my gnome menu just happened to stay like this after update, how can I solve that?, I tried to remove all the themes, including icon and shell, tried the command dconf reset -f /org/gnome/
, deleted gtk files from gtk-3.0 and gtk-4.0 folder, but the problem persist, also tried to turn off ALL extensions, problem happens in wayland and xorg
You have to set Shell (theme) to default with “Tweaks” tool.
But as you have delete/reset I’m not sure why it has not set itself to Default Theme?
thanks for your reply, mate, I already tried this
Reinstall Gnome Shell?
I reinstalled the entire gnome environment and it worked fine, thank you for you answer mate! It helped me a lot!
How did you reinstall it?
Try this first:
sudo pacman -S manjaro-gnome-settings manjaro-settings-manager
If that fails then:
sudo pacman -S gnome
And option “All”.
