I’m new to Manjaro set up on my also new Lenovo ThinkCentre. I’m seeing some stability issues mostly related to coming back from hibernation, but I also had cases of the system freezing during use. Sometimes REISUB works to gracefully reboot, sometimes it doesn’t.
I already tried to disable all extensions prior to hibernating and then enabling them again once the system is up again.
While writing this message, I actually have the system in a state where certain programs, like “System Monitor” won’t open at all anymore. I just get:
“System Monitor” is not responding
and choosing wait doesn’t do anything - I have to force quit.
This also applies to certain console commands, like “inxi -Fayz” isn’t doing anything. Just sitting there until I terminate it via CTRL-C.
That prompted me to look into journalctl where since my last reboot on May 26 i see these errors with the “journalctl -p 3 -xb” command:
Mai 26 06:06:16 ThinkCentre kernel: tpm tpm0: [Firmware Bug]: TPM interrupt not working, polling instead
Mai 26 06:06:16 ThinkCentre kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Mai 26 06:06:17 ThinkCentre kernel: ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x000000002) is beyond end of object (length 0x2) (20210730/exoparg2-393)
Mai 26 06:06:17 ThinkCentre kernel: ACPI Error: Aborting method \WMI1.WQA0 due to previous error (AE_AML_PACKAGE_LIMIT) (20210730/psparse-529)
Mai 26 06:06:19 ThinkCentre gnome-session-binary[940]: GLib-GIO-CRITICAL: g_bus_get_sync: assertion 'error == NULL || *error == NULL' failed
Mai 26 06:06:23 ThinkCentre nmbd[1312]: [2022/05/26 06:06:23.415124, 0] ../../source3/nmbd/nmbd.c:901(main)
Mai 26 06:06:23 ThinkCentre nmbd[1312]: nmbd version 4.16.1 started.
Mai 26 06:06:23 ThinkCentre nmbd[1312]: Copyright Andrew Tridgell and the Samba Team 1992-2022
Mai 26 06:06:23 ThinkCentre smbd[1313]: [2022/05/26 06:06:23.452276, 0] ../../source3/smbd/server.c:1741(main)
Mai 26 06:06:23 ThinkCentre smbd[1313]: smbd version 4.16.1 started.
Mai 26 06:06:23 ThinkCentre smbd[1313]: Copyright Andrew Tridgell and the Samba Team 1992-2022
Mai 26 06:06:33 ThinkCentre gdm-password][1317]: gkr-pam: unable to locate daemon control file
Mai 26 06:06:41 ThinkCentre systemd[1332]: Failed to start Application launched by gnome-session-binary.
░░ Subject: A start job for unit UNIT has failed
░░ Defined-By: systemd
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 480 and the job result is failed.
Mai 26 06:06:43 ThinkCentre gdm-launch-environment][903]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Mai 26 06:17:42 ThinkCentre kernel: sd 0:0:0:0: [sda] No Caching mode page found
Mai 26 06:17:42 ThinkCentre kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Mai 26 08:14:28 ThinkCentre sudo[22386]: pam_unix(sudo:auth): conversation failed
Mai 26 08:14:28 ThinkCentre sudo[22386]: pam_unix(sudo:auth): auth could not identify password for [rain]
Mai 27 06:00:37 ThinkCentre systemd[1]: Failed to start pkgfile database update.
░░ Subject: A start job for unit pkgfile-update.service has failed
░░ A start job for unit pkgfile-update.service has finished with a failure.
░░ The job identifier is 4396 and the job result is failed.
Mai 27 06:00:37 ThinkCentre nmbd[1312]: [2022/05/27 06:00:37.431896, 0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mai 27 06:00:37 ThinkCentre nmbd[1312]: Packet send failed to 192.168.188.255(137) ERRNO=Network is unreachable
Mai 27 06:00:37 ThinkCentre nmbd[1312]: [2022/05/27 06:00:37.457946, 0] ../../source3/nmbd/nmbd_packets.c:180(send_netbios_packet)
Mai 27 06:00:37 ThinkCentre nmbd[1312]: send_netbios_packet: send_packet() to IP 192.168.188.255 port 137 failed
Mai 27 06:00:37 ThinkCentre nmbd[1312]: [2022/05/27 06:00:37.459178, 0] ../../source3/nmbd/nmbd_namequery.c:245(query_name)
Mai 27 06:00:37 ThinkCentre nmbd[1312]: query_name: Failed to send packet trying to query name WORKGROUP<1d>
Mai 27 06:00:37 ThinkCentre nmbd[1312]: [2022/05/27 06:00:37.460945, 0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mai 27 06:00:37 ThinkCentre nmbd[1312]: Packet send failed to 192.168.188.255(138) ERRNO=Network is unreachable
Mai 27 06:00:37 ThinkCentre nmbd[1312]: [2022/05/27 06:00:37.467262, 0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mai 27 06:00:37 ThinkCentre nmbd[1312]: [2022/05/27 06:00:37.467370, 0] ../../source3/nmbd/nmbd_packets.c:180(send_netbios_packet)
Mai 27 06:00:37 ThinkCentre nmbd[1312]: [2022/05/27 06:00:37.467383, 0] ../../source3/nmbd/nmbd_namequery.c:245(query_name)
Mai 27 06:00:37 ThinkCentre nmbd[1312]: [2022/05/27 06:00:37.468386, 0] ../../source3/nmbd/nmbd.c:359(reload_interfaces)
Mai 27 06:00:37 ThinkCentre nmbd[1312]: reload_interfaces: No subnets to listen to. Waiting..
