I see this problem particularly with Lutris, so not sure if it’s with only this or a broader issue.
Put simply, I have to deselect and reselect GTK themes every PC startup to apply it correctly to Lutris; even the default themes preinstalled do the same. I’ve had issues with my re-installation of KDE since my previous black screen and this is one of the problems I have, which leads to my second issue.
Dolpin Add-on services don’t install through the installer; the manual method works, somewhat, but they don’t run as they initially used to (i.e root actions and iso mount). For example, mounted ISOs never appear as a removable device or have a “unmount” option (I even have to click “show hidden places” in Dolphin so they appear). Could be an issue with the add-on itself or Dolphin, but I have zero clue.
I’m putting both as one topic, just in case if it’s a sign of a bigger issue with my KDE install or a few hiccups. Would prefer it to be the latter so another reinstall isn’t necessary, but we’ll see.
(This pic is the problem I have every PC startup)
(When I select a different theme, it works and I can then reselect my original theme. This is how I want it to look when it works)
