This is pretty cool and available in the Manjaro repos.
Glances, a neat alternative to htop
Yes, it is an excellent utility. Be sure to check your RAM usage though, as the last time I had it installed it was creating a memory leak. Rather ironic as that's usually why people install utilities like that for in the first place.
Gives a good overview. But I wouldn't call it an alternative to htop, because you can't kill processes from within it.
I didn't know you could do that in htop. I use task manager for that. I was just repeating the article title though. Thanks for the htop info.
After looking it up, I will still use task manager for that.
htop or top are my task managers
I will try it before I knock it, but I like that task manager is nicely alphabetized for quick, easy searching, even if it's not as cool as a terminal program.
Here's the desktop non-AMP version:
Haha!! A girl blew me kisses. That never happens in real life. Thx @jillswift. You made my day.
I got bored and added all the optional dependencies to the PKGBUILD. That way you can keep track of them if you want to use any of them.
glances PKGBUILD
pkgname=glances
pkgver=3.1.3
pkgrel=2
pkgdesc='CLI curses-based monitoring tool'
arch=('any')
url='https://github.com/nicolargo/glances'
license=('LGPL')
makedepends=('git')
depends=('python-psutil' 'python-setuptools' 'python-future')
optdepends=('python-bottle: for Web server mode'
'python-cassandra-driver: for the Cassandra export module'
'python-couchdb: for the CouchDB export module'
'python-docker: for the Docker monitoring support'
'python-elasticsearch: for the Elastic Search export module'
'python-hddtemp: HDD temperature monitoring support'
'python-influxdb: for the InfluxDB export module'
'python-kafka: for the Kafka export module'
'python-matplotlib: for graphical/chart support'
'python-netifaces: for the IP plugin'
'python-nvidia-ml-py3-git: for the GPU plugin'
'python-pika: for the RabbitMQ/ActiveMQ export module'
'python-prometheus_client: for the Prometheus export module'
'python-py-cpuinfo: for the Quicklook CPU info module'
'python-pygal: for the graph export module'
'python-pysnmp: for SNMP support'
'python-pystache: for the action script feature'
'python-pyzmq: for the ZeroMQ export module'
'python-requests: for the Ports, Cloud plugins and RESTful export module'
'python-statsd: for the StatsD export module'
'python-wifi: for the wifi plugin'
'python-zeroconf: for the autodiscover mode')
# Missing from repos / AUR
#'python-bernhard: for the Riemann export module'
#'python-potsdb: for the OpenTSDB export module'
#'python-pymdstat: for RAID support'
#'python-pysmart.smartx: for HDD Smart support'
changelog=NEWS.rst
source=("https://github.com/nicolargo/glances/archive/v$pkgver.tar.gz"
"$pkgname.service")
sha256sums=('e3e8f9362b82c74427522e82501b47696945251035b35282f9ee4bc533996220'
'4cdd6955ec14146a9975bd5a6fe0fe15081b0d83fc8a062e4a68b8e432317308')
build() {
cd "$pkgname-$pkgver"
python setup.py build
package() {
python setup.py install --root="$pkgdir/" --skip-build --optimize=1
install -Dm644 "$srcdir/$pkgname.service" -t "$pkgdir/usr/lib/systemd/system"
The one thing I like using glances for. Monitor my cpu and gpu temperature. I don't care about my ram usage. As much as I used to. Back when I had 4GB of ram. Now that I have 32GB of ram. Just don't care. Just want to use my system the way I want to.
Have you considered using or making a conky to constantly monitor your CPU temperature? If you haven't, you should. Conkys are fun.
I have. But been so darn lazzy about it. And I like to used Dynamic window manager. So I rarely ever see the background. So idk. If I was using a floating window manager. Sure. It make more since to used conky over running a terminal monitor tool like glances.
