Gnome Control Center seg faults
I just installed Manjaro with Gnome and the gnome-control-center won't open. Yes, I tried pacman -S gnome-control-center. It told me it was already up to date. Here are the details:
[kotval@chainsmoker ~]$ gnome-control-center
Segmentation fault (core dumped)
[kotval@chainsmoker ~]$ sudo journalctl -p 3 -xb
-- Logs begin at Tue 2020-01-14 16:35:06 CST, end at Tue 2020-01-14 18:06:25 CST. --
Jan 14 17:15:24 chainsmoker kernel: ACPI: SPCR: Unexpected SPCR Access Width.  Defaulting to byte size
Jan 14 17:15:24 chainsmoker kernel: [Firmware Bug]: the BIOS has corrupted hw-PMU resources (MSR 38d is 330)
Jan 14 17:15:24 chainsmoker kernel: ipmi_si dmi-ipmi-si.0: IRQ index 0 not found
Jan 14 17:15:24 chainsmoker kernel: ipmi_si IPI0001:00: IRQ index 0 not found
Jan 14 17:15:27 chainsmoker kernel: usb 1-2: 3:1: cannot get min/max values for control 2 (id 3)
Jan 14 17:15:37 chainsmoker kernel: usb 1-2: 2:1: cannot set freq 16000 to ep 0x84
Jan 14 17:15:37 chainsmoker kernel: usb 1-2: 3:1: cannot get min/max values for control 2 (id 3)
Jan 14 17:18:16 chainsmoker gdm-password][1042]: gkr-pam: unable to locate daemon control file
Jan 14 17:18:25 chainsmoker gdm-password][1069]: gkr-pam: unable to locate daemon control file
Jan 14 17:18:29 chainsmoker kernel: ucsi_ccg 0-0008: failed to reset PPM!
Jan 14 17:18:29 chainsmoker kernel: ucsi_ccg 0-0008: PPM init failed (-110)
Jan 14 17:18:32 chainsmoker gdm-password][1072]: gkr-pam: unable to locate daemon control file
Jan 14 17:18:58 chainsmoker gdm-password][1078]: gkr-pam: unable to locate daemon control file
Jan 14 17:19:04 chainsmoker gdm-password][1083]: gkr-pam: unable to locate daemon control file
Jan 14 17:19:15 chainsmoker gdm-password][1087]: gkr-pam: unable to locate daemon control file
Jan 14 17:19:29 chainsmoker gdm-password][1093]: gkr-pam: unable to locate daemon control file
Jan 14 17:19:48 chainsmoker gdm-password][1097]: gkr-pam: unable to locate daemon control file
Jan 14 17:19:56 chainsmoker kernel: usb 1-2: 3:1: cannot get min/max values for control 2 (id 3)
Jan 14 17:22:15 chainsmoker systemd-coredump[1863]: Process 1851 (gnome-control-c) of user 1000 dumped core.
                                                    Stack trace of thread 1859:
                                                    #0  0x00007f6d8f523f2b gst_caps_set_value (libgstreamer-1.0.so.0)                                                     #1  0x00007f6d8f524169 gst_caps_set_simple_valist (libgstreamer-1.0.so.0)                                                     #2  0x00007f6d8f524295 gst_caps_set_simple (libgstreamer-1.0.so.0)
                                                    #3  0x00007f6d8076a243 gst_caps_from_format (libgstpipewire.so)
                                                    #4  0x00007f6d8076e32f n/a (libgstpipewire.so)
                                                    #5  0x00007f6d8069274a n/a (libpipewire-module-protocol-native.so)
                                                    #6  0x00007f6d80696ad8 n/a (libpipewire-module-protocol-native.so)
                                                    #7  0x00007f6d80751556 n/a (libspa-support.so)
                                                    #8  0x00007f6d806f3d4d n/a (libpipewire-0.2.so.1)
                                                    #9  0x00007f6d8fcea4cf start_thread (libpthread.so.0)
                                                    #10 0x00007f6d919102d3 __clone (libc.so.6)
                                                    Stack trace of thread 1854:
                                                    #0  0x00007f6d919059ef __poll (libc.so.6)
                                                    #1  0x00007f6d9154c120 n/a (libglib-2.0.so.0)
                                                    #2  0x00007f6d9154c1f1 g_main_context_iteration (libglib-2.0.so.0)
                                                    #3  0x00007f6d9154c242 n/a (libglib-2.0.so.0)
                                                    #4  0x00007f6d91528bb1 n/a (libglib-2.0.so.0)
                                                    #5  0x00007f6d8fcea4cf start_thread (libpthread.so.0)
                                                    #6  0x00007f6d919102d3 __clone (libc.so.6)
                                                    Stack trace of thread 1855:
                                                    #2  0x00007f6d9154d0c3 g_main_loop_run (libglib-2.0.so.0)
                                                    #3  0x00007f6d916babc8 n/a (libgio-2.0.so.0)
                                                    Stack trace of thread 1858:
  #0  0x00007f6d9191060e epoll_wait (libc.so.6)                                                     #1  0x00007f6d8075143d n/a (libspa-support.so)
                                                    #2  0x00007f6d8070c010 n/a (libpipewire-0.2.so.1)
                                                    #3  0x00007f6d8fcea4cf start_thread (libpthread.so.0)
                                                    #4  0x00007f6d919102d3 __clone (libc.so.6)
                                                    Stack trace of thread 1851:
                                                    #0  0x00007f6d910dd433 n/a (libgtk-3.so.0)
                                                    #1  0x00007f6d910dd45b n/a (libgtk-3.so.0)
                                                    #2  0x00007f6d910dd45b n/a (libgtk-3.so.0)
                                                    #3  0x00007f6d910dd45b n/a (libgtk-3.so.0)
                                                    #4  0x00007f6d910dd45b n/a (libgtk-3.so.0)
                                                    #5  0x00007f6d910dd45b n/a (libgtk-3.so.0)
                                                    #6  0x00007f6d910dd540 n/a (libgtk-3.so.0)
                                                    #7  0x00007f6d910dd4de n/a (libgtk-3.so.0)
                                                    #8  0x00007f6d910de66e n/a (libgtk-3.so.0)
                                                    #9  0x00007f6d90f82965 n/a (libgtk-3.so.0)
                                                    #10 0x00007f6d910d8283 n/a (libgtk-3.so.0)
                                                    #11 0x00007f6d910f1dab n/a (libgtk-3.so.0)
                                                    #12 0x00007f6d910ef67c n/a (libgtk-3.so.0)
                                                    #13 0x00007f6d910ef86d n/a (libgtk-3.so.0)
                                                    #14 0x00007f6d910ef8bb n/a (libgtk-3.so.0)
                                                    #15 0x00007f6d910ef8bb n/a (libgtk-3.so.0)
                                                    #16 0x00007f6d910ef8bb n/a (libgtk-3.so.0)
                                                    #17 0x00007f6d910ef8bb n/a (libgtk-3.so.0)
                                                    #18 0x00007f6d910ef8bb n/a (libgtk-3.so.0)
                                                    #19 0x00007f6d910ef8bb n/a (libgtk-3.so.0)
