I am getting an error when trying to run picom on my rpi4. Here is the error:
[neofax@RPI4-Manjaro ~]$ picom --experimental-backends
[ 05/01/2022 13:21:51.407 parse_kawase_blur_strength INFO ] blur-strength: 7 [.iter = 3, .offset = 4.250000, .expand = 50]
[ 05/01/2022 13:21:51.782 glx_has_extension INFO ] Found GLX extension GLX_SGI_video_sync.
[ 05/01/2022 13:21:51.782 glx_has_extension INFO ] Found GLX extension GLX_SGI_swap_control.
[ 05/01/2022 13:21:51.782 glx_has_extension INFO ] Found GLX extension GLX_OML_sync_control.
[ 05/01/2022 13:21:51.782 glx_has_extension INFO ] Found GLX extension GLX_MESA_swap_control.
[ 05/01/2022 13:21:51.782 glx_has_extension INFO ] Found GLX extension GLX_EXT_swap_control.
[ 05/01/2022 13:21:51.782 glx_has_extension INFO ] Found GLX extension GLX_EXT_texture_from_pixmap.
[ 05/01/2022 13:21:51.782 glx_has_extension INFO ] Found GLX extension GLX_ARB_create_context.
[ 05/01/2022 13:21:51.782 glx_has_extension INFO ] Found GLX extension GLX_EXT_buffer_age.
[ 05/01/2022 13:21:51.783 glx_init ERROR ] Failed to get GLX context.
[ 05/01/2022 13:21:51.783 initialize_backend FATAL ERROR ] Failed to initialize backend, aborting...
This is the same if I run just picom but works (w/o dual_kawase running xrender). glxinfo shows glx is working though.
glxinfo -B
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
Extended renderer info (GLX_MESA_query_renderer):
Vendor: Broadcom (0x14e4)
Device: V3D 4.2 (0xffffffff)
Version: 22.0.1
Accelerated: yes
Video memory: 3791MB
Unified memory: yes
Preferred profile: compat (0x2)
Max core profile version: 0.0
Max compat profile version: 2.1
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.1
OpenGL vendor string: Broadcom
OpenGL renderer string: V3D 4.2
OpenGL version string: 2.1 Mesa 22.0.1
OpenGL shading language version string: 1.20
OpenGL ES profile version string: OpenGL ES 3.1 Mesa 22.0.1
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10
config.txt
# See /boot/overlays/README for all available options
#gpu_mem=64
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
#hdmi_drive=2
#enable vc4
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
disable_splash=1
#overclock
over_voltage=6
arm_freq=2000
