Hi,
After the update to newer kernel versions 5.7 or 5.8 gnome crashes after opening any program. Thus, as soon as I click on any application, may it be from the panel or applications menu, a window open animation appears, but the window never appears, instead the mouse hangs and I can not interact with gnome anymore. Also the open terminal shortcut doesn’t work.
What I already tried:
- Change Theme -> no success
- Disable all extensions -> no success
- Move back to kernel 5.4 -> all good,
might be related to https ://forum.manjaro.org/t/gnome-hangs-after-opening-certain-programs/16836 only that I have no NVIDIA card
from that post it might seem helpful to have the following info:
$inxi -Fxza --no-host
System: Kernel: 5.8.3-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=8216afb1-d930-4ab4-ad0d-051744e04357 rw quiet apparmor=1
security=apparmor resume=UUID=e4f8bf79-161f-4f5b-8d86-c15f51915c74 udev.log_priority=3
Console: tty 1 DM: GDM 3.36.3 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASRock model: B85M-ITX serial: <filter> UEFI [Legacy]: American Megatrends v: P2.50
date: 01/07/2016
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400 serial: <filter>
charge: 50% (should be ignored) rechargeable: yes status: N/A
CPU: Topology: Dual Core model: Intel Pentium G3240 bits: 64 type: MCP arch: Haswell family: 6 model-id: 3C (60)
stepping: 3 microcode: 28 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 12403
Speed: 1768 MHz min/max: 800/3100 MHz Core speeds (MHz): 1: 1344 2: 1246
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics vendor: ASRock driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:0402
Display: server: X.org 1.20.8 compositor: gnome-shell driver: intel unloaded: modesetting alternate: fbdev,vesa
tty: 140x73
Message: Advanced graphics data unavailable in console. Try -G --display
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
bus ID: 00:03.0 chip ID: 8086:0c0c
Sound Server: ALSA v: k5.8.3-2-MANJARO
Network: Device-1: Intel 82574L Gigabit Network driver: e1000e v: 3.2.6-k port: e000 bus ID: 01:00.0 chip ID: 8086:10d3
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 3.87 TiB used: 3.22 TiB (83.4%)
ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: 1B6Q scheme: MBR
ID-2: /dev/sdb vendor: Seagate model: ST4000DM000-1F2168 size: 3.64 TiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: 5900 rpm serial: <filter> rev: CC54 scheme: GPT
Partition: ID-1: / raw size: 225.29 GiB size: 220.75 GiB (97.99%) used: 103.20 GiB (46.8%) fs: ext4 dev: /dev/sda1
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 7.60 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2
Sensors: System Temperatures: cpu: 37.0 C mobo: N/A
Info: Processes: 164 Uptime: 12m Memory: 7.44 GiB used: 588.5 MiB (7.7%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1284 lib: 387 flatpak: 0 Shell: Bash v: 5.0.18 running in: tty 1 (SSH) inxi: 3.1.05
$XDG_SESSION_TYPE
prints x11
dmesg -l emerg,alert,crit,err,warn output after starting an application on kernel 5.8
[ 0.657673] ata1.00: supports DRM functions and may not be fully accessible
[ 0.658186] ata1.00: NCQ Send/Recv Log not supported
[ 0.659506] ata1.00: supports DRM functions and may not be fully accessible
[ 0.659974] ata1.00: NCQ Send/Recv Log not supported
[ 4.084208] ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000187F (\PMIO) (20200528/utaddress-204)
