Dando
1
Hello,
I’m trying to find the Openshot package (packaged by David Runge) in pacman in manjaro gitlab packages so i can inspect it but i can’t find it.
i also looked in arch linux package website and couldn’t find it.
Can someone point me in the right direction?
Cheers
Arch packages are located here: Arch Linux - Package Search
Dando
4
@Yochanan in the github package code, are the SHA hashes for the download file from the source or for the package file/code itself?
If they’re available upstream, then yes. See PKGBUILD - ArchWiki
