Hi, newbie here. Applied materia dark global theme in KDE plasma, but system settings dialog doesn’t appear to be properly themed.
It can be seen that the area encircled in red does not respect materia dark theme, rather it resembles breeze theme. Can anybody help me apply proper theming to that area? Ignore my poor English, it’s not my native language.
If needed, here’s my system info:
System: Kernel: 5.4.116-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.21.4
Machine: Type: Laptop System: HP product: HP Laptop 14-bw0xx v: N/A serial: <filter>
Mobo: HP model: 8324 v: 22.27 serial: <filter> UEFI: AMI v: F.28 date: 04/09/2019
Battery: ID-1: BAT0 charge: 31.8 Wh (100.0%) condition: 31.8/31.8 Wh (100.0%) volts: 16.7 min: 14.6
model: HP Primary status: Full
CPU: Info: Dual Core model: AMD E2-9000e RADEON R2 4 COMPUTE CORES 2C+2G bits: 64 type: MCP
arch: Excavator rev: 0 cache: L2: 1024 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 5990
Speed: 1094 MHz min/max: 1100/1500 MHz boost: enabled Core speeds (MHz): 1: 1094 2: 1084
Graphics: Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Hewlett-Packard driver: amdgpu
v: kernel bus-ID: 00:01.0
Device-2: Sunplus Innovation HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 3-1.3:3
Display: x11 server: X.Org 1.20.11 driver: loaded: amdgpu,ati unloaded: modesetting
s-res: 1366x768
OpenGL: renderer: AMD STONEY (DRM 3.35.0 5.4.116-1-MANJARO LLVM 11.1.0) v: 4.5 Mesa 21.0.3
direct render: Yes
Audio: Device-1: AMD vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:01.1
Device-2: AMD Family 15h Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 00:09.2
Sound Server-1: ALSA v: k5.4.116-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
driver: r8168 v: 8.048.03-NAPI port: e000 bus-ID: 02:00.0
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel
port: e000 bus-ID: 03:00.0
Bluetooth: Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-1.4:4
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block:
hardware: no software: yes address: see --recommends
Drives: Local Storage: total: 465.76 GiB used: 118.97 GiB (25.5%)
ID-1: /dev/sda vendor: Western Digital model: WD5000LPCX-60VHAT0 size: 465.76 GiB
Partition: ID-1: / size: 22.75 GiB used: 16.09 GiB (70.7%) fs: ext4 dev: /dev/sda4
ID-2: /boot/efi size: 256 MiB used: 84.7 MiB (33.1%) fs: vfat dev: /dev/sda1
ID-3: /home size: 200.55 GiB used: 102.8 GiB (51.3%) fs: ext4 dev: /dev/sda5
Swap: ID-1: swap-1 type: partition size: 5 GiB used: 0 KiB (0.0%) dev: /dev/sda6
Sensors: System Temperatures: cpu: 36.5 C mobo: N/A gpu: amdgpu temp: 36.0 C
Info: Processes: 174 Uptime: 17m Memory: 3.29 GiB used: 1.77 GiB (53.8%) Init: systemd Compilers:
gcc: 10.2.0 clang: 11.1.0 Packages: 1475 Shell: Bash v: 5.1.4 inxi: 3.3.04
