I updated my install today and am unable to log-in through gdm. When access tty, I also can only log-in as root. Any other user will give me an “incorrect login” error.
You should be aware that if you enter the password as part of the command it will be stored in the history file e.g. .bash_history - in clear text.
The correct method is to create the user - then assign a password using the passwd command - use the --expire to force the user to change the password on login
That won’t work - you need an encrypted value
$ man useradd
-p, --password PASSWORD
defines an initial password for the account. PASSWORD is expected
to be encrypted, as returned by crypt (3). Within a shell script,
this option allows to create efficiently batches of users.
Without this option, the new account will be locked and with no
password defined, i.e. a single exclamation mark in the respective
field of /etc/shadow. This is a state where the user won't be able
to access the account or to define a password himself.
Note:Avoid this option on the command line because the password
(or encrypted password) will be visible by users listing the
processes.
You should make sure the password respects the system's password
policy.
You can use openssl to create the password.
$ openssl passwd --help
Usage: passwd [options] [password]
General options:
-help Display this summary
Input options:
-in infile Read passwords from file
-noverify Never verify when reading password from terminal
-stdin Read passwords from stdin
Output options:
-quiet No warnings
-table Format output as table
-reverse Switch table columns
Cryptographic options:
-salt val Use provided salt
-6 SHA512-based password algorithm
-5 SHA256-based password algorithm
-apr1 MD5-based password algorithm, Apache variant
-1 MD5-based password algorithm
-aixmd5 AIX MD5-based password algorithm
Random state options:
-rand val Load the given file(s) into the random number generator
-writerand outfile Write random data to the specified file
Provider options:
-provider-path val Provider load path (must be before 'provider' argument if required)
-provider val Provider to load (can be specified multiple times)
-propquery val Property query used when fetching algorithms
Parameters:
password Password text to digest (optional)
With the above warning in mind …
openssl passwd -6 123
you could use it as part the useradd command like this
