Hello,
Not entirely sure this is exactly the right section, but here is the problem I have:
I’m using XFCE4-power-manager to manage the power settings on a Manjaro awesome edition (XFCE4-power-manager is just the default, really). My icon theme is Papirus-Dark-Maia, which should give me a nice white battery icon (which I checked with the icon browser, GitHub - v1cont/yad: Yet Another Dialog). However, the power manager uses a dark icon instead, which, given that the background is dark as well, gives a barely visible outline. As far as I can tell it’s the icon from Papirus-Light-Maia or Papirus.
This has been going on for a long while already, but it never bothered me before since my laptop was mostly plugged in. Now it isn’t anymore, though, so I’d like to actually see the icon, and I thought I just needed to change the icon in the theme but I realized the icon shouldn’t be the one I see. Now, though, I’d appreciate any help in figuring out why this happens and how to fix it.
Thanks in advance!
In case it is relevant, the output from inxi -Fazy
Kernel: 5.10.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=26505fa8-bb0c-4ae5-9de4-c22a5dcfa957 rw quiet apparmor=1
Desktop: Xfce 4.16.2 wm: awesome 4.3 dm: LightDM 1.30.0
Distro: Manjaro Linux
Type: Laptop System: Dell product: Inspiron 15 5501 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 06TT8N v: A00 serial: <filter> UEFI: Dell v: 1.5.3
date: 12/18/2020
ID-1: BAT0 charge: 53.0 Wh condition: 53.0/53.0 Wh (100%) volts: 17.0/15.0
model: SMP DELL 9077G07 type: Li-poly serial: <filter> status: Full
Info: Quad Core model: Intel Core i7-1065G7 bits: 64 type: MT MCP
arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: A0
L2 cache: 8 MiB
bogomips: 23968
Speed: 1900 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 1900 2: 1900
3: 1900 4: 570 5: 1900 6: 1900 7: 1900 8: 1603
Device-1: Intel Iris Plus Graphics G7 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:8a52 class ID: 0300
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 3-6:2 chip ID: 0bda:565a class ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: compton driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel Iris Plus Graphics (ICL GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel Smart Sound Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:34c8
class ID: 0403
Sound Server: ALSA v: k5.10.19-1-MANJARO
Device-1: Intel Killer Wi-Fi 6 AX1650i 160MHz Wireless Network Adapter
driver: iwlwifi v: kernel port: 3000 bus ID: 00:14.3 chip ID: 8086:34f0
class ID: 0280
Device-1: Intel type: USB driver: btusb v: 0.8 bus ID: 3-10:3
chip ID: 8087:0026 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 476.94 GiB used: 294.7 GiB (61.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KBG40ZNS512G NVMe KIOXIA 512GB size: 476.94 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: 10410104 temp: 39.9 C scheme: GPT
ID-1: / raw size: 99.5 GiB size: 97.44 GiB (97.93%) used: 57.35 GiB (58.9%)
fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /boot/efi raw size: 512 MiB size: 511 MiB (99.80%)
used: 308 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p9 maj-min: 259:9
System Temperatures: cpu: 82.0 C mobo: N/A
Fan Speeds (RPM): cpu: 4132
Processes: 251 Uptime: 3h 32m wakeups: 18792 Memory: 15.41 GiB
used: 4.39 GiB (28.5%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.1.0 Packages: pacman: 2014 lib: 448 flatpak: 0 Shell: Zsh v: 5.8
running in: xfce4-terminal inxi: 3.3.01
