I tried this on many applications but its didn’t work.Example: I was downloading Whatsapp on Konsole with AUR Git Clone command and i got this error… I tried also with PCSX2 Emulator and many applications but nothings changed…
==> Starting build()...
CMake Error: CMake was unable to find a build program corresponding to "Unix Makefiles". CMAKE_MAKE_PROGRAM is not set. You probably need to select a different build tool.
CMake Error: CMAKE_C_COMPILER not set, after EnableLanguage
CMake Error: CMAKE_CXX_COMPILER not set, after EnableLanguage
-- Configuring incomplete, errors occurred!
==> ERROR: A failure occurred in build().
Aborting...
Thanks for helps and sorry for my English, have a good day…
