: Applying InputClass "libinput touchpad catchall"
[    99.681] (II) Using input driver 'libinput' for 'CUST0001:00 06CB:CDAD Touchpad'
[    99.681] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 25 paused 0
[    99.681] (**) CUST0001:00 06CB:CDAD Touchpad: always reports core events
[    99.681] (**) Option "Device" "/dev/input/event8"
[    99.681] (**) Option "_source" "server/udev"
[    99.683] (II) event8  - CUST0001:00 06CB:CDAD Touchpad: is tagged by udev as: Touchpad
[    99.684] (II) event8  - CUST0001:00 06CB:CDAD Touchpad: device is a touchpad
[    99.684] (II) event8  - CUST0001:00 06CB:CDAD Touchpad: device removed
[    99.685] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.2/i2c_designware.1/i2c-3/i2c-CUST0001:00/0018:06CB:CDAD.0001/input/input15/event8"
[    99.685] (II) XINPUT: Adding extended input device "CUST0001:00 06CB:CDAD Touchpad" (type: TOUCHPAD, id 12)
[    99.686] (**) Option "AccelerationScheme" "none"
[    99.686] (**) CUST0001:00 06CB:CDAD Touchpad: (accel) selected scheme none/0
[    99.686] (**) CUST0001:00 06CB:CDAD Touchpad: (accel) acceleration factor: 2.000
[    99.686] (**) CUST0001:00 06CB:CDAD Touchpad: (accel) acceleration threshold: 4
[    99.687] (II) event8  - CUST0001:00 06CB:CDAD Touchpad: is tagged by udev as: Touchpad
[    99.689] (II) event8  - CUST0001:00 06CB:CDAD Touchpad: device is a touchpad
[    99.690] (II) config/udev: Adding input device CUST0001:00 06CB:CDAD Touchpad (/dev/input/mouse0)
[    99.690] (II) No input driver specified, ignoring this device.
[    99.690] (II) This device may have been added with another device file.
[    99.690] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event12)
[    99.690] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event13)
[    99.690] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event14)
[    99.690] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event15)
[    99.691] (II) No input driver specified, ignoring this device.
[    99.691] (II) This device may have been added with another device file.
[    99.691] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event16)
[    99.691] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event17)
[    99.691] (II) config/udev: Adding input device gpio-keys (/dev/input/event6)
[    99.692] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[    99.692] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    99.692] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[    99.692] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[    99.692] (**) AT Translated Set 2 keyboard: Applying InputClass "Keyboard Defaults"
[    99.692] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[    99.692] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 26 paused 0
[    99.692] (**) AT Translated Set 2 keyboard: always reports core events
[    99.692] (**) Option "Device" "/dev/input/event4"
[    99.692] (**) Option "_source" "server/udev"
[    99.693] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    99.693] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[    99.694] (II) event4  - AT Translated Set 2 keyboard: device removed
[    99.694] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[    99.694] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 13)
[    99.694] (**) Option "xkb_model" "pc105"
[    99.694] (**) Option "xkb_layout" "us"
[    99.694] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    99.695] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    99.695] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[    99.695] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/event18)
[    99.695] (**) PS/2 Generic Mouse: Applying InputClass "evdev pointer catchall"
[    99.695] (**) PS/2 Generic Mouse: Applying InputClass "libinput pointer catchall"
[    99.695] (II) Using input driver 'libinput' for 'PS/2 Generic Mouse'
[    99.696] (II) systemd-logind: got fd for /dev/input/event18 13:82 fd 27 paused 0
[    99.696] (**) PS/2 Generic Mouse: always reports core events
[    99.696] (**) Option "Device" "/dev/input/event18"
[    99.696] (**) Option "_source" "server/udev"
[    99.697] (II) event18 - PS/2 Generic Mouse: is tagged by udev as: Mouse
[    99.697] (II) event18 - PS/2 Generic Mouse: device is a pointer
[    99.697] (II) event18 - PS/2 Generic Mouse: device removed
[    99.697] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input7/event18"
[    99.697] (II) XINPUT: Adding extended input device "PS/2 Generic Mouse" (type: MOUSE, id 14)
[    99.697] (**) Option "AccelerationScheme" "none"
[    99.697] (**) PS/2 Generic Mouse: (accel) selected scheme none/0
[    99.697] (**) PS/2 Generic Mouse: (accel) acceleration factor: 2.000
[    99.697] (**) PS/2 Generic Mouse: (accel) acceleration threshold: 4
[    99.698] (II) event18 - PS/2 Generic Mouse: is tagged by udev as: Mouse
[    99.698] (II) event18 - PS/2 Generic Mouse: device is a pointer
[    99.698] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/mouse1)
[    99.698] (II) No input driver specified, ignoring this device.
[    99.699] (II) This device may have been added with another device file.
[    99.699] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[    99.699] (II) No input driver specified, ignoring this device.
[    99.699] (II) config/udev: Adding input device MSI WMI hotkeys (/dev/input/event7)
[    99.699] (**) MSI WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[    99.699] (**) MSI WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[    99.699] (**) MSI WMI hotkeys: Applying InputClass "system-keyboard"
[    99.699] (**) MSI WMI hotkeys: Applying InputClass "Keyboard Defaults"
[    99.699] (II) Using input driver 'libinput' for 'MSI WMI hotkeys'
[    99.700] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 28 paused 0
[    99.700] (**) MSI WMI hotkeys: always reports core events
[    99.700] (**) Option "Device" "/dev/input/event7"
[    99.700] (**) Option "_source" "server/udev"
[    99.700] (II) event7  - MSI WMI hotkeys: is tagged by udev as: Keyboard
[    99.700] (II) event7  - MSI WMI hotkeys: device is a keyboard
[    99.700] (II) event7  - MSI WMI hotkeys: device removed
[    99.700] (**) Option "config_info" "udev:/sys/devices/virtual/input/input9/event7"
[    99.700] (II) XINPUT: Adding extended input device "MSI WMI hotkeys" (type: KEYBOARD, id 15)
[    99.700] (**) Option "xkb_model" "pc105"
[    99.700] (**) Option "xkb_layout" "us"
[    99.700] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    99.701] (II) event7  - MSI WMI hotkeys: is tagged by udev as: Keyboard
[    99.701] (II) event7  - MSI WMI hotkeys: device is a keyboard
[    99.705] (**) SteelSeries SteelSeries KLC: Applying InputClass "evdev keyboard catchall"
[    99.705] (**) SteelSeries SteelSeries KLC: Applying InputClass "libinput keyboard catchall"
[    99.705] (**) SteelSeries SteelSeries KLC: Applying InputClass "system-keyboard"
[    99.705] (**) SteelSeries SteelSeries KLC: Applying InputClass "Keyboard Defaults"
[    99.705] (II) Using input driver 'libinput' for 'SteelSeries SteelSeries KLC'
[    99.705] (II) systemd-logind: returning pre-existing fd for /dev/input/event9 13:73
[    99.705] (**) SteelSeries SteelSeries KLC: always reports core events
[    99.705] (**) Option "Device" "/dev/input/event9"
[    99.705] (**) Option "_source" "_driver/libinput"
[    99.705] (II) libinput: SteelSeries SteelSeries KLC: is a virtual subdevice
[    99.705] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:1038:1122.0003/input/input13/event9"
[    99.705] (II) XINPUT: Adding extended input device "SteelSeries SteelSeries KLC" (type: KEYBOARD, id 16)
[    99.705] (**) Option "xkb_model" "pc105"
[    99.705] (**) Option "xkb_layout" "us"
[    99.705] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    99.952] (II) intel(0): EDID vendor "AUO", prod id 33005
[    99.952] (II) intel(0): DDCModeFromDetailedTiming: 1920x1080 Warning: We only handle separate sync.