Mai 27 06:00:43 ThinkCentre systemd-coredump[82181]: Process 23321 (gnome-calendar) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id a6913678db0cce9811d35c782542decae1d16452
Module librsvg-2.so.2 with build-id 8c033bf594f51f48c7b2ee078fa4586ddb70513a
Module libpixbufloader-svg.so with build-id b496e4f240c3dd862a5fe9ad31a464e65692cc08
Module libgioremote-volume-monitor.so with build-id b32824d1334e43af0033456180017669e3a7dd2b
Module libcamelimapx.so with build-id cb3728cfd709dcaeef9a05d0dd2c28b847af882d
Module libcamelpop3.so with build-id 99627371b554c902f43add97f44aed24d03d57db
Module libcamelsmtp.so with build-id d0d77b4f177c7698f8bc72e43f4e9a4f968dc269
Module libcamellocal.so with build-id 1b95196b38c1e4a9cdc1480409fb4a1b38e1d4b6
Module libcamelnntp.so with build-id d9fe703713048860e4418d4b332aeeacf5170e98
Module libcamelsendmail.so with build-id 94cc52bcc6f17aaa267922df1d280a9a167d6bd8
Module libgvfscommon.so with build-id 5c6df2952527d8d19cfb9ba14ceb290a15d186f8
Module libgvfsdbus.so with build-id 2529d3764be816acfea14bd80db2c56c2cb7f024
Module libvulkan.so.1 with build-id 198212a538d4e3b290530d75a0614e803b03d39e
Module libdrm_nouveau.so.2 with build-id af8afb2331ac08c52132102ecbdc6076a8eb4c6f
Module libdrm_amdgpu.so.1 with build-id 8eb3977b830f3012d9ead7b4def5f4d2f38ec688
Module libelf.so.1 with build-id c09e357a1a3b061bf219bcfb243ca31b175e77fa
Module libdrm_radeon.so.1 with build-id 43e0aecc70c4ce905ba35c948e1c9a5d999b14c0
Module libsensors.so.5 with build-id dc8b2c1c0d8525411aca188ea3cc3fb86d381d30
Module radeonsi_dri.so with build-id 95d3e076d72d35549fb8b8e21545bade2bb7cee6
Module libXxf86vm.so.1 with build-id 01e8243d0c6c971fa9e743e6e53d606b1cb76f6e
Module libxcb-glx.so.0 with build-id 71d5b6691f53a235696da49ffa2178d643ecc228
Module libGLX_mesa.so.0 with build-id c06d82d70c326e947e96aee34690e586296830ca
Module libGLX.so.0 with build-id 02bd4ac6acc4da9288c543ea1a0cdaa70c5e151a
Module libGL.so.1 with build-id b915a2e48be6c9fd3cc6f9f4c7aab1f7aeed8a4c
Module libncursesw.so.6 with build-id b9917757481e6fa6097e2a1f31f5bb5eaf138c4e
Module libedit.so.0 with build-id 4b0babfcad161c2ad0af6e59e2493258db23a331
Module libLLVM-13.so with build-id 90a760361bef9d2de117d7e696dad26fc4cb24f4
Module libxshmfence.so.1 with build-id 8876d9ccf620858795724ca24b9e567585a77cec
Module libxcb-sync.so.1 with build-id 13025f6de23a271636ad321c77eda98801e62e8e
Module libxcb-present.so.0 with build-id 8ed389d9cd6ad7110fbb00c93b32e0efaa71a6b1
Module libxcb-dri3.so.0 with build-id 088c750254cc139e7d62b8a3fc7795a138447ccf
Module libwayland-server.so.0 with build-id 5526cec43774a83c7ab8c7ff820eea8b28880d51
Module libdrm.so.2 with build-id 00816f0a71c7e4e388c10db6245dbb9c031732a9
Module libxcb-xfixes.so.0 with build-id e231a68d00ee4cfa12a2c31e755a9e2c1e7be450
Module libxcb-dri2.so.0 with build-id 7bde0abc84135ae6258a8d1d130864071c2cc327
Module libX11-xcb.so.1 with build-id f6beacd41cd16a23f53e5e56bb599e98f039d0d6
Module libglapi.so.0 with build-id 0c725713a11c8b58cb83bcea3e0b22b187035927
Module libgbm.so.1 with build-id da72f9cb000015a62c89834b025b0ca7bec50543
Module libEGL_mesa.so.0 with build-id 2b4462bcd5bbd213bcfbe3157c335bdf03027ab0
Module libGLdispatch.so.0 with build-id de981c020bd9dbdc159b11f4a2a541310cc3b8d5
Module libEGL.so.1 with build-id 30b30de54f2f848a7b8bed469349c9a7ab1b7c22
Module libibus-1.0.so.5 with build-id 9ee6cfbac64630c1ecf356c6f72d46f932e20be8
Module libim-ibus.so with build-id e4c121358a5d080f872f3941b5bc9250d029d871
Module libdconfsettings.so with build-id 7a4ba7af122c4d11168004a9ea6def330f02089f
Module libdl.so.2 with build-id 94198b268228074fa9f405bbedbbae94112593ed
Module libp11-kit.so.0 with build-id cc372ea3c28c4d3dfc633b4d2e933c8584d2af16
Module libgck-1.so.0 with build-id bf4564176ebb323df30329f302d4a9f4565ecd5b
Module libtss2-sys.so.1 with build-id 1498ac4b48b90c1d3ac0f5f8f4d27d667bfc4771
Module libcrypto.so.1.1 with build-id d54a7ee1e288aeae436d073277ff986e03994b15
Module libgpg-error.so.0 with build-id f9aaa96d5ddf6f6872051ed7abcdfe6bdaff9b1c
Module libplds4.so with build-id d91a9c5ee69e8a373b87bfc3eec221b5c1e2950c
Module libplc4.so with build-id e194130401ccec0067df40f72affdde25bb9a383
Module libnssutil3.so with build-id 1a64415cbb9d33b86f22e1bc4028411fd5bd9484
Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5955
Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libresolv.so.2 with build-id 89a368a6ad1b392d126a2a5beb9c2f61ade00279
Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
Module libkrb5support.so.0 with build-id 36db7c21bc57a9b934ad2d3463782db9fef4af07
Module libcom_err.so.2 with build-id 358b783c9b3d12ba8248519ea2e7f3da4c4e0297
Module libk5crypto.so.3 with build-id f1c113fea46023cdf62c7e51cb643c45831abdd5
Module libkrb5.so.3 with build-id 9350783c946d77aec8ee8fd9c6bc12f4f7b72be9
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libidn2.so.0 with build-id 1ce2b50ad9f9821c2c629b521cf5a3c99593d332
Module libunistring.so.2 with build-id 617dbf3d3d6f85d6556a7a036e23845e95490158
Module libgcr-base-3.so.1 with build-id b877460db7e7f44e691890517ffff43d53da8975
Module libgoa-1.0.so.0 with build-id 4a210381e534495653b0f92be35e53931cade1cd
Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
Module libtss2-tctildr.so.0 with build-id d45a42b5bc06ce0bc08516ee688eb690cd8c5c91
Module libtss2-rc.so.0 with build-id 683cdb1ae9b98aca4ccd4080b6f418bdd95d7b59
Module libtss2-mu.so.0 with build-id ddbc7a4374d0d9ccb2132b2d7497074920f6b65c
Module libtss2-esys.so.0 with build-id 964b48ed1a288f436f7b22b1d5d765765238bde4
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libnspr4.so with build-id 0fcca981168b16e07684217e645e9b3b716a0c57
Module libnss3.so with build-id 63b30181a431facad7300e8fa3855db13d822da1
Module libsmime3.so with build-id 2950ba6b2aa311f260d83a6f27ea82f51205c57a
Module libssl3.so with build-id cb5c77014c1efd0defe3f20dca6aaeeaf5878dbf
Module libblkid.so.1 with build-id 140694a62d8d4d07c6c320a501f948dd1b389d73
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module liblzo2.so.2 with build-id ed8e33ba505954ca344aea58d10c7b8a37fd2f39
Module liblzma.so.5 with build-id 28b40c7af8098a66af6ee093b6986b91cad7694d
Module libzstd.so.1 with build-id 3bccb8fe08e48d5ea135b1d0f99de0d771dd752f
Module libstemmer.so.0 with build-id 013b48e71279a5ec55e3021fc0bd8fb10a08bae5
Module libexpat.so.1 with build-id 113bb5a3e9ad856801bfcfc029102c9bdc13d67e
Module libgraphite2.so.3 with build-id 47761dc11e553f519cde97ed9ee985be12ccdae2
Module libpixman-1.so.0 with build-id 341f793dcada3a48a306a793d265a517e3f2e7d6
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libXrender.so.1 with build-id 97e0b9ab6ba96ebc86527cc2b3c3078aad8616b3
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module ld-linux-x86-64.so.2 with build-id fc93487393eea02b5bc6e76e48976fc325294c24
Module libgeocode-glib.so.0 with build-id eb94cbef27e4d51da5dd4cce43b180236f17901a
Module libical.so.3 with build-id 1935cfb0cd72391958908957f99cde2b77cfb78a
Module libpthread.so.0 with build-id 95ae4f30a6f12ccbff645d30f8e1a3ee23ec7d36
Module libgssapi_krb5.so.2 with build-id 1813217c8baf82a1078772eed0d868310cd59f8b
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libpsl.so.5 with build-id 0229a201aaf5652186c9fdc192ebe52baf19d7f1
Module libsqlite3.so.0 with build-id 143cb4bde0356249e42c865273631c175d738ba1
Module libstdc++.so.6 with build-id b3eaebcb5369487562e52dd8d016c9cd77f80c54
Module libgdata.so.22 with build-id 62997a0216c81c4610d8a1a6b88dd63bdaf54560
Module libjson-glib-1.0.so.0 with build-id 58decebd2c409d59b07f926ae4c513281918bc4d
Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
Module libxml2.so.2 with build-id 8cdf00fa954d9a27f2f184c4d354cb14677446ac
Module libsecret-1.so.0 with build-id 0cc692dc5ac19d1147a9846a00821b6687102386
Module libedbus-private.so with build-id 7245e87071ad6c35775ae1c2963e5c742ff9fce5
Module libcamel-1.2.so.63 with build-id 7428c6c9017d632ec9a89ddd4165858ee187b3db
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
Module libmount.so.1 with build-id 4436aeea0cd8c01b5a77969e0531184f8b3513ce
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libcairo-script-interpreter.so.2 with build-id 0dda168871dfb84b217d6320fcf03a04d623364e
Module libXinerama.so.1 with build-id dbb6adece34ea2766d3efcd628af8f9757344dd6
Module libXrandr.so.2 with build-id d4e869b5c72541e1de8f96b456248987ea52d51b
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libXdamage.so.1 with build-id a1d867e093c16944b2c0083be98050ef35c9e5c2
Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
Module libXext.so.6 with build-id d70f24beb4fad748d6becffdcc13e51be0a2ebfa
Module libwayland-egl.so.1 with build-id ac45e227422559ff92c4d04851fffb8452874713
Module libwayland-client.so.0 with build-id 95e7368b400dd57e3db2a5c385de71c7dca08879
Module libxkbcommon.so.0 with build-id 3a9338b2085f0af41217bc0a90ffcc941938a16e
Module libjpeg.so.8 with build-id 8e6d3f3e8f438912b561c43b6e7f66e6e5e097d0
Module libtiff.so.5 with build-id 9e8868622f8b7144fd82dabfa8ac2fcaf6d45a34
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libtracker-sparql-3.0.so.0 with build-id d03c91051f78975ac3f1d4732d1fecf70b32e709
Module libcloudproviders.so.0 with build-id ed1d9c9e60be4e858ad148484767249be1edf95f
Module libpangoft2-1.0.so.0 with build-id c2c09f789578900f61b7fca4a4311d8b94d9a750
Module libX11.so.6 with build-id d8e0be8e0323aa421366f19065ecd1c76405c130
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libepoxy.so.0 with build-id edc178a150c4255d124e1e1ecbdbecebd1a388cd
Module libgdk_pixbuf-2.0.so.0 with build-id 5b8422ab971b1a8a8e1c43b88738d4ee217f609e
Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
Module libcairo-gobject.so.2 with build-id 9927090dddfb180365695a8f37d1cac89463f109
Module libharfbuzz.so.0 with build-id a11faa61f71b258fb92b717723757fc7dd141c01
Module libpangocairo-1.0.so.0 with build-id b65f507d9e33adfbd19369acef5e5a0a2422c6d1
Module libgmodule-2.0.so.0 with build-id c6df28882f153ee03d0fb33bb8aac2b219ebaacc
Module libcairo.so.2 with build-id a222d042e56108d2786ece7bf291b56ba2069591
Module libfribidi.so.0 with build-id fe9f35ac2a0074108c8306c517793f7279bd9b37
Module libc.so.6 with build-id 388993b6ef62f964bc7bf473c069fbfe957b9e44
Module libgcc_s.so.1 with build-id 0e3de903950e35ae59a5de8c00b1817a4a71ca01
Module libm.so.6 with build-id 210ec9905e41825671210f8f7d0b24d6c371196a
Module libgeoclue-2.so.0 with build-id c4fbb36d5d77c684c563056dd5a075772a0463dc
Module libgweather-4.so.0 with build-id 2b4819a76ee3b7beffd9d50b9383f91a05dcc432
Module libical-glib.so.3 with build-id d21a93f5b848ae3e64f2dc26696813418ec61472
Module libecal-2.0.so.1 with build-id 19420a591cf0b938dec9b03ed417e4b94f7111db
Module libsoup-2.4.so.1 with build-id 678dafa54638a6d0ab73f810643f9a23d988db00
Module libedataserver-1.2.so.26 with build-id ba73ef6b310ac157b60c7d1c30e386847991fd44
Module libglib-2.0.so.0 with build-id e268e80e668ce871312cf50e9969f88b086e33f2
Module libgobject-2.0.so.0 with build-id 4337ec84b2f33ec39a95863d47bfca0a28afd488
Module libgio-2.0.so.0 with build-id 8c411770513e0bc758a1bbe661af14c972e2a3c4
Module libgraphene-1.0.so.0 with build-id 146fd1d0593533b7842d16bc96e114e80c183ec3
Module libpango-1.0.so.0 with build-id 7e27c1e46a1d958f6b16e1ba199f8bdb3f100566
Module libgtk-4.so.1 with build-id 297f91465f88568ffd1689e7f38b326c56943897
Module libadwaita-1.so.0 with build-id b55fa43d1c6f8151265d1851a0fd6e0e979f8bb0
Module gnome-calendar with build-id 9fb854739cf8c55dfbb59a3d6a681dad5ee35a63
Stack trace of thread 23321:
#0 0x00007faed60c66c9 g_date_time_get_ymd (libglib-2.0.so.0 + 0x3a6c9)
#1 0x00007faed60c718c g_date_time_get_year (libglib-2.0.so.0 + 0x3b18c)
#2 0x000055fcbe158b2d n/a (gnome-calendar + 0x4bb2d)
#3 0x00007faed61dff8f g_closure_invoke (libgobject-2.0.so.0 + 0x13f8f)
#4 0x00007faed61fbba8 n/a (libgobject-2.0.so.0 + 0x2fba8)
#5 0x00007faed61fd5c7 g_signal_emit_valist (libgobject-2.0.so.0 + 0x315c7)
#6 0x00007faed61fd824 g_signal_emit (libgobject-2.0.so.0 + 0x31824)
#7 0x000055fcbe15d3b2 n/a (gnome-calendar + 0x503b2)
#8 0x000055fcbe15d5c4 n/a (gnome-calendar + 0x505c4)
#9 0x00007faed60e1958 n/a (libglib-2.0.so.0 + 0x55958)
#10 0x00007faed60e1163 g_main_context_dispatch (libglib-2.0.so.0 + 0x55163)
#11 0x00007faed61379e9 n/a (libglib-2.0.so.0 + 0xab9e9)
#12 0x00007faed60de6c5 g_main_context_iteration (libglib-2.0.so.0 + 0x526c5)
#13 0x00007faed62fe80e g_application_run (libgio-2.0.so.0 + 0xd380e)
#14 0x000055fcbe12d845 main (gnome-calendar + 0x20845)
#15 0x00007faed5b1b290 n/a (libc.so.6 + 0x29290)
#16 0x00007faed5b1b34a __libc_start_main (libc.so.6 + 0x2934a)
#17 0x000055fcbe12d925 _start (gnome-calendar + 0x20925)
Stack trace of thread 23363:
#0 0x00007faed5bf7faf __poll (libc.so.6 + 0x105faf)
#1 0x00007faed6137976 n/a (libglib-2.0.so.0 + 0xab976)
#2 0x00007faed60de6c5 g_main_context_iteration (libglib-2.0.so.0 + 0x526c5)
#3 0x00007faed60de712 n/a (libglib-2.0.so.0 + 0x52712)
#4 0x00007faed6110da5 n/a (libglib-2.0.so.0 + 0x84da5)
#5 0x00007faed5b7e54d n/a (libc.so.6 + 0x8c54d)
#6 0x00007faed5c03b14 __clone (libc.so.6 + 0x111b14)
Stack trace of thread 23366:
#3 0x00007faed6d78ebe n/a (libdconfsettings.so + 0x5ebe)
Stack trace of thread 23786:
#2 0x00007faed60e06a3 g_main_loop_run (libglib-2.0.so.0 + 0x546a3)
#3 0x000055fcbe15d107 n/a (gnome-calendar + 0x50107)
Stack trace of thread 23787:
Stack trace of thread 23779:
Stack trace of thread 23784:
Stack trace of thread 23782:
Stack trace of thread 23794:
Stack trace of thread 23624:
#0 0x00007faed5b7b119 n/a (libc.so.6 + 0x89119)
#1 0x00007faed5b7d920 pthread_cond_wait (libc.so.6 + 0x8b920)
#2 0x00007faeaa63abbc n/a (radeonsi_dri.so + 0xbdbbc)
#3 0x00007faeaa6347fc n/a (radeonsi_dri.so + 0xb77fc)
#4 0x00007faed5b7e54d n/a (libc.so.6 + 0x8c54d)
#5 0x00007faed5c03b14 __clone (libc.so.6 + 0x111b14)
Stack trace of thread 23627:
Stack trace of thread 23834:
Stack trace of thread 23791:
Stack trace of thread 23793:
Stack trace of thread 23792:
Stack trace of thread 23790:
Stack trace of thread 23789:
Stack trace of thread 23788:
Stack trace of thread 23783:
Stack trace of thread 23781:
Stack trace of thread 23780:
Stack trace of thread 23720:
#3 0x00007faed5ed461b n/a (libecal-2.0.so.1 + 0x1a61b)
Stack trace of thread 23701:
#3 0x00007faed60313e3 n/a (libedataserver-1.2.so.26 + 0x673e3)
Stack trace of thread 23639:
Stack trace of thread 23638:
Stack trace of thread 23637:
Stack trace of thread 23636:
Stack trace of thread 23635:
Stack trace of thread 23634:
Stack trace of thread 23633:
Stack trace of thread 23632:
Stack trace of thread 23631:
Stack trace of thread 23630:
Stack trace of thread 23629:
Stack trace of thread 23628:
Stack trace of thread 23626:
Stack trace of thread 23625:
Stack trace of thread 23623:
Stack trace of thread 23622:
Stack trace of thread 23621:
Stack trace of thread 23620:
Stack trace of thread 23365:
#3 0x00007faed63356dc n/a (libgio-2.0.so.0 + 0x10a6dc)
Stack trace of thread 23785:
░░ Subject: Process 23321 (gnome-calendar) dumped core
░░ Documentation: man:core(5)
░░ Process 23321 (gnome-calendar) crashed and dumped core.
░░ This usually indicates a programming error in the crashing program and
░░ should be reported to its vendor as a bug.
Mai 27 06:01:27 ThinkCentre kernel: r8169 0000:02:00.1: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000a address=0xbf49c000 flags=0x0020]
Mai 27 06:01:27 ThinkCentre kernel: r8169 0000:02:00.1: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000a address=0xbf49c010 flags=0x0020]
Mai 27 06:01:27 ThinkCentre kernel: r8169 0000:02:00.1: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000a address=0xbf49c020 flags=0x0020]
Mai 27 06:01:28 ThinkCentre kernel: r8169 0000:02:00.1: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000a address=0xbf49c030 flags=0x0020]
Mai 27 06:01:28 ThinkCentre kernel: r8169 0000:02:00.1: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000a address=0xbf49c040 flags=0x0020]
Mai 27 06:01:28 ThinkCentre kernel: r8169 0000:02:00.1: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000a address=0xbf49c050 flags=0x0020]
Mai 27 06:01:28 ThinkCentre kernel: r8169 0000:02:00.1: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000a address=0xbf49c060 flags=0x0020]
Mai 27 06:01:28 ThinkCentre kernel: r8169 0000:02:00.1: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000a address=0xbf49c070 flags=0x0020]
Mai 27 06:01:29 ThinkCentre kernel: r8169 0000:02:00.1: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000a address=0xbf49c080 flags=0x0020]
Mai 27 06:01:29 ThinkCentre kernel: r8169 0000:02:00.1: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000a address=0xbf49c090 flags=0x0020]
Mai 27 06:01:32 ThinkCentre kernel: r8169 0000:02:00.1: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000a address=0xbf49c1b0 flags=0x0020]
Mai 27 06:01:33 ThinkCentre kernel: r8169 0000:02:00.1: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000a address=0xbf49c1c0 flags=0x0020]
Mai 27 06:01:33 ThinkCentre kernel: r8169 0000:02:00.1: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000a address=0xbf49c1d0 flags=0x0020]
Mai 27 06:01:33 ThinkCentre kernel: r8169 0000:02:00.1: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000a address=0xbf49c1e0 flags=0x0020]
Mai 27 06:01:33 ThinkCentre kernel: r8169 0000:02:00.1: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000a address=0xbf49c1f0 flags=0x0020]
Mai 27 06:01:33 ThinkCentre kernel: r8169 0000:02:00.1: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000a address=0xbf49c200 flags=0x0020]
Mai 27 06:01:34 ThinkCentre kernel: r8169 0000:02:00.1: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000a address=0xbf49c210 flags=0x0020]
Mai 27 06:01:34 ThinkCentre kernel: r8169 0000:02:00.1: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000a address=0xbf49c220 flags=0x0020]
Mai 27 06:01:34 ThinkCentre kernel: r8169 0000:02:00.1: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000a address=0xbf49c230 flags=0x0020]
Mai 27 06:01:34 ThinkCentre kernel: r8169 0000:02:00.1: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000a address=0xbf49c240 flags=0x0020]
Mai 27 06:30:41 ThinkCentre kernel: sd 0:0:0:0: [sda] No Caching mode page found
Mai 27 06:30:41 ThinkCentre kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Mai 30 06:02:14 ThinkCentre kernel: ACPI: PM: Hardware changed while hibernated, success doubtful!
Mai 30 06:02:14 ThinkCentre nmbd[1312]: [2022/05/30 06:02:14.529247, 0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mai 30 06:02:14 ThinkCentre nmbd[1312]: Packet send failed to 192.168.188.255(138) ERRNO=Network is unreachable
Mai 30 06:02:14 ThinkCentre nmbd[1312]: [2022/05/30 06:02:14.550609, 0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mai 30 06:02:14 ThinkCentre nmbd[1312]: Packet send failed to 192.168.188.255(137) ERRNO=Network is unreachable
Mai 30 06:02:14 ThinkCentre nmbd[1312]: [2022/05/30 06:02:14.550687, 0] ../../source3/nmbd/nmbd_packets.c:180(send_netbios_packet)
Mai 30 06:02:14 ThinkCentre nmbd[1312]: send_netbios_packet: send_packet() to IP 192.168.188.255 port 137 failed
Mai 30 06:02:14 ThinkCentre nmbd[1312]: [2022/05/30 06:02:14.550702, 0] ../../source3/nmbd/nmbd_namequery.c:245(query_name)
Mai 30 06:02:14 ThinkCentre nmbd[1312]: query_name: Failed to send packet trying to query name WORKGROUP<1d>
Mai 30 06:02:14 ThinkCentre nmbd[1312]: [2022/05/30 06:02:14.553674, 0] ../../source3/nmbd/nmbd.c:359(reload_interfaces)
Mai 30 06:02:14 ThinkCentre nmbd[1312]: reload_interfaces: No subnets to listen to. Waiting..
Mai 30 06:02:14 ThinkCentre systemd[1]: Failed to start pkgfile database update.
░░ The job identifier is 6651 and the job result is failed.
Mai 31 06:00:03 ThinkCentre nmbd[1312]: [2022/05/31 06:00:03.377535, 0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mai 31 06:00:03 ThinkCentre nmbd[1312]: Packet send failed to 192.168.188.255(138) ERRNO=Network is unreachable
Mai 31 06:00:03 ThinkCentre nmbd[1312]: [2022/05/31 06:00:03.388998, 0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mai 31 06:00:03 ThinkCentre nmbd[1312]: Packet send failed to 192.168.188.255(137) ERRNO=Network is unreachable
Mai 31 06:00:03 ThinkCentre nmbd[1312]: [2022/05/31 06:00:03.389045, 0] ../../source3/nmbd/nmbd_packets.c:180(send_netbios_packet)
Mai 31 06:00:03 ThinkCentre nmbd[1312]: send_netbios_packet: send_packet() to IP 192.168.188.255 port 137 failed
Mai 31 06:00:03 ThinkCentre nmbd[1312]: [2022/05/31 06:00:03.389063, 0] ../../source3/nmbd/nmbd_namequery.c:245(query_name)
Mai 31 06:00:03 ThinkCentre nmbd[1312]: query_name: Failed to send packet trying to query name WORKGROUP<1d>
Mai 31 06:00:03 ThinkCentre nmbd[1312]: [2022/05/31 06:00:03.391779, 0] ../../source3/nmbd/nmbd.c:359(reload_interfaces)
Mai 31 06:00:03 ThinkCentre nmbd[1312]: reload_interfaces: No subnets to listen to. Waiting..
Mai 31 06:00:03 ThinkCentre systemd[1]: Failed to start pkgfile database update.
░░ The job identifier is 8673 and the job result is failed.
Mai 31 06:00:07 ThinkCentre systemd-coredump[280968]: Process 84712 (gnome-calendar) of user 1000 dumped core.
Stack trace of thread 84712:
#0 0x00007fd5735726c9 g_date_time_get_ymd (libglib-2.0.so.0 + 0x3a6c9)
#1 0x00007fd57357318c g_date_time_get_year (libglib-2.0.so.0 + 0x3b18c)
#2 0x0000555c6d73fb2d n/a (gnome-calendar + 0x4bb2d)
#3 0x00007fd57368bf8f g_closure_invoke (libgobject-2.0.so.0 + 0x13f8f)
#4 0x00007fd5736a7ba8 n/a (libgobject-2.0.so.0 + 0x2fba8)
#5 0x00007fd5736a95c7 g_signal_emit_valist (libgobject-2.0.so.0 + 0x315c7)
#6 0x00007fd5736a9824 g_signal_emit (libgobject-2.0.so.0 + 0x31824)
#7 0x0000555c6d7443b2 n/a (gnome-calendar + 0x503b2)
#8 0x0000555c6d744638 n/a (gnome-calendar + 0x50638)
#9 0x00007fd57368bf8f g_closure_invoke (libgobject-2.0.so.0 + 0x13f8f)
#10 0x00007fd5736a7ba8 n/a (libgobject-2.0.so.0 + 0x2fba8)
#11 0x00007fd5736a95c7 g_signal_emit_valist (libgobject-2.0.so.0 + 0x315c7)
#12 0x00007fd5736a9824 g_signal_emit (libgobject-2.0.so.0 + 0x31824)
#13 0x00007fd5737e4816 n/a (libgio-2.0.so.0 + 0x10d816)
#14 0x00007fd5737d1348 n/a (libgio-2.0.so.0 + 0xfa348)
#15 0x00007fd57358d163 g_main_context_dispatch (libglib-2.0.so.0 + 0x55163)
#16 0x00007fd5735e39e9 n/a (libglib-2.0.so.0 + 0xab9e9)
#17 0x00007fd57358a6c5 g_main_context_iteration (libglib-2.0.so.0 + 0x526c5)
#18 0x00007fd5737aa80e g_application_run (libgio-2.0.so.0 + 0xd380e)
#19 0x0000555c6d714845 main (gnome-calendar + 0x20845)
#20 0x00007fd572fc7290 n/a (libc.so.6 + 0x29290)
#21 0x00007fd572fc734a __libc_start_main (libc.so.6 + 0x2934a)
#22 0x0000555c6d714925 _start (gnome-calendar + 0x20925)
Stack trace of thread 84989:
#0 0x00007fd573027119 n/a (libc.so.6 + 0x89119)
#1 0x00007fd573029920 pthread_cond_wait (libc.so.6 + 0x8b920)
#2 0x00007fd53e63abbc n/a (radeonsi_dri.so + 0xbdbbc)
#3 0x00007fd53e6347fc n/a (radeonsi_dri.so + 0xb77fc)
#4 0x00007fd57302a54d n/a (libc.so.6 + 0x8c54d)
#5 0x00007fd5730afb14 __clone (libc.so.6 + 0x111b14)
Stack trace of thread 84749:
#0 0x00007fd5730a3faf __poll (libc.so.6 + 0x105faf)
#1 0x00007fd5735e3976 n/a (libglib-2.0.so.0 + 0xab976)
#2 0x00007fd57358c6a3 g_main_loop_run (libglib-2.0.so.0 + 0x546a3)
#3 0x00007fd5737e16dc n/a (libgio-2.0.so.0 + 0x10a6dc)
#4 0x00007fd5735bcda5 n/a (libglib-2.0.so.0 + 0x84da5)
#5 0x00007fd57302a54d n/a (libc.so.6 + 0x8c54d)
#6 0x00007fd5730afb14 __clone (libc.so.6 + 0x111b14)
Stack trace of thread 84747:
#2 0x00007fd57358a6c5 g_main_context_iteration (libglib-2.0.so.0 + 0x526c5)
#3 0x00007fd57358a712 n/a (libglib-2.0.so.0 + 0x52712)
Stack trace of thread 84752:
#3 0x00007fd574224ebe n/a (libdconfsettings.so + 0x5ebe)
Stack trace of thread 84996:
Stack trace of thread 85033:
#3 0x00007fd5734dd3e3 n/a (libedataserver-1.2.so.26 + 0x673e3)
Stack trace of thread 177380:
#3 0x0000555c6d744107 n/a (gnome-calendar + 0x50107)
Stack trace of thread 177388:
Stack trace of thread 177376:
Stack trace of thread 84990:
Stack trace of thread 84991:
Stack trace of thread 177384:
Stack trace of thread 177379:
Stack trace of thread 177374:
Stack trace of thread 177383:
Stack trace of thread 85048:
#3 0x00007fd57338061b n/a (libecal-2.0.so.1 + 0x1a61b)
Stack trace of thread 177389:
Stack trace of thread 177385:
Stack trace of thread 85001:
Stack trace of thread 85003:
Stack trace of thread 177375:
Stack trace of thread 177377:
Stack trace of thread 177381:
Stack trace of thread 177378:
Stack trace of thread 177386:
Stack trace of thread 177382:
Stack trace of thread 177387:
Stack trace of thread 84993:
Stack trace of thread 84995:
Stack trace of thread 84994:
Stack trace of thread 84992:
Stack trace of thread 84997:
Stack trace of thread 85014:
Stack trace of thread 84999:
Stack trace of thread 84998:
Stack trace of thread 85000:
Stack trace of thread 85002:
Stack trace of thread 85005:
Stack trace of thread 85007:
Stack trace of thread 85006:
Stack trace of thread 85004:
Stack trace of thread 177456:
░░ Subject: Process 84712 (gnome-calendar) dumped core
░░ Process 84712 (gnome-calendar) crashed and dumped core.
Mai 31 11:58:03 ThinkCentre nmbd[1312]: [2022/05/31 11:58:03.512413, 0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mai 31 11:58:03 ThinkCentre nmbd[1312]: Packet send failed to 192.168.188.255(138) ERRNO=No child processes
Mai 31 11:58:03 ThinkCentre nmbd[1312]: [2022/05/31 11:58:03.516653, 0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mai 31 11:58:03 ThinkCentre nmbd[1312]: Packet send failed to 192.168.188.255(137) ERRNO=Network is unreachable
Mai 31 11:58:03 ThinkCentre nmbd[1312]: [2022/05/31 11:58:03.516700, 0] ../../source3/nmbd/nmbd_packets.c:180(send_netbios_packet)
Mai 31 11:58:03 ThinkCentre nmbd[1312]: send_netbios_packet: send_packet() to IP 192.168.188.255 port 137 failed
Mai 31 11:58:03 ThinkCentre nmbd[1312]: [2022/05/31 11:58:03.525365, 0] ../../source3/nmbd/nmbd_namequery.c:245(query_name)
Mai 31 11:58:03 ThinkCentre nmbd[1312]: query_name: Failed to send packet trying to query name WORKGROUP<1d>
Mai 31 11:58:03 ThinkCentre nmbd[1312]: [2022/05/31 11:58:03.527294, 0] ../../source3/nmbd/nmbd.c:359(reload_interfaces)
Mai 31 11:58:03 ThinkCentre nmbd[1312]: reload_interfaces: No subnets to listen to. Waiting..
Mai 31 21:25:38 ThinkCentre nmbd[1312]: [2022/05/31 21:25:38.493250, 0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mai 31 21:25:38 ThinkCentre nmbd[1312]: Packet send failed to 192.168.188.255(138) ERRNO=Network is unreachable
Mai 31 21:25:38 ThinkCentre nmbd[1312]: [2022/05/31 21:25:38.517136, 0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mai 31 21:25:38 ThinkCentre nmbd[1312]: Packet send failed to 192.168.188.255(137) ERRNO=Network is unreachable
Mai 31 21:25:38 ThinkCentre nmbd[1312]: [2022/05/31 21:25:38.517210, 0] ../../source3/nmbd/nmbd_packets.c:180(send_netbios_packet)
Mai 31 21:25:38 ThinkCentre nmbd[1312]: send_netbios_packet: send_packet() to IP 192.168.188.255 port 137 failed
Mai 31 21:25:38 ThinkCentre nmbd[1312]: [2022/05/31 21:25:38.517223, 0] ../../source3/nmbd/nmbd_namequery.c:245(query_name)
Mai 31 21:25:38 ThinkCentre nmbd[1312]: query_name: Failed to send packet trying to query name WORKGROUP<1d>
Mai 31 21:25:38 ThinkCentre nmbd[1312]: [2022/05/31 21:25:38.518726, 0] ../../source3/nmbd/nmbd.c:359(reload_interfaces)
Mai 31 21:25:38 ThinkCentre nmbd[1312]: reload_interfaces: No subnets to listen to. Waiting..
Mai 31 21:25:39 ThinkCentre kernel: BUG: unable to handle page fault for address: 000000280002ffe9
Mai 31 21:25:39 ThinkCentre kernel: #PF: supervisor read access in kernel mode
Mai 31 21:25:39 ThinkCentre kernel: #PF: error_code(0x0000) - not-present page
Mai 31 22:49:39 ThinkCentre kernel: Fixing recursive fault but reboot is needed!
For the gnome-calendar coredump on resuming from hibernation on May 27 at 6am, I actually captured a stack trace:
[Thread 0x7fae69ffb640 (LWP 23714) exited]
[New Thread 0x7fae69ffb640 (LWP 55581)]
[New Thread 0x7fae637fe640 (LWP 55582)]
[Thread 0x7fae69ffb640 (LWP 55581) exited]
[New Thread 0x7fae69ffb640 (LWP 55596)]
[Thread 0x7fae69ffb640 (LWP 55596) exited]
[Thread 0x7fae637fe640 (LWP 55582) exited]
[New Thread 0x7fae637fe640 (LWP 66544)]
[New Thread 0x7fae69ffb640 (LWP 66545)]
[Thread 0x7fae69ffb640 (LWP 66545) exited]
[Thread 0x7fae637fe640 (LWP 66544) exited]
[New Thread 0x7fae637fe640 (LWP 67504)]
[New Thread 0x7fae69ffb640 (LWP 67510)]
[Thread 0x7fae637fe640 (LWP 67504) exited]
[New Thread 0x7fae637fe640 (LWP 67512)]
[New Thread 0x7faed0c31640 (LWP 67513)]
[New Thread 0x7fae62ffd640 (LWP 67514)]
[Thread 0x7faed0c31640 (LWP 67513) exited]
[New Thread 0x7faed0c31640 (LWP 67515)]
[New Thread 0x7fae6a7fc640 (LWP 67516)]
[Thread 0x7fae62ffd640 (LWP 67514) exited]
[Thread 0x7faed0c31640 (LWP 67515) exited]
[Thread 0x7fae6a7fc640 (LWP 67516) exited]
[New Thread 0x7fae6a7fc640 (LWP 67517)]
[New Thread 0x7faed0c31640 (LWP 67518)]
[Thread 0x7fae6a7fc640 (LWP 67517) exited]
[Thread 0x7faed0c31640 (LWP 67518) exited]
[New Thread 0x7faed0c31640 (LWP 67519)]
[New Thread 0x7fae6a7fc640 (LWP 67520)]
[Thread 0x7faed0c31640 (LWP 67519) exited]
[Thread 0x7fae6a7fc640 (LWP 67520) exited]
[Thread 0x7fae69ffb640 (LWP 67510) exited]
[New Thread 0x7fae69ffb640 (LWP 67521)]
[Thread 0x7fae637fe640 (LWP 67512) exited]
[New Thread 0x7fae637fe640 (LWP 67522)]
[Thread 0x7fae69ffb640 (LWP 67521) exited]
[Thread 0x7fae637fe640 (LWP 67522) exited]
[New Thread 0x7fae637fe640 (LWP 67542)]
[Thread 0x7fae637fe640 (LWP 67542) exited]
Thread 1 "gnome-calendar" received signal SIGSEGV, Segmentation fault.
0x00007faed60c66c9 in g_date_time_get_ymd () from /usr/lib/libglib-2.0.so.0
#0 0x00007faed60c66c9 in g_date_time_get_ymd () at /usr/lib/libglib-2.0.so.0
#1 0x00007faed60c718c in g_date_time_get_year () at /usr/lib/libglib-2.0.so.0
#2 0x000055fcbe158b2d in ()
#3 0x00007faed61dff8f in g_closure_invoke () at /usr/lib/libgobject-2.0.so.0
#4 0x00007faed61fbba8 in () at /usr/lib/libgobject-2.0.so.0
#5 0x00007faed61fd5c7 in g_signal_emit_valist () at /usr/lib/libgobject-2.0.so.0
#6 0x00007faed61fd824 in g_signal_emit () at /usr/lib/libgobject-2.0.so.0
#7 0x000055fcbe15d3b2 in ()
#8 0x000055fcbe15d5c4 in ()
#9 0x00007faed60e1958 in () at /usr/lib/libglib-2.0.so.0
#10 0x00007faed60e1163 in g_main_context_dispatch () at /usr/lib/libglib-2.0.so.0
#11 0x00007faed61379e9 in () at /usr/lib/libglib-2.0.so.0
#12 0x00007faed60de6c5 in g_main_context_iteration () at /usr/lib/libglib-2.0.so.0
#13 0x00007faed62fe80e in g_application_run () at /usr/lib/libgio-2.0.so.0
#14 0x000055fcbe12d845 in main ()
No symbol "gjs_dumpstack" in current context.
A debugging session is active.
Inferior 1 [process 23321] will be detached.
Quit anyway? (y or n) [answered Y; input not from terminal]
[Inferior 1 (process 23321) detached]
Here’s also my inxi output that I saved on May 12 (now I’m fully updated running kernel 5.15.41-1:
inxi -Fayz ✔
Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=3b6fde5b-4520-48c4-a624-f054a37f1e42 rw quiet
cryptdevice=UUID=88490f74-5838-4a7b-9308-81198af45113:luks-88490f74-5838-4a7b-9308-81198af45113
root=/dev/mapper/luks-88490f74-5838-4a7b-9308-81198af45113 splash
resume=UUID=3b6fde5b-4520-48c4-a624-f054a37f1e42 resume_offset=32329728
Desktop: GNOME v: 41.5 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 41.3
Type: Mini-pc System: LENOVO product: 11JN000NGE v: ThinkCentre M75q Gen 2
serial: <superuser required> Chassis: type: 35 serial: <superuser required>
Mobo: LENOVO model: 32E4 v: SDK0J40697 WIN xxx
serial: <superuser required> UEFI: LENOVO v: M47KT1FA date: 02/25/2022
Info: model: AMD Ryzen 7 PRO 5750GE with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2125 high: 3635 min/max: 1400/4659 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2216 2: 1574
3: 1510 4: 2400 5: 2400 6: 1655 7: 2362 8: 2086 9: 3635 10: 2085 11: 1929
12: 1533 13: 1841 14: 2273 15: 2400 16: 2106 bogomips: 102432
STIBP: always-on, RSB filling
Device-1: AMD Cezanne vendor: Lenovo driver: amdgpu v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: DP-2,DP-3,HDMI-A-1 empty: DP-1,DP-4 bus-ID: 04:00.0
chip-ID: 1002:1638 class-ID: 0300
Display: x11 server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: X: loaded: amdgpu
unloaded: modesetting,radeon alternate: fbdev,vesa gpu: amdgpu
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2520 s-size: <missing: xdpyinfo>
Monitor-1: DP-2 mapped: DisplayPort-1 pos: middle-r model: DuexPlus
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 166 gamma: 1.2
size: 294x165mm (11.57x6.5") diag: 337mm (13.3") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: DP-3 mapped: DisplayPort-2 pos: primary,top-left
model: Philips PHL 276B1 serial: <filter> built: 2021 res: 2560x1440 hz: 60
dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
ratio: 16:9 modes: max: 2560x1440 min: 720x400
Monitor-3: HDMI-A-1 mapped: HDMI-A-0 pos: primary,bottom-c
model: Dell E176FP serial: <filter> built: 2006 res: 1280x1024 hz: 60
dpi: 96 gamma: 1.2 size: 338x270mm (13.31x10.63") diag: 433mm (17")
ratio: 5:4 modes: max: 1280x1024 min: 720x400
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.32-1-MANJARO LLVM 13.0.1)
v: 4.6 Mesa 21.3.8 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
link-max: gen: 2 speed: 5 GT/s port: f800 bus-ID: 02:00.1
IF: enp2s0f1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0 chip-ID: 10ec:c822
class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-1.1:4 chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
Local Storage: total: 484.4 GiB used: 139.25 GiB (28.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS512GDE9X081N
lanes: 4 type: SSD serial: <filter> rev: 41720C20 temp: 41.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Verbatim model: STORE N GO
size: 7.46 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 5.00 scheme: MBR
ID-1: / raw-size: 368.18 GiB size: 361.34 GiB (98.14%)
used: 135.82 GiB (37.6%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-88490f74-5838-4a7b-9308-81198af45113
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 45.2 MiB (17.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 32 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 38.0 C
Processes: 435 Uptime: 50m wakeups: 0 Memory: 15.07 GiB
used: 8.09 GiB (53.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: N/A Packages: 1503 pacman: 1492 lib: 473 flatpak: 0 snap: 11 Shell: Zsh
v: 5.8.1 running-in: gnome-terminal inxi: 3.3.15
Any suggestions on what I can do to avoid these issues?
Thanks a lot,
Rain
EDIT: In the state the system was just now, I also couldn’t force quit the VirtualBox manager that was still open. The only way to reboot I could find was to REISUB. And when the system came back, I logged into Xorg as usual and while all 3 my screens were on, only the primary was usable. The other two were just showing a black screen and Gnome-Shell was actually mostly unresponsive. The top bar with the activities and power button was not reacting to clicks.
Switching to another shell via CTRL+ALT+F1 worked. I then restarted the gnome-shell via ALT+F2 and the r command.
Journalctl then showed a core dump for gnome-shell, but I had no gdb running to capture more details. If it would still be helpful, I could post that as well.
