Hello everyone!
My Manjaro gnome (which I installed in July 2020, Nibia 20.2.1) does not have any icons and right click on Desktop shows only Background/Display settings. The funny thing is that on my Laptop (installed Manjaro Gnome in June 2020 Nibia 20.2) the Desktop works fine with icons.
Short info about my system:
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=2d450e8a-f065-40ba-828d-a4128a42776f rw quiet apparmor=1
Desktop: GNOME 3.38.3 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: B450 GAMING PLUS MAX (MS-7B86) v: 3.0
serial: <filter> UEFI: American Megatrends v: H.60 date: 04/18/2020
Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701021
L2 cache: 4 MiB
bogomips: 115250
Speed: 4039 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 4039 2: 2061 3: 2124 4: 2053 5: 2839 6: 2050 7: 1878 8: 2040 9: 2057
10: 2131 11: 3690 12: 2052 13: 2039 14: 2043 15: 4021 16: 2056
conditional, RSB filling
Device-1: NVIDIA TU104 [GeForce RTX 2060] vendor: Gigabyte driver: nouveau
v: kernel bus ID: 26:00.0 chip ID: 10de:1e89
Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver:
loaded: modesetting,nouveau alternate: fbdev,nv,vesa
OpenGL: renderer: NV164 v: 4.3 Mesa 20.3.3 direct render: Yes
Device-1: NVIDIA TU104 HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 26:00.1 chip ID: 10de:10f8
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 28:00.4 chip ID: 1022:1487
Sound Server: ALSA v: k5.9.16-1-MANJARO
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus ID: 22:00.0
chip ID: 10ec:8168
IF: enp34s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: br-13c397636b91 state: down mac: <filter>
IF-ID-2: br-6ddf1b65eb5e state: down mac: <filter>
IF-ID-3: br-a62f915ab8ca state: down mac: <filter>
IF-ID-4: br-c7af60b09f4b state: down mac: <filter>
IF-ID-5: docker0 state: down mac: <filter>
Local Storage: total: 1.47 TiB used: 63.59 GiB (4.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P2SSD8
size: 465.76 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: P2CR010 temp: 30.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT120BX500SSD1
size: 111.79 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: R013
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-08WN4A0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 1A02
ID-1: / raw size: 465.46 GiB size: 457.16 GiB (98.22%)
used: 63.59 GiB (13.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 41.5 C mobo: N/A gpu: nouveau temp: 36.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 606
Processes: 380 Uptime: 43m wakeups: 0 Memory: 15.64 GiB
used: 4.34 GiB (27.7%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.1 Packages: 1475 pacman: 1470 lib: 398 flatpak: 0 snap: 5
Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.2.02
I’ve tried also 5.4 LTS Kernel and doesn’t work. I have gnome-shell-extension-desktop-icons
installed on my PC.
I really do not know what to do
Thanks in advance.
