Glade libsoup collissions
When I try to start Glade, I get this issue:
(glade:225430): Gtk-WARNING **: 21:05:15.239: Unknown key gtk-cursor-theme in /home/alicia/.config/gtk-3.0/settings.ini
GladeUI-Message: 21:05:15.301: 3 missing displayable value for GtkWidget::AtkObject::accessible-role
GladeUI-Message: 21:05:15.328: 1 missing displayable value for GtkLabel::wrap-mode
GladeUI-Message: 21:05:15.443: 5 missing displayable value for GtkCellRendererText::variant
(org.gnome.Glade:225430): libsoup-ERROR **: 21:05:15.466: libsoup3 symbols detected. Using libsoup2 and libsoup3 in the same process is not supported.
Trace/breakpoint trap      (core dumped) glade
Is there a fix for this?
An issue due to timezonemap, a part of cinnamon desktop. Take a look:
In first post you have a temporary workaround.
Thank you for responding.
I now renamed /usr/share/glade/catalogs/TimezoneMap.xml to TimezoneMap.xml~ which got Glade working again.
Thanks again and have a great 2026!
I hadn’t realized a message in the Archlinux Gitlab, the timezonemap developer closed the issue telling this was finally fixed in timezonemap 0.4.5.4-1 five days ago. Manjaro still has 0.4.5.2-2 so as soon as the update arrives, you will be able to rename back the xml file. The new one it’s currently only available in the unstable version.
If you need it and don’t want to switch to the unstable version, there’s a specific thread for requesting packages to be added to the stable version:
Happy New Year for you too! :tada:
