Gnome layout switcher settings and reload button errors
Gnome layout switcher settings Automatic Dark Theme and Pop Shell when enabled don’t work and don’t show in system tray.
And when I click Reload, shows a window to logout (?)
Someone have the same problem?
That’s not related to Layouts. What exactly are you referrring to?
It’s a known issue. For now install gnome-shell-extension-pop-shell from Add / Remove Software manually.
On a Wayland session, one must logout / login for Extension changes to take effect.
Thank you, Yochanan!
I refer to -
Ah, forgot about that. :laughing: The Automatic dark theme option uses the Night Theme Switcher Extension. If you already have a light theme set during the day or dark theme set at night, you won’t notice anything happening.
Also, might this be another case of extension not being installed by default? :thinking:
Thank you, Chrysostomus!
Why have you marked @Chrysostomus’s post as the solution? What solved your issue exactly?
