HI!. Im Using Manjaro KDE in the latest version. Im using a ThinkPad t410 wich is equipped with a nvidia nvs 3100m. Now, The problem appears after wake up, With the propietary drivers running, after wake up, the background wallpapers becomes glitchy and others elements too.
Hi there,
Maybe see this first and share system info:
Hi!. ok, this is the output.
root=UUID=dee80289-3666-48ba-bde9-3b0892ffde6b rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 2537VQA v: ThinkPad T410
Mobo: LENOVO model: 2537VQA serial: <superuser required> BIOS: LENOVO
v: 6IET85WW (1.45 ) date: 02/14/2013
ID-1: BAT0 charge: 6.6 Wh (17.1%) condition: 38.5/47.5 Wh (81.1%) volts: 10.6
min: 10.8 model: SANYO 45N1105 type: Li-ion serial: <filter>
status: discharging
RAM: total: 7.64 GiB used: 2.3 GiB (30.1%)
Info: model: Intel Core i3 M 350 bits: 64 type: MT MCP arch: Westmere
gen: core 1 level: v2 built: 2010-11 process: Intel 32nm family: 6
model-id: 0x25 (37) stepping: 2 microcode: 0x11
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1028 high: 1116 min/max: 933/2266 scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 931 2: 993 3: 1073 4: 1116
bogomips: 18094
Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs lahf_lm lm mca mce mmx
monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pdcm pebs pge pni popcnt
pse pse36 pti rdtscp rep_good sep ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
vulnerable
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
prctl and seccomp
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GT218M [NVS 3100M] vendor: Lenovo ThinkPad T410
driver: nvidia v: 340.108 alternate: nouveau non-free: series: 340.xx
status: legacy (EOL) last: release: 340.108 kernel: 5.4 xorg: 1.20
arch: Tesla process: 40-80nm built: 2006-13 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 2 speed: 5 GT/s bus-ID: 01:00.0 chip-ID: 10de:0a6c
class-ID: 0300
Device-2: Lenovo Integrated Webcam [R5U877] type: USB driver: uvcvideo
bus-ID: 1-1.6:4 chip-ID: 17ef:480f class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1280x800 s-dpi: 108 s-size: 301x192mm (11.85x7.56")
s-diag: 357mm (14.06")
Monitor-1: LVDS-0 res: 1280x800 hz: 60 dpi: 107
size: 303x190mm (11.93x7.48") diag: 358mm (14.08") modes: N/A
API: OpenGL v: 3.3.0 NVIDIA 340.108 renderer: NVS 3100M/PCIe/SSE2
direct-render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
class-ID: 0403
Device-2: NVIDIA High Definition Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 2
speed: 5 GT/s bus-ID: 01:00.1 chip-ID: 10de:0be3 class-ID: 0403
API: ALSA v: k5.4.241-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.70 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
Device-1: Intel 82577LM Gigabit Network vendor: Lenovo driver: e1000e
v: 3.2.6-k port: 1820 bus-ID: 00:19.0 chip-ID: 8086:10ea class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Centrino Advanced-N 6200 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:4239
class-ID: 0280
Local Storage: total: 262.61 GiB used: 17.87 GiB (6.8%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: SanDisk model: SC32G
size: 29.72 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> scheme: GPT
SMART Message: Unknown smartctl error. Unable to generate data.
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS250G2B0A-00SM50 size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter> rev: 20WD
scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GU10N rev: MX05
dev-links: cdrom
ID-1: / raw-size: 146.48 GiB size: 143.13 GiB (97.71%)
used: 17.87 GiB (12.5%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: dee80289-3666-48ba-bde9-3b0892ffde6b
ID-1: /dev/mmcblk0p1 maj-min: 179:1 size: 29.72 GiB fs: vfat label: SD CARD
uuid: 061E-DFD1
ID-2: /dev/sda1 maj-min: 8:1 size: 1.17 GiB fs: ntfs label: SYSTEM_DRV
uuid: 76849BE3849BA3E1
ID-3: /dev/sda2 maj-min: 8:2 size: 85.23 GiB fs: ntfs label: Windows7_OS
uuid: 2C5C9E8D5C9E5186
Hub-1: 1-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0020 class-ID: 0900
Device-1: 1-1.3:3 info: Upek Biometric Touchchip/Touchstrip Fingerprint
Sensor type: <vendor specific> driver: N/A interfaces: 1 rev: 1.0
speed: 12 Mb/s power: 100mA chip-ID: 147e:2016 class-ID: 0000
Device-2: 1-1.6:4 info: Lenovo Integrated Webcam [R5U877] type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 200mA
Hub-3: 2-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
System Temperatures: cpu: 59.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 3827
Processes: 184 Uptime: 19m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1161 libs: 326 tools: pamac pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16
running-in: konsole inxi: 3.3.26
