how to make glava music visualizer auto startup
Add it to…
System Settings → Workspace → Startup and Shutdown → Autostart
thank you for your quick reply…
but how can add it as application when it ‘not’ found as ‘application’ in system
Why is it “not found”?
I dunno knw…
when I search ‘galva’ in krunner…
I found nothing on this name …
I download and installed it in terminal using command ( sudo pacman -S gava )
Maybe you mistyped the name ─ as you did twice now in your post above mine. The name is glava, and you should be able to select that in the “Autostart” section of System Settings.
Edit: It’s probably under the Multimedia section.
This time I typed it super clear but couldn’t found
can you confirm the way of I installed this is correct or not…
If you installed it with…
sudo pacman -S glava
… then yes, you did it correctly.
How do you normally start it?
I got the solution…
just now I searched on this in google and it says - ( You can also do this manually, by creating a file called glava.desktop
in ~/.config/autostart/
with the following contents:
[Desktop Entry]
Type=Application
Exec=sh -c 'sleep 10 && glava --desktop'
Hidden=false
NoDisplay=false
X-GNOME-Autostart-enabled=true
Name=GLava
anyway thank you for your kind and quick replies
only with “konsole” (because it not showing as application in krunner or launcher) by using this command " glava --desktop"
but only problem is whenever i close the konsole tab which I gave the command … this glava also closing