                                                    #20 0x00007f6d910ef8bb n/a (libgtk-3.so.0)
                                                    #21 0x00007f6d910ef8bb n/a (libgtk-3.so.0)
                                                    #22 0x00007f6d910ef8bb n/a (libgtk-3.so.0)
                                                    #23 0x00007f6d90ed1fd5 n/a (libgtk-3.so.0)
                                                    #24 0x00007f6d91636d5a g_closure_invoke (libgobject-2.0.so.0)
                                                    #25 0x00007f6d916249e4 n/a (libgobject-2.0.so.0)
                                                    #26 0x00007f6d9162898a g_signal_emit_valist (libgobject-2.0.so.0)
                                                    #27 0x00007f6d916297f0 g_signal_emit (libgobject-2.0.so.0)
                                                    #28 0x00007f6d90eed8aa gtk_widget_show (libgtk-3.so.0)
                                                    #29 0x00005608ab5020c5 n/a (gnome-control-center)
                                                    #30 0x00007f6d91749b48 n/a (libgio-2.0.so.0)
                                                    #31 0x00007f6d91628b4a g_signal_emit_valist (libgobject-2.0.so.0)
                                                    #32 0x00007f6d916297f0 g_signal_emit (libgobject-2.0.so.0)
                                                    #33 0x00007f6d916fb557 n/a (libgio-2.0.so.0)
                                                    #34 0x00007f6d916fe1d2 n/a (libgio-2.0.so.0)
                                                    #35 0x00007f6d916fdd26 g_application_run (libgio-2.0.so.0)
                                                    #36 0x00005608ab4013fe main (gnome-control-center)
                                                    #37 0x00007f6d91838153 __libc_start_main (libc.so.6)
                                                    #38 0x00005608ab40144e _start (gnome-control-center)
                                                    Stack trace of thread 1856:
                                                    #3  0x00007f6d83462e5e n/a (libdconfsettings.so)
                                                     Stack trace of thread 1857:
                                                    #0  0x00007f6d8fcf0c45 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0)
                                                    #1  0x00007f6d806f22d9 pw_thread_loop_wait (libpipewire-0.2.so.1)
                                                    #2  0x00007f6d8076d9ad n/a (libgstpipewire.so)
                                                    #3  0x00007f6d8f51874b gst_device_provider_start (libgstreamer-1.0.so.0)
                                                    #4  0x00007f6d8f50b893 gst_device_monitor_start (libgstreamer-1.0.so.0)
                                                    #5  0x00007f6d9099018c n/a (libcheese.so.8)
                                                    #6  0x00007f6d91786fcf n/a (libgio-2.0.so.0)
                                                    #7  0x00007f6d91721e11 n/a (libgio-2.0.so.0)
                                                    #8  0x00007f6d91521f87 n/a (libglib-2.0.so.0)
                                                    #9  0x00007f6d91528bb1 n/a (libglib-2.0.so.0)
                                                    #10 0x00007f6d8fcea4cf start_thread (libpthread.so.0)
                                                    #11 0x00007f6d919102d3 __clone (libc.so.6)
-- Subject: Process 1851 (gnome-control-c) dumped core
-- Defined-By: systemd
-- Support: https://forum.manjaro.org/c/technical-issues-and-assistance
-- Documentation: man:core(5)
-- Process 1851 (gnome-control-c) crashed and dumped core.
-- This usually indicates a programming error in the crashing program and
-- should be reported to its vendor as a bug.
[kotval@chainsmoker ~]$ uname -a
Linux chainsmoker 5.4.6-2-MANJARO #1 SMP PREEMPT Tue Dec 24 15:55:20 UTC 2019 x86_64 GNU/Linux
[kotval@chainsmoker ~]$ mhwd -l
> 0000:03:00.0 (0300:10de:2182) Display controller nVidia Corporation:
    video-nvidia-440xx            2019.10.25               false            PCI
    video-nvidia-435xx            2019.10.25               false            PCI
    video-nvidia-430xx            2019.10.25               false            PCI
    video-nvidia-418xx            2019.10.25               false            PCI
           video-linux            2018.05.04                true            PCI
> 0000:01:00.1 (0300:102b:0533) Display controller Matrox Graphics, Inc.:
             video-mga            2017.03.12                true            PCI
It works perfect for me. I am just installing a new machine
[carlos@thb ~]$ gnome-control-center --version
gnome-control-center 3.34.2
[carlos@thb ~]$ uname -a
Linux thb 5.4.6-2-MANJARO #1 SMP PREEMPT Tue Dec 24 15:55:20 UTC 2019 x86_64 GNU/Linux
[carlos@thb ~]$
