[Gnome 3.36] Apps in drawer disappeared + DE crash
Hi! Gnome 3.36 update just arrived -- and right after all app icons in app drawer are gone. Plus selecting "Frequent" option now crashes DE. Reboooted multiple times in a hope that it will start working properly.
Where to start troubleshooting? Thank you in advance :wink:
sys info:
  Host: xxxxxxxx Kernel: 5.5.11-1-MANJARO x86_64 bits: 64 compiler: gcc
  v: 9.3.0 Desktop: Gnome 3.36.0 wm: gnome-shell dm: GDM 3.34.1
  Distro: Manjaro Linux
  Type: Laptop System: LENOVO product: 80YW
  v: Lenovo Legion Y920-17IKB Laptop serial: <filter> Chassis: type: 10
  Mobo: LENOVO model: Hades v: SDK0J40709 WIN serial: <filter>
  UEFI [Legacy]: LENOVO v: 5KCN17WW date: 10/18/2018
  ID-1: BAT0 charge: 93.4 Wh condition: 96.6/90.0 Wh (107%) volts: 12.4/11.1
  model: SMP L14M6P21 type: Li-poly serial: <filter> status: Unknown
  Topology: Quad Core model: Intel Core i7-7820HK bits: 64 type: MT MCP
  arch: Kaby Lake rev: 9 L2 cache: 8192 KiB
  bogomips: 46419
  Speed: 1495 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 2753 2: 2849
  3: 2930 4: 2712 5: 3023 6: 2799 7: 2426 8: 2910
  Device-1: NVIDIA GP104BM [GeForce GTX 1070 Mobile] vendor: Lenovo
  driver: nvidia v: 430.64 bus ID: 01:00.0 chip ID: 10de:1be1
  Display: x11 server: X.Org 1.20.7 driver: nvidia compositor: gnome-shell
  resolution: 1920x1080~75Hz
  OpenGL: renderer: GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 430.64
  direct render: Yes
  Device-1: Intel CM238 HD Audio vendor: Lenovo driver: snd_hda_intel
  v: kernel bus ID: 00:1f.3 chip ID: 8086:a171
  Device-2: NVIDIA GP104 High Definition Audio driver: snd_hda_intel
  v: kernel bus ID: 01:00.1 chip ID: 10de:10f0
  Sound Server: ALSA v: k5.5.11-1-MANJARO
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
  vendor: Bigfoot Networks driver: ath10k_pci v: kernel port: 4000
  bus ID: 6e:00.0 chip ID: 168c:003e
  IF: wlp110s0 state: down mac: <filter>
  Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet vendor: Lenovo
  driver: alx v: kernel port: 3000 bus ID: 6f:00.0 chip ID: 1969:e0b1
  IF: enp111s0 state: down mac: <filter>
  Device-3: Qualcomm Atheros type: USB driver: btusb bus ID: 1-5:4
  chip ID: 0cf3:e300
  Device-4: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
  bus ID: 1-6:5 chip ID: 148f:7601 serial: <filter>
  IF: wlp0s20f0u6 state: up mac: <filter>
  IF-ID-1: ppp0 state: unknown speed: N/A duplex: N/A mac: N/A
  Local Storage: total: 1.38 TiB used: 182.02 GiB (12.9%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZVKW512HMJP-000L2
  size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 5L0QCXA7
  scheme: GPT
  ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 960 EVO 500GB
  size: 465.76 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 2B7QCXE7
  scheme: GPT
  ID-3: /dev/sda vendor: Western Digital model: WD10SPCX-24HWST1
  size: 931.51 GiB speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter>
  rev: 1A02 scheme: GPT
  ID-1: / size: 176.56 GiB used: 38.14 GiB (21.6%) fs: ext4
  dev: /dev/nvme1n1p1
  ID-2: /home size: 279.89 GiB used: 143.88 GiB (51.4%) fs: ext4
  dev: /dev/nvme1n1p2
  System Temperatures: cpu: 69.5 C mobo: N/A gpu: nvidia temp: 55 C
  Processes: 329 Uptime: 13m Memory: 47.01 GiB used: 3.04 GiB (6.5%)
  Init: systemd v: 244 Compilers: gcc: 9.3.0 alt: 8 Shell: bash v: 5.0.16
  running in: gnome-terminal inxi: 3.0.37
I reset Gnome to default after recent update, I do prefer Gnome Adwaita dark theme more then Manjaro so I removed everything Gnome related in /Home and remove all the Manjaro gnome settings and packages, there used to be Vanilla Gnome in repo, it is still there but does not work anymore.
Disabling UserTheme extension fixed this
I had the same issue. I specifically had to disable dash-to-dock in Gnome Tweaks
It did not solve for me.
Disabling Appfolders Management extension solved it for me.
