Hello,
I have a laptop with a builtin screen. When I boot, everything works fine. When I boot and afterwards plug in a second monitor with an HDMI-cable, everything still works fine and as expected. However, when the monitor is already connected before Gnome starts running, then Gnome fails to load.
I have an Nvidia graphics card and an Intel CPU. I already installed optimus-manager and gdm-prime. I set it up to use the nvidia profile by default. I also made sure to run X11 instead of Wayland sessions.
I did all that in the past, when my secondary monitor wouldn’t work at all.
What I find especially strange about this problem is that it occurs, even when the second monitor isn’t connected to an electricity outlet.
Thank you for just linking those two things. I don’t know if you meant it condescending, but it certainly comes across like it.
Anyways, about providing additional information: no, sadly I cannot do that. I don’t know which information about my system might be helpful in this situation, nor how to acquire it. I don’t know if there are log files or anything and if there are, I don’t know where they are located. I agree though that I could have written that in my first post.
These are links to tutorials on how to provide the needed information.
Please follow the links in my post, and you will get info about:
- What info is desired
- How to get this info
- How to post it
This way anyone who might be able to help you can have a look at the infos, and decide what might help in your case
There are different DEs, graphic cards … Good to know before trying to help. There are about 10 different kernels arround …
I am sorry, but I couldn’t find which information is desired for this particular problem. I found the post about using inxi, so I can post the output of that, but I couldn’t find an “in case of problems with HDMI, please also provide…”.
So, the inxi output:
Kernel: 5.10.89-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=c79f2610-2055-4434-9096-ead1b6a1a453 rw quiet splash apparmor=1
security=apparmor resume=UUID=aba05aa6-0b44-4171-a6a0-0e0c651abe18
udev.log_priority=3
Desktop: GNOME 41.2 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.0
Type: Laptop System: TUXEDO product: TUXEDO v: N/A
serial: <superuser required> Chassis: Notebook type: 10
Mobo: TUXEDO model: NH5x_7xEDx,RCx,RDx serial: <superuser required>
UEFI: INSYDE v: 1.07.14RTR1 date: 10/08/2019
ID-1: BAT0 charge: 45.0 Wh (100.0%) condition: 45.0/48.0 Wh (93.6%)
volts: 16.3 min: 14.4 model: Notebook BAT type: Li-ion serial: <filter>
status: Full
RAM: total: 15.35 GiB used: 5.33 GiB (34.7%)
RAM Report:
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 3908 high: 3998 min/max: 800/4100 scaling:
driver: intel_pstate governor: performance cores: 1: 3983 2: 3989 3: 3997
4: 3989 5: 3989 6: 3892 7: 3266 8: 3996 9: 3980 10: 3998 11: 3982 12: 3843
bogomips: 52815
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: CLEVO/KAPOK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: CLEVO/KAPOK
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f11 class-ID: 0300
Device-3: Acer BisonCam NB Pro type: USB driver: uvcvideo bus-ID: 1-8:6
chip-ID: 5986:9102 class-ID: 0e02
Display: x11 server: X.org 1.21.1.2 compositor: gnome-shell driver:
loaded: modesetting,nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA 495.44
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f9
class-ID: 0403
Device-3: Logitech G430 Surround Sound Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2.3:7 chip-ID: 046d:0a4d
class-ID: 0300
Sound Server-1: ALSA v: k5.10.89-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: no
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel bus-ID: 08:00.0
chip-ID: 8086:2526 class-ID: 0280
IF: wlp8s0 state: down mac: <filter>
vendor: CLEVO/KAPOK driver: r8169 v: kernel port: 3000 bus-ID: 09:00.1
IF: enp9s0f1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-14:8 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 2.27 TiB used: 956.9 GiB (41.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SanDisk model: Ultra 3D NVMe
lanes: 4 type: SSD serial: <filter> rev: 211070WD temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO M.2 500GB
type: SSD serial: <filter> rev: 3B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-1: / raw-size: 166.02 GiB size: 162.41 GiB (97.83%)
used: 80.6 GiB (49.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: c79f2610-2055-4434-9096-ead1b6a1a453
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: E7E1-F0A6
ID-3: /home/<filter>/Games raw-size: 748.32 GiB size: 735.51 GiB (98.29%)
used: 620.76 GiB (84.4%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: N/A uuid: 6c2d9636-97e6-4d9b-8e8b-85bfe27992d1
ID-4: /home/<filter>/Lagerhaus raw-size: 667.79 GiB
size: 667.79 GiB (100.00%) used: 167.74 GiB (25.1%) fs: ntfs dev: /dev/sdb5
maj-min: 8:21 label: N/A uuid: 2ACB4A19349C1530
ID-5: /run/timeshift/backup raw-size: 224.61 GiB size: 220.08 GiB (97.99%)
used: 87.8 GiB (39.9%) fs: ext4 dev: /dev/sdb4 maj-min: 8:20 label: N/A
uuid: 1bb9218c-3b73-4b4d-a8d4-25bde9862590
ID-1: swap-1 type: partition size: 16.88 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: aba05aa6-0b44-4171-a6a0-0e0c651abe18
ID-1: /dev/sda1 maj-min: 8:1 size: 579 MiB fs: ntfs label: System-reserviert
uuid: 084EAC684EAC4FEC
ID-2: /dev/sda2 maj-min: 8:2 size: 465.1 GiB fs: ntfs label: N/A
uuid: 527EB0F97EB0D6C7
ID-3: /dev/sda3 maj-min: 8:3 size: 100 MiB fs: vfat label: N/A
uuid: E489-3185
ID-4: /dev/sdb1 maj-min: 8:17 size: 50 MiB fs: vfat label: N/A
uuid: 55FB-ABE5
ID-5: /dev/sdb2 maj-min: 8:18 size: 19.53 GiB fs: ext4 label: N/A
uuid: 783c8b14-d941-43d5-a2b0-e35779587d88
ID-6: /dev/sdb3 maj-min: 8:19 size: 19.53 GiB fs: vfat label: N/A
uuid: CC2D-9A2C
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-1:2 info: Logitech F310 Gamepad [XInput Mode]
type: <vendor specific> driver: xpad interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 046d:c21d class-ID: ff00 serial: <filter>
Hub-2: 1-2:3 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-2.1:5 info: SINOWEALTH Speedlink Sovos Gaming Mouse
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 480mA chip-ID: 258a:0024 class-ID: 0301
Device-2: 1-2.3:7 info: Logitech G430 Surround Sound Gaming Headset
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 046d:0a4d class-ID: 0300
Device-3: 1-2.4:15 info: Razer USA BlackWidow Tournament Edition Stealth
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 1532:011c class-ID: 0300
Device-4: 1-3:4 info: Chrontel Billboard type: Billboard driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 200mA chip-ID: 0639:7213
class-ID: 1100 serial: <filter>
Device-5: 1-8:6 info: Acer BisonCam NB Pro type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:9102
class-ID: 0e02
Device-6: 1-14:8 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Hub-3: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 61.0 C pch: 65.0 C mobo: N/A gpu: nvidia
temp: 53 C
Processes: 347 Uptime: 10h 40m wakeups: 1 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1551 pacman: 1538 lib: 466
flatpak: 13 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.11
As for other additional information, as said I had other problem with Gnome, Nvidia and Optimus-Manager once, so I am currently suspecting that one. I followed the instructions for Gnome from this link. GitHub - Askannz/optimus-manager: A Linux program to handle GPU switching on Optimus laptops. So because I did that, I am not sure if that is actually the issue.
