Hello there.
I have encountered this strange issue with the display . I am not sure what this is and I don’t know what to call it to find similar references.
It doesn’t happen with all applications and seems to happen at random with select applications.
Apparently this bug wasn’t captured on recording when I used screen recording or screenshot and the display was also glitch free while the recording software was active , so recording it by an external camera was my only option to show the issue.
Here’s the inxi output
Kernel: 5.10.61-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=882db191-d1a6-4a88-a851-8252e191a3a2 ro quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Convertible System: FUJITSU product: LIFEBOOK P728 v: N/A
serial: <filter> Chassis: type: 31 serial: <filter>
Mobo: FUJITSU model: FJNB2B3 v: G2 serial: <filter> UEFI: FUJITSU // Insyde
v: Version 1.10 date: 09/12/2018
ID-1: CMB1 charge: 22.4 Wh (66.1%) condition: 33.9/45.0 Wh (75.3%)
volts: 11.2 min: 10.8 model: Fujitsu CP734929-01 type: Li-ion
serial: <filter> status: Discharging cycles: 374
RAM: total: 7.6 GiB used: 3.12 GiB (41.1%)
Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: EA cache: L2: 6 MiB bogomips: 28808
Speed: 400 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 400 2: 400 3: 400
4: 400 5: 401 6: 400 7: 400 8: 400
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Fujitsu Limited. driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Chicony FJ Camera type: USB driver: uvcvideo bus-ID: 1-10:6
chip-ID: 04f2:b564 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 125 size: 277x156mm (10.9x6.1")
diag: 318mm (12.5")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Fujitsu Limited.
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.10.61-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Device-1: Intel Ethernet I219-LM vendor: Fujitsu Limited. driver: e1000e
v: kernel port: 3040 bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel modules: wl
port: 3040 bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
IP v6: <filter> type: deprecated dynamic noprefixroute scope: global
IF-ID-1: vboxnet0 state: down mac: <filter>
bus-ID: 1-7:4 chip-ID: 8087:0a2b class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Local Storage: total: 238.47 GiB used: 206.05 GiB (86.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD8SN8U-256G-1016
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 2016 scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.43 GiB (98.01%)
used: 206.05 GiB (88.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 882db191-d1a6-4a88-a851-8252e191a3a2
used: 304 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: F4F8-68D5
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-1:2 info: Dell Dell MS116 Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 413c:301a class-ID: 0301
Device-2: 1-5:3 info: Validity Sensors Swipe Fingerprint Sensor
type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 138a:0050 class-ID: ff00 serial: <filter>
Device-3: 1-7:4 info: Intel Bluetooth wireless interface type: Bluetooth
Device-4: 1-8:5 info: Wacom Pen and multitouch sensor type: HID
driver: usbhid,wacom interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 400mA
chip-ID: 056a:50a9 class-ID: 0300
Device-5: 1-10:6 info: Chicony FJ Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b564
class-ID: 0e02
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 42.0 C mobo: N/A
Processes: 263 Uptime: 6h 40m wakeups: 7 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1396
pacman: 1384 lib: 433 flatpak: 0 snap: 12 Shell: Bash v: 5.1.8
running-in: xfce4-terminal inxi: 3.3.06
I had kernel 5.4 installed and tried running it , but the issue persisted and became a bit worse on some applications while it improved on some other applications.