[    99.952] (II) intel(0): Printing DDC gathered Modelines:
[    99.952] (II) intel(0): Modeline "1920x1080"x0.0  368.14  1920 1968 2000 2102  1080 1090 1095 1216 -hsync -vsync (175.1 kHz eP)
[    99.952] (II) intel(0): Modeline "1920x1080"x0.0  368.14  1920 1968 2000 2102  1080 1090 1095 2915 -hsync -vsync (175.1 kHz e)
[   211.410] (**) Option "fd" "17"
[   211.410] (II) event3  - Power Button: device removed
[   211.410] (**) Option "fd" "20"
[   211.410] (II) event10 - Video Bus: device removed
[   211.410] (**) Option "fd" "21"
[   211.410] (II) event11 - Video Bus: device removed
[   211.410] (**) Option "fd" "22"
[   211.410] (II) event2  - Power Button: device removed
[   211.410] (**) Option "fd" "23"
[   211.410] (II) event1  - Sleep Button: device removed
[   211.410] (**) Option "fd" "24"
[   211.410] (**) Option "fd" "25"
[   211.410] (II) event8  - CUST0001:00 06CB:CDAD Touchpad: device removed
[   211.410] (**) Option "fd" "26"
[   211.410] (II) event4  - AT Translated Set 2 keyboard: device removed
[   211.410] (**) Option "fd" "27"
[   211.410] (II) event18 - PS/2 Generic Mouse: device removed
[   211.410] (**) Option "fd" "28"
[   211.410] (II) event7  - MSI WMI hotkeys: device removed
[   211.410] (II) event9  - SteelSeries SteelSeries KLC: device removed
[   211.410] (II) UnloadModule: "libinput"
[   211.410] (II) systemd-logind: not releasing fd for 13:73, still in use
[   211.410] (II) systemd-logind: releasing fd for 13:71
[   211.443] (II) UnloadModule: "libinput"
[   211.443] (II) systemd-logind: releasing fd for 13:82
[   211.534] (II) UnloadModule: "libinput"
[   211.534] (II) systemd-logind: releasing fd for 13:68
[   211.553] (II) UnloadModule: "libinput"
[   211.553] (II) systemd-logind: releasing fd for 13:72
[   211.636] (II) UnloadModule: "libinput"
[   211.637] (II) systemd-logind: releasing fd for 13:73
[   211.653] (II) UnloadModule: "libinput"
[   211.653] (II) systemd-logind: releasing fd for 13:65
[   211.700] (II) UnloadModule: "libinput"
[   211.700] (II) systemd-logind: releasing fd for 13:66
[   211.720] (II) UnloadModule: "libinput"
[   211.720] (II) systemd-logind: releasing fd for 13:75
[   211.770] (II) UnloadModule: "libinput"
[   211.770] (II) systemd-logind: releasing fd for 13:74
[   211.803] (II) UnloadModule: "libinput"
[   211.803] (II) systemd-logind: releasing fd for 13:67
[   211.837] (WW) xf86CloseConsole: KDSETMODE failed: Input/output error
[   211.837] (WW) xf86CloseConsole: VT_GETMODE failed: Input/output error
[   211.837] (WW) xf86CloseConsole: VT_ACTIVATE failed: Input/output error
[   211.860] (II) Server terminated successfully (0). Closing log file.```
This is a week old log.
Post the terminal output from the commands
No VIRTUAL outputs on ":0".
Are you running on Wayland? If so, disregard the rest of my post... :sob:
I have absolutely no experience with wayland...
Please post
optirun inxi -Gxxxaz
optirun xrandr
grep -v ^# /etc/bumblebee/bumblebee.conf
grep -v ^# /etc/bumblebee/xorg.conf.nvidia
systemctl status bumblebeed   --no-pager
journalctl -b -g "bbswitch|bumble"  --no-pager --no-hostname
for p in /sys/class/drm/*/status; do con=${p%/status}; echo -n "${con#*/card?-}: "; cat $p; done
Note to support team
I'll post them as soon as I get back on my computer, but can you tell me what are you looking for?
Some web search suggests specific conf settings in bumblebee conf files.
Complicated issue, as deprecated is bumblebee.
You may read the link I posted, but not follow blindly, unless you know what you are doing and can revert changes easily.
  Device-1: Intel UHD Graphics 630 vendor: Micro-Star MSI driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:3e9b
  Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Micro-Star MSI
  driver: nvidia v: 430.64 bus ID: 01:00.0 chip ID: 10de:2191
  Display: wayland server: X.Org 1.20.5 driver: intel unloaded: modesetting
  alternate: fbdev,vesa compositor: gnome-shell v: 3.34.1
  resolution: 1920x1080~144Hz
  OpenGL: renderer: GeForce GTX 1660 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 430.64
  direct render: Yes
optirun xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 8192 x 8192
XWAYLAND0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 340mm x 190mm
   1920x1080    143.88*+
[bumblebeed]
VirtualDisplay=:8
KeepUnusedXServer=true
ServerGroup=bumblebee
TurnCardOffAtExit=false
NoEcoModeOverride=false
Driver=nvidia
XorgConfDir=/etc/bumblebee/xorg.conf.d
XorgBinary=Xorg
[optirun]
Bridge=auto
VGLTransport=proxy
PrimusLibraryPath=/usr/lib/primus:/usr/lib32/primus
AllowFallbackToIGC=false
[driver-nvidia]
KernelDriver=nvidia
PMMethod=auto
LibraryPath=/usr/lib/nvidia:/usr/lib32/nvidia:/usr/lib:/usr/lib32
XorgModulePath=/usr/lib/nvidia/xorg,/usr/lib/xorg/modules
XorgConfFile=/etc/bumblebee/xorg.conf.nvidia
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
XorgConfFile=/etc/bumblebee/xorg.conf.nouveau
Section "ServerLayout"
    Identifier "Layout0"
    #Option "AutoAddDevices" "false"
EndSection
Section "Device"
    Identifier  "Device1"
    Driver      "nvidia"
    BusID       "PCI:1:0:0"
    VendorName "NVIDIA Corporation"
    Option "NoLogo" "true"
    #Option "UseEDID" "false"
    Option "ConnectedMonitor" "DFP"
EndSection
● bumblebeed.service - Bumblebee C Daemon
   Loaded: loaded (/usr/lib/systemd/system/bumblebeed.service; enabled; vendor preset: disabled)
   Active: active (running) since Mon 2019-12-02 19:43:47 AST; 52min ago
 Main PID: 879 (bumblebeed)
    Tasks: 2 (limit: 4915)
   Memory: 62.7M
   CGroup: /system.slice/bumblebeed.service
           ├─ 879 /usr/bin/bumblebeed --use-syslog
           └─5336 /usr/lib/Xorg :8 -config /etc/bumblebee/xorg.conf.nvidia -configd…
dic 02 19:43:47 Stealth systemd[1]: Started Bumblebee C Daemon.
dic 02 19:43:47 Stealth bumblebeed[879]: /usr/bin/bumblebeed 3.2.1-2017-02-27-F…rted
dic 02 20:35:38 Stealth bumblebeed[879]: [XORG] (WW) `fonts.dir' not found (or …pi".
dic 02 20:35:38 Stealth bumblebeed[879]: [XORG] (WW) Open ACPI failed (/var/run…ory)
dic 02 20:35:38 Stealth bumblebeed[879]: [XORG] (WW) NVIDIA(0): Option "NoLogo"…used
Hint: Some lines were ellipsized, use -l to show in full.
-- Logs begin at Thu 2019-11-21 00:12:17 AST, end at Mon 2019-12-02 20:36:04 AST. --
dic 02 19:43:47 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bumblebeed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
dic 02 19:43:47 systemd[1]: Started Bumblebee C Daemon.
dic 02 19:43:47 kernel: bbswitch: version 0.8
dic 02 19:43:47 kernel: bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
dic 02 19:43:47 kernel: bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.PEGP
dic 02 19:43:47 kernel: bbswitch: detected an Optimus _DSM function
dic 02 19:43:47 kernel: bbswitch: disabling discrete graphics
dic 02 19:43:47 kernel: bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is off
dic 02 19:43:47 bumblebeed[879]: /usr/bin/bumblebeed 3.2.1-2017-02-27-Format:%h$ started
dic 02 20:35:37 kernel: bbswitch: enabling discrete graphics
DP-1: disconnected
eDP-1: connected
HDMI-A-1: disconnected
I quit!! :rofl:
You are on your own! :running_man:
or someone else may help... and I'll watch, so I learn more!!
:sweat_smile::sweat_smile::joy:
