Gnome going lock screen and switching monitor off after some inactivity
Hey there,
for some time already the lock-screen and screen turning off mechanism has been behaving irregular. There are 3 types of behaviors I could observe over time:
1:
After some time the lock screen is being shown and the screen goes blank, monitors go in sleep mode.
2:
After some time the lock screen is being shown and the screen goes blank, monitors don’t go in sleep mode.
3:
The lock screen is never been shown after some time, desktop is keep being shown
Case 1 is the expected behavior, rarely case 2 happens, and usually case 3 is more often the wrong behavior.
Currently the system only stays in case 3 and I can’t figure out what the issue here is. I did not mess around with any settings concerning this behavior. I did some reinstalling of some packages like vulkan or nvidia-drivers and installing some applications.
System Info:
  Kernel: 6.1.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
    root=UUID=97edd2bb-94d6-46d3-a872-5fc965ae2865 rw rootflags=subvol=@ quiet
    splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: GNOME v: 44.5 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
  Type: Desktop Mobo: ASRock model: Z370 Extreme4 serial: <superuser required>
    UEFI: American Megatrends v: P4.20 date: 10/31/2019
  Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 min/max: 800/4700 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 88824
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: Gigabyte
    driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-09) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:1e07 class-ID: 0300
  Device-2: Microsoft Microsoft LifeCam HD-5001
    driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
    mode: 2.0 bus-ID: 1-11:8 chip-ID: 045e:076e class-ID: 0102
  Display: x11 server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.1
    compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
    screens: 1
  Screen-1: 0 s-res: 5560x1920 s-size: <missing: xdpyinfo>
  Monitor-1: DP-1 pos: left res: 1080x1920 hz: 60 dpi: 82
    size: 336x598mm (13.23x23.54") diag: 686mm (27.01") modes: N/A
  Monitor-2: DP-2 pos: primary,center res: 2560x1440 hz: 60 dpi: 93
    size: 697x392mm (27.44x15.43") diag: 800mm (31.48") modes: N/A
  Monitor-3: DP-4 pos: right res: 1920x1080 hz: 60 dpi: 81
    size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
  Monitor-4: HDMI-0 size-res: N/A modes: N/A
  API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
  API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2
    memory: 10.74 GiB
  API: Vulkan v: 1.3.264 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 2080 Ti driver: nvidia v: 535.113.01 device-ID: 10de:1e07
    surfaces: xcb,xlib
  Device-1: Intel 200 Series PCH HD Audio vendor: ASRock driver: snd_hda_intel
    v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0 class-ID: 0403
  Device-2: NVIDIA TU102 High Definition Audio vendor: Gigabyte
    bus-ID: 01:00.1 chip-ID: 10de:10f7 class-ID: 0403
  Device-3: Microsoft Microsoft LifeCam HD-5001
  Device-4: SteelSeries ApS Arctis 7 driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:3
    chip-ID: 1038:12ad class-ID: 0300
  Device-5: Focusrite-Novation Focusrite Scarlett 2i2 2nd Gen
    driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 1-8:5 chip-ID: 1235:8202 class-ID: 0102
  API: ALSA v: k6.1.55-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.80 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
  Device-2: Ralink MT7610U (Archer T2U 2.4G+5G WLAN Adapter driver: mt76x0u
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2:2
    chip-ID: 148f:761a class-ID: 0000 serial: <filter>
  IF: wlp5s0u2 state: up mac: <filter>
  Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f020
    bus-ID: 00:17.0 chip-ID: 8086:2822 rev: class-ID: 0104
  Local Storage: total: 9.08 TiB used: 1.2 TiB (13.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup
    model: T-FORCE TM8FP7002T size: 1.82 TiB block-size: physical: 512 B
    fw-rev: EGFM15.2 temp: 45.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 960 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3B7QCXE7 temp: 39.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ABA300
    size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 5940 serial: <filter> fw-rev: ABB0 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3000DM008-2DM166
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC26 scheme: GPT
  ID-5: /dev/sdc maj-min: 8:32 vendor: SanDisk model: SSD PLUS 480GB
    size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 04RL scheme: GPT
  ID-6: /dev/sdd maj-min: 8:48 vendor: SanDisk model: SSD PLUS 1000GB
    size: 931.52 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 00RL scheme: GPT
  ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 472.06 GiB (25.3%)
    fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 612 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
    used: 472.06 GiB (25.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-4: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
  ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -2
    file: /swap
  System Temperatures: cpu: 34.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 423 Uptime: 20m wakeups: 1 Memory: total: 16 GiB
  available: 15.55 GiB used: 6.03 GiB (38.8%) Init: systemd v: 254
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
  clang: 16.0.6 Packages: 1737 pm: pacman pkgs: 1713 libs: 463
  tools: gnome-software,pamac pm: flatpak pkgs: 24 Shell: Zsh v: 5.9
  running-in: gnome-terminal inxi: 3.3.30
