After booting, I am presented with the usual login screen however, there is no login prompt. I can move the mouse, check the calendar and use the GUI to shutdown again.
Using ctr+alt + f-keys makes the screen freeze until I come back to F1.
I had the same problem yesterday, figured it might have been a bad update after some time or just something I broke and reinstalled. Worked as it should yesterday, same problem this morning. Any ideas?
Thanks @Mirdarthos
I got a bunch of usb read errors in the log and after some testing it seems like my front usb is broken. If there is anything plugged in there, I get no login prompt.
