Glances stopped working
network
bug
#1
My glances stopped working in my tmux after the latest stable update.
  File "/usr/lib/python3.7/site-packages/glances/__init__.py", line 109, in start
                                   mode.serve_forever()
                                                         File "/usr/lib/python3.7/site-packages/glances/standalone.py", line 144, in serve_forever
        loop = self.__serve_forever()
                       File "/usr/lib/python3.7/site-packages/glances/standalone.py", line 114, in __serve_forever
        self.stats.update()
        File "/usr/lib/python3.7/site-packages/glances/stats.py", line 222, in update
                                                              self._plugins[p].update()
        File "/usr/lib/python3.7/site-packages/glances/plugins/glances_plugin.py", line 911, in wrapper
                              ret = fct(self, *args, **kw)
                                                            File "/usr/lib/python3.7/site-packages/glances/plugins/glances_plugin.py", line 920, in wrapper
        ret = fct(*args, **kw)
                         File "/usr/lib/python3.7/site-packages/glances/plugins/glances_network.py", line 133, in update
        netstat['is_up'] = netstatus[net].isup
    KeyError: 'enp1s0'
The above appears where Glances should be.
Looks like it could be due to python.
Any (quick) fix?
#2
I just tried it on a ssh/screen session, works without problems.
Do you use a config in /etc or ~./config ? Because the problem seems to be relate to the network plugin and something that looks like a network device.
A quick fix might be to start glances without the network plugin.
glances --disable-plugin network
Yes that is it. This lap is on wireless so enp1s0 is simply wrong!
What I do not get is how it could change since I have not touched the config file for ages (actually: not at all).
In any case
works just fine - thanks!
#4
There is a Bug report that sounds very similar to your Problem
It is fixed but there is no new release yet.
Ah! That is good news because this has to be that bug. Now it will be fixed! Meanwhile I can use your workaround. Life is good :slight_smile:
