Hello!
I am running gnome3 on stable branch and don’t tinker here. It is a pretty standard installation.
After last update i saw this happening with gnome-photos
$ gnome-photos --version 1 ✘
gnome-photos 40.0
Then gnome-documents:
$ gnome-documents --version
3.34.0
It does not even start:
gnome-documents ✔
** (org.gnome.Documents:8039): CRITICAL **: 20:56:25.016: g_irepository_find_by_name: assertion 'typelib != NULL' failed
** (org.gnome.Documents:8039): CRITICAL **: 20:56:25.017: g_irepository_find_by_name: assertion 'typelib != NULL' failed
** (org.gnome.Documents:8039): CRITICAL **: 20:56:25.122: g_irepository_find_by_name: assertion 'typelib != NULL' failed
** (org.gnome.Documents:8039): CRITICAL **: 20:56:25.123: g_irepository_find_by_name: assertion 'typelib != NULL' failed
(org.gnome.Documents:8039): Gjs-WARNING **: 20:56:25.123: JS ERROR: Unable to connect to the tracker database: Error: Unable to resolve arg type 'SparqlConnection'
vfunc_startup@resource:///org/gnome/Documents/js/application.js:341:51
main@resource:///org/gnome/Documents/js/main.js:47:24
run@resource:///org/gnome/gjs/modules/script/package.js:206:19
@/usr/bin/gnome-documents:6:17
(org.gnome.Documents:8039): Gjs-WARNING **: 20:56:25.133: JS ERROR: Error indexing the getting started PDF: GLib.Error tracker-miner-manager-error-quark: Filesystem miner is not active
_initGettingStarted@resource:///org/gnome/Documents/js/application.js:142:25
_createWindow@resource:///org/gnome/Documents/js/application.js:392:14
vfunc_activate@resource:///org/gnome/Documents/js/application.js:449:18
(org.gnome.Documents:8039): Gjs-CRITICAL **: 20:56:25.141: JS ERROR: TypeError: Application.modeController is null
IndexingNotification@resource:///org/gnome/Documents/js/notifications.js:176:9
_init@resource:///org/gnome/Documents/js/notifications.js:328:38
_createWindow@resource:///org/gnome/Documents/js/application.js:394:31
The tracker-miner works good in nautilus and in gnome-photos.
GJS is installed.
gnome-music
works as expected.
I am not very experience at this point when it comes to such gnome3 specific stuff.
Any help is welcome.
I would like really avoid deleting configs and just solve the problem. Thanks.