[ 4.084219] ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR2) (20200528/utaddress-204)
[ 4.084222] ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20200528/utaddress-204)
[ 4.084224] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR2) (20200528/utaddress-204)
[ 4.084226] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20200528/utaddress-204)
[ 4.084231] ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20200528/utaddress-204)
[ 4.084233] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR2) (20200528/utaddress-204)
[ 4.084238] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20200528/utaddress-204)
[ 4.084239] ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20200528/utaddress-204)
[ 5.108899] kauditd_printk_skb: 14 callbacks suppressed
[ 16.004808] kauditd_printk_skb: 22 callbacks suppressed
[ 29.695400] ------------[ cut here ]------------
[ 29.695405] WARNING: CPU: 0 PID: 1249 at kernel/sched/core.c:4576 default_wake_function+0x16/0x30
[ 29.695406] Modules linked in: fuse hid_logitech_hidpp joydev mousedev input_leds rfkill hid_logitech_dj squashfs loop snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel i915 kvm snd_hda_intel ofpart cmdlinepart irqbypass intel_spi_platform crct10dif_pclmul crc32_pclmul intel_spi snd_intel_dspcfg i2c_algo_bit ghash_clmulni_intel at24 snd_hda_codec drm_kms_helper spi_nor mei_hdcp mei_wdt cryptd iTCO_wdt mtd intel_pmc_bxt iTCO_vendor_support rapl intel_cstate snd_hda_core intel_uncore snd_hwdep i2c_i801 cec pcspkr i2c_smbus snd_pcm rc_core intel_gtt snd_timer syscopyarea mei_me e1000e snd mei sysfillrect sysimgblt fb_sys_fops soundco[ 29.695434] Code: e8 ef 8c 3e 00 eb 99 0f 0b 66 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 f7 c2 fe ff ff ff 75 09 48 8b 7f 08 e9 0a f9[ 29.695436] RAX: ffffffffae4e4a40 RBX: ffffacdc80a93d30 RCX: ffffacdc80c8fe08
[ 29.695436] RDX: 00000000fffffffb RSI: 0000000000000003 RDI: ffffacdc80a93d30
[ 29.695437] RBP: ffff960ef01ebd68 R08: 0000000000000000 R09: 0000000000000001
[ 29.695518] signal_irq_work+0x23e/0x350 [i915]
[ 29.695523] irq_work_single+0x2c/0x40
[ 29.695526] ? asm_sysvec_irq_work+0xa/0x20
[ 29.695527] irq_work_run_list+0x2d/0x40
[ 29.695528] irq_work_run+0x26/0x40
[ 29.695530] __sysvec_irq_work+0x2d/0xf0
[ 29.695533] sysvec_irq_work+0x41/0xe0
[ 29.695534] ? asm_sysvec_irq_work+0xa/0x20
[ 29.695536] asm_sysvec_irq_work+0x12/0x20
[ 29.695537] RIP: 0033:0x7f6037f8025a
[ 29.695539] Code: 00 00 75 05 48 83 c4 18 c3 e8 b2 f7 01 00 66 90 f3 0f 1e fa 41 89 f8 48 89 f7 48 89 d6 41 83 f8 01 77 2d b8 04 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 06 c3 0f 1f 44 00 00 48 8b 15 e1 1b 0d 00 f7
[ 29.695539] RSP: 002b:00007ffc2c2e7fb8 EFLAGS: 00000246
[ 29.695540] RAX: 0000000000000000 RBX: 000056384d2bee70 RCX: 00007f6037f8025a
[ 29.695541] RDX: 00007ffc2c2e7fc0 RSI: 00007ffc2c2e7fc0 RDI: 00007ffc2c2e8070
[ 29.695541] RBP: 00007ffc2c2e8130 R08: 0000000000000001 R09: 61702d7962663278
[ 29.695542] R10: 63706632785c6874 R11: 0000000000000246 R12: 000056384d272de0
[ 29.695542] R13: 000056384d272de0 R14: 000056384d2b0cb0 R15: 0000000000000000
[ 29.695545] ---[ end trace e5a24f9c0fb72850 ]---
[ 41.780566] ------------[ cut here ]------------
[ 41.780578] WARNING: CPU: 0 PID: 0 at kernel/sched/core.c:2470 ttwu_queue_wakelist+0xc2/0xd0
[ 41.780580] Modules linked in: fuse hid_logitech_hidpp joydev mousedev input_leds rfkill hid_logitech_dj squashfs loop snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel i915 kvm snd_hda_intel ofpart cmdlinepart irqbypass intel_spi_platform crct10dif_pclmul crc32_pclmul intel_spi snd_intel_dspcfg i2c_algo_bit ghash_clmulni_intel at24 snd_hda_codec drm_kms_helper spi_nor mei_hdcp mei_wdt cryptd iTCO_wdt mtd intel_pmc_bxt iTCO_vendor_support rapl intel_cstate snd_hda_core intel_uncore snd_hwdep i2c_i801 cec pcspkr i2c_smbus snd_pcm rc_core intel_gtt snd_timer syscopyarea mei_me e1000e snd mei sysfillrect sysimgblt fb_sys_fops soundco
re lpc_ich evdev mac_hid drm uinput sg crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 hid_generic usbhid hid sr_mod crc32c_intel cdrom ehci_pci ehci_hcd xhci_pci xhci_pci_renesas xhci_hcd
[ 41.780649] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W 5.8.3-2-MANJARO #1
[ 41.780651] Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./B85M-ITX, BIOS P2.50 01/07/2016
[ 41.780656] RIP: 0010:ttwu_queue_wakelist+0xc2/0xd0
[ 41.780660] Code: 02 83 e1 f7 83 e0 01 c1 e0 03 09 c8 88 83 c4 04 00 00 c7 42 68 01 00 00 00 e8 ba f3 07 00 b8 01 00 00 00 5b 5d 41 5c 41 5d c3 <0f> 0b 31 c0 eb 90 0f 1f 84 00 00 00 00 00 55 48 89 e5 41 57 49 89
[ 41.780663] RSP: 0018:ffffacdc80003e28 EFLAGS: 00010046
[ 41.780667] RAX: 0000000000000000 RBX: ffff960f11f6bb00 RCX: ffff960f16600000
[ 41.780669] RDX: 000000000002c340 RSI: ffffffffaf7744c2 RDI: ffffffffaf754331
[ 41.780671] RBP: 00000000ffffffff R08: 00000009ba50c446 R09: 0000000000000000
[ 41.780673] R10: 0000000000000006 R11: 0000000000000005 R12: 0000000000000000
[ 41.780676] R13: 0000000000000000 R14: ffff960f11f6c2ac R15: 000000000002c340
[ 41.780679] FS: 0000000000000000(0000) GS:ffff960f16600000(0000) knlGS:0000000000000000
[ 41.780682] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 41.780684] CR2: 000056384d245088 CR3: 000000020840a004 CR4: 00000000000606f0
[ 41.780687] Call Trace:
[ 41.780691] <IRQ>
[ 41.780701] try_to_wake_up+0x1b2/0x620
[ 41.780711] autoremove_wake_function+0xe/0x30
[ 41.780790] __i915_sw_fence_complete+0x156/0x1b0 [i915]
[ 41.780854] dma_i915_sw_fence_wake_timer+0x2c/0x50 [i915]
[ 41.780884] signal_irq_work+0x23e/0x350 [i915]
[ 41.780890] irq_work_single+0x2c/0x40
[ 41.780893] irq_work_run_list+0x2d/0x40
[ 41.780894] irq_work_run+0x26/0x40
[ 41.780898] __sysvec_irq_work+0x2d/0xf0
[ 41.780902] asm_call_on_stack+0x12/0x20
[ 41.780903] </IRQ>
[ 41.780906] sysvec_irq_work+0xa8/0xe0
[ 41.780909] asm_sysvec_irq_work+0x12/0x20
[ 41.780912] RIP: 0010:cpuidle_enter_state+0xb6/0x420
[ 41.780914] Code: 20 97 41 51 e8 db 5b 8d ff 49 89 c7 0f 1f 44 00 00 31 ff e8 0c 6a 8d ff 80 7c 24 0f 00 0f 85 06 02 00 00 fb 66 0f 1f 44 00 00 <45> 85 e4 0f 88 e9 01 00 00 49 63 d4 4c 2b 7c 24 10 48 8d 04 52 48
[ 41.780915] RSP: 0018:ffffffffafa03e40 EFLAGS: 00000246
[ 41.780916] RAX: ffff960f16600000 RBX: ffff960f16636738 RCX: 000000000000001f
[ 41.780917] RDX: 0000000000000000 RSI: ffffffffaf7744c2 RDI: ffffffffaf754331
[ 41.780918] RBP: ffffffffafaca1a0 R08: 00000009ba4fcfde R09: 0000000000000018
[ 41.780919] R10: 000000000000266c R11: 0000000000001d77 R12: 0000000000000004
[ 41.780919] R13: ffff960f16636738 R14: 0000000000000004 R15: 00000009ba4fcfde
[ 41.780925] cpuidle_enter+0x29/0x40
[ 41.780928] do_idle+0x1fb/0x2c0
[ 41.780932] cpu_startup_entry+0x19/0x20
[ 41.780935] start_kernel+0x85b/0x880
[ 41.780939] secondary_startup_64+0xb6/0xc0
[ 41.780943] ---[ end trace e5a24f9c0fb72851 ]---
[ 58.295510] kauditd_printk_skb: 2 callbacks suppressed
Please any advice?
