Welcome!
Manjaro 23.1.2 Unstable
For this machine, do you recommend 6.1 LTS or rather 6.6 LTS kernel?
I-5 8600 CPU with IGP 8 GB DDR4 RAM
(I can’t show inxi output because I’m on another machine.)
Hi @growler,
I always suggest the latest LTS. However, I personally use 6.1 LTS because my wake-up from suspend doesn’t work properly in anything else I’ve tested so far.
So, as you can see it depends on which works best for you…
Edit:
Add to that that kernel 6.1 is to be maintained for 10 years, I’d say that is a good option, then.
See
…about that.
Thank you very much!
That leaves 6.1 (for now)
