I will hold off on trying to solve the problem until full Gnome 40 is implemented. Ever since Gnome 40 apps were installed I randomly loose access to my Intel AX200 wifi pcie card. In the Gnome menu the wifi options is not seen and I have no internet access. I Shutdown the machine fully, then start the computer and it might be there or not. When it’s there wifi works like it always worked before. This card worked absolutely reliably before before update.
Also my bluetooth connection to speakers ever 5 minutes drops out and reconnects after a few seconds then works fine again for 5-10 minutes and the cycle repeats. Bluetooth is on the same PCIE card. Since I can get it working half the time I boot up I will not try to solve it until until Gnome 40 is fully implemented. Just making people aware of the problem.
Welcome to Manjaro!
- Please read this:
How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies… - An
would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
P.S. Your profile mentioned 5.10 RC5 which doesn’t exist any more so please update that?
Here is the output of the command. Interestingly enough this a dual boot system and transferring files in Windows 10 on this machine is at 1GB/s or roughly 112 Mb/s (maxing out my 1Gb cable connection from router to access point) and 28 Mb/s on Manajro, but I think this is a separate issue. I think wifi disappearing happens more after I boot into Windows. Not sure, I rarely use Windows.
Kernel: 5.10.30-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.10-x86_64
root=UUID=58189e2c-8a29-40d1-95b7-cbcb181272b1 rw rootflags=subvol=@ quiet
Desktop: GNOME 3.38.4 tk: GTK 3.24.28 wm: gnome-shell dm: GDM 40.0
Type: Desktop Mobo: ASUSTeK model: X79-DELUXE v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 4805 date: 02/02/2016
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M525
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Solar Keyboard K750
serial: <filter> charge: 100% rechargeable: yes status: Full
RAM: total: 31.3 GiB used: 2.24 GiB (7.2%)
Array-1: capacity: 96 GiB slots: 8 EC: None max-module-size: 12 GiB
note: est.
Device-1: ChannelA_Dimm1 size: 4 GiB speed: 1600 MT/s type: DDR3
detail: synchronous bus-width: 64 bits total: 64 bits manufacturer: Kingston
part-no: KHX1600C9D3/4GX serial: <filter>
Device-2: ChannelA_Dimm2 size: 4 GiB speed: 1600 MT/s type: DDR3
Device-3: ChannelB_Dimm1 size: 4 GiB speed: 1600 MT/s type: DDR3
Device-4: ChannelB_Dimm2 size: 4 GiB speed: 1600 MT/s type: DDR3
Device-5: ChannelC_Dimm1 size: 4 GiB speed: 1600 MT/s type: DDR3
Device-6: ChannelC_Dimm2 size: 4 GiB speed: 1600 MT/s type: DDR3
Device-7: ChannelD_Dimm1 size: 4 GiB speed: 1600 MT/s type: DDR3
Device-8: ChannelD_Dimm2 size: 4 GiB speed: 1600 MT/s type: DDR3
Info: 6-Core model: Intel Core i7-4930K socket: LGA2011 bits: 64
type: MT MCP arch: Ivy Bridge family: 6 model-id: 3E (62) stepping: 4
microcode: 42E cache: L1: 32 KiB L2: 12 MiB L3: 12 MiB bogomips: 81648
Speed: 1350 MHz min/max: 1200/3900 MHz base/boost: 3400/4000 volts: 1.0 V
ext-clock: 100 MHz Core speeds (MHz): 1: 1350 2: 1540 3: 1399 4: 3404
5: 2120 6: 3404 7: 2757 8: 3403 9: 2132 10: 3169 11: 2249 12: 3403
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 dca de ds_cpl dtes64 dtherm dts epb
ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: NVIDIA GK104 [GeForce GTX 770] vendor: eVga.com. driver: nvidia
v: 460.67 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1184
class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 2-1.4:5 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: gnome-shell driver:
loaded: nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x572mm (40.0x22.5")
s-diag: 1166mm (45.9")
Monitor-1: DP-1 res: 3840x2160 hz: 60 dpi: 157 size: 621x341mm (24.4x13.4")
diag: 708mm (27.9")
OpenGL: renderer: GeForce GTX 770/PCIe/SSE2 v: 4.6.0 NVIDIA 460.67
direct render: Yes
Device-1: Intel C600/X79 series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1d20
class-ID: 0403
Device-2: NVIDIA GK104 HDMI Audio vendor: eVga.com. driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e0a class-ID: 0403
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.10.30-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.25 running: no
Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe
driver: e1000e v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1503
class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel modules: wl
port: d000 bus-ID: 09:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp9s0 state: up mac: <filter>
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK driver: r8168 v: 8.048.03-NAPI modules: r8169 port: c000
bus-ID: 0a:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp10s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-1.6:3 chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter>
Local Storage: total: 1.86 TiB used: 392.96 GiB (20.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 1TB
rotation: SSD serial: <filter> rev: BB6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Intel model: SSDSC2BP480G4
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 0420 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 500GB
rotation: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: Ultra
size: 57.28 GiB block-size: physical: 512 B logical: 512 B serial: <filter>
rev: 1.00 scheme: MBR
ID-1: / raw-size: 447.03 GiB size: 447.03 GiB (100.00%)
used: 392.96 GiB (87.9%) fs: btrfs block-size: 4096 B dev: /dev/sdb2
maj-min: 8:18 label: N/A uuid: 58189e2c-8a29-40d1-95b7-cbcb181272b1
ID-2: /boot/efi raw-size: 105 MiB size: 103.4 MiB (98.45%)
used: 806 KiB (0.8%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
label: N/A uuid: E2EB-910A
ID-3: /home raw-size: 447.03 GiB size: 447.03 GiB (100.00%)
ID-1: /dev/sda1 maj-min: 8:1 size: 450 MiB fs: ntfs label: Recovery
uuid: C28EEDC18EEDADDB
ID-2: /dev/sda2 maj-min: 8:2 size: 100 MiB fs: vfat label: N/A
uuid: 2E01-9AF3
ID-3: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-4: /dev/sda4 maj-min: 8:4 size: 930.12 GiB fs: ntfs label: N/A
uuid: C492045E92045778
ID-5: /dev/sda5 maj-min: 8:5 size: 860 MiB fs: ntfs label: N/A
uuid: 0E60790D6078FCB1
ID-6: /dev/sdc1 maj-min: 8:33 size: 465.76 GiB fs: ntfs label: Projects
uuid: AECA03A9CA036D41
ID-7: /dev/sdd1 maj-min: 8:49 size: 2.89 GiB fs: iso9660
label: MANJARO_KDE_202 uuid: 2020-12-07-13-36-18-00
ID-8: /dev/sdd2 maj-min: 8:50 size: 4 MiB fs: vfat label: MISO_EFI
uuid: EC08-A711
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.6:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.2:3 info: Wacom ACK-40401 [Wireless Accessory Kit] type: HID
driver: usbhid,wacom interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 98mA
chip-ID: 056a:0084 class-ID: 0300
Device-2: 2-1.3:4 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-3: 2-1.4:5 info: Logitech Webcam C270 type: Video,Audio
power: 500mA chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Device-4: 2-1.7:6 info: SanDisk Ultra type: Mass Storage driver: usb-storage
interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 224mA chip-ID: 0781:5581
class-ID: 0806 serial: <filter>
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-7: 5-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub-8: 5-1:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
speed: 480 Mb/s power: 100mA chip-ID: 174c:2074 class-ID: 0900
Device-1: 5-1.3:3 info: Cyber Power System CP1500 AVR UPS type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 2mA
chip-ID: 0764:0501 class-ID: 0300 serial: <filter>
Hub-9: 6-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.0 speed: 5 Gb/s
Hub-10: 6-1:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s power: 8mA chip-ID: 174c:3074 class-ID: 0900
Hub-11: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-12: 8-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-13: 9-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-14: 10-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0
speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 21.0 C mobo: N/A gpu: nvidia temp: 37 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 41%
Processes: 345 Uptime: 2m wakeups: 5 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1976 lib: 476
flatpak: 0 Shell: Bash (su) v: 5.1.0 running-in: gnome-terminal inxi: 3.3.04
You might have a issue with hardware being claimed by windows that persists between boots. More here.
If this is true, this would also explain the wifi app not behaving as expected and you should cold boot from Windows to Manjaro…
5.10 is the very newest LTS kernel. Have you tried the most robust one (5.4) yet
Turned it off and after rebooting from windows it seems to work. Will see if it helps with reboots between Manjaro which is what I mostly use. Thanks for advice.
Good idea, will try different kernel.
Went back to 5.10 as the problem is there but now only happens about 20% of the time. Most times I boot and reboot it works 80% of the time. The Bluetooth still kicks out every 15 minutes for half a minute.
Turned off fast boot, but this happens between Manajro reboots. Seems to be less after using windows so i think it helped. Thanks
Have you tried cold booting yet??? (especially if you come from Windows in a dual boot)
Yes, that does solve the problem. I turn off the computer using the switch on the power supply.
Yeah, so I’ve marked this answer as the solution to your question as it is by far the best answer you’ll get.
Because:
- What is happening is that the Windows drivers leave the UEFI system in an unpredictable state when you warm boot.
- Windows solves this by hardware resetting individual components in its drivers at boot time.
- Linux plays nice and takes whatever UEFI gives it (and why we regularly have to tell people to upgrade their UEFI Firmware because of known bugs)
- This is a known issue and is called a side effect
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
I will test it out for a couple of weeks, but I do agree. I will also wait until full Gnome 40 rolls out. Situation has seemed to have gotten much better.
