Hi!
I’m using a wired connection. I wanted to play Minecraft but to sign in I had to go to Microsoft’s website. When I go to login.live.com
it says
Hmm. We’re having trouble finding that site.
We can’t connect to the server at login.live.com.
If that address is correct, here are three other things you can try:
Try again later.
Check your network connection.
If you are connected but behind a firewall, check that Firefox has permission to access the Web.
I checked whether this was a connection issue, however the site works fine on my iPhone and I also tested both ethernet and wifi on a different laptop that uses Linux Mint.
A while ago I changed my internet security setting to WPA2 on the router gateway website and that fixed it for a while but that suddenly stopped working too, I also recently reset my router settings and I still can’t access login.live.com
My inxi --admin --verbosity=7 --filter --no-host
output is as follows:
Kernel: 5.18.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=60fe6756-469a-4df1-8e23-bfb9d193f49f rw quiet apparmor=1
security=apparmor udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1
Type: Desktop Mobo: ASUSTeK model: TUF B450-PRO GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2202
date: 07/14/2020
RAM: total: 15.56 GiB used: 2.9 GiB (18.6%)
RAM Report:
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2243 high: 3589 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2195 2: 2061
3: 2122 4: 2203 5: 2196 6: 2194 7: 3589 8: 2054 9: 2050 10: 1863 11: 2202
12: 2196 bogomips: 86278
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN 4 process: GF 14nm
built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-2
empty: DP-1, DVI-D-1, HDMI-A-1, HDMI-A-2 bus-ID: 08:00.0
chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: DP-2 mapped: DisplayPort-1 model: ASUS VP248QG
serial: <filter> built: 2020 res: 1920x1080 dpi: 92 gamma: 1.2
size: 531x299mm (20.91x11.77") diag: 609mm (24") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
OpenGL: renderer: AMD Radeon RX 580 Series (polaris10 LLVM 13.0.1 DRM
3.46 5.18.3-1-MANJARO)
v: 4.6 Mesa 22.1.1 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 08:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.18.3-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.0 running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
vendor: ASUSTeK PRIME B450M-A driver: r8168 v: 8.049.02-NAPI modules: r8169
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.04 TiB used: 403.28 GiB (19.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WDS240G2G0A-00JH30 size: 223.57 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0400
scheme: GPT
ID-1: / raw-size: 223.27 GiB size: 218.71 GiB (97.96%)
used: 196.54 GiB (89.9%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 60fe6756-469a-4df1-8e23-bfb9d193f49f
used: 312 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: D777-5487
ID-3: /run/media/peri/09427639-084e-42b3-a1e3-d188274b9460
raw-size: 1.77 TiB size: 1.74 TiB (98.37%) used: 206.74 GiB (11.6%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 09427639-084e-42b3-a1e3-d188274b9460
ID-1: /dev/sda2 maj-min: 8:2 size: 48.83 GiB fs: ext4 label: N/A
uuid: 0cd51c5c-bc1d-443e-8fa9-396879dfc5a0
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-8:2 info: Wacom CTH-490 [Intuos Art/Photo/Comic (S)]
type: HID,Mouse driver: usbhid,wacom interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 498mA chip-ID: 056a:033c class-ID: 0301
Device-2: 1-10:3 info: Cherry GmbH USB Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046a:000c class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 40.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 584
Processes: 309 Uptime: 5h 29m wakeups: 1 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: pacman: 1881 lib: 535 flatpak: 0 Shell: Bash v: 5.1.16
running-in: konsole inxi: 3.3.18
Thanks in advance!
