Gnome 44.1 Upgrade - Any Issues?
It looks like Gnome 44.1 dropped into the test update branch this morning. I have 2 machines and planning on upgrading my old “testing machine” first. Anyone have any issues to report? Smooth upgrade? Any things to prep before upgrading?
Thanks.
Looks like the thread for this update is currently in progress Testing Updates - Manjaro Linux Forum
You could check the unstable thread.
use the advice of mithrial
as a precaution create a system restore point with timeshift
but nothing unusual happened (I was successful with unstable)
Some manual installed extensions will complain, but will be updated.
Smooth upgrade in testing, even pop-shell works where I used to have some issues with major updates.
