Gimp slows, sometimes crashes, using soft select tool, which may be caused by GPU
Having problem with Gimp (soft select tool slows, sometimes crashes Gimp) and I suspect the problem is GPU. I have AMD Radeon RX 580 and want to update the driver but AMD does not have one for Manjaro OS. AMD has only RHEL, Ubuntu and SLED SLES Linux drivers. Will one of these three driver updates work in Manjaro?
  Kernel: 6.11.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
    root=UUID=722d2fc0-e926-4117-8d67-d114ac83bcc8 rw quiet splash
    resume=UUID=c6d32ee6-aa10-4c68-ae27-261ad233c02e udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
  Mobo: ASUSTeK model: PRIME Z690-A v: Rev 1.xx serial: <superuser required>
    part-nu: SKU uuid: <superuser required> UEFI: American Megatrends v: 2403
    date: 05/11/2023
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
    status: discharging
  Info: model: 12th Gen Intel Core i7-12700 bits: 64 type: MST AMCP
    arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
    microcode: 0x37
  Topology: cpus: 1x dies: 1 clusters: 9 cores: 12 threads: 20 mt: 8 tpc: 2
    st: 4 smt: enabled cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32
    KiB, 4x64 KiB L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB desc: 1x25 MiB
  Speed (MHz): avg: 800 min/max: 800/4800:4900:3600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
    5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
    15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 bogomips: 84500
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
    470/480/570/570X/580/580X/590] vendor: XFX Pine driver: amdgpu v: kernel
    arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
    gen: 3 speed: 8 GT/s lanes: 16 ports: active: DVI-D-1,HDMI-A-1
    empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
    temp: 51.0 C
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1016x317mm (40.00x12.48")
    s-diag: 1064mm (41.9") monitors: <missing: xrandr>
  Monitor-1: DVI-D-1 model: Samsung SyncMaster serial: <filter> built: 2007
    res: 1920x1200 dpi: 94 gamma: 1.6 size: 518x324mm (20.39x12.76")
    diag: 611mm (24.1") ratio: 16:10 modes: max: 1920x1200 min: 720x400
  Monitor-2: HDMI-A-1 model: Acer G276HL serial: <filter> built: 2016
    res: 1920x1080 dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23")
    diag: 686mm (27") ratio: 16:9 modes: max: 1920x1080 min: 720x400
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 Series (radeonsi
    polaris10 LLVM 18.1.8 DRM 3.59 6.11.11-1-MANJARO) device-ID: 1002:67df
    memory: 7.81 GiB unified: no
  API: Vulkan v: 1.4.303 layers: N/A device: 0 type: discrete-gpu name: AMD
    Radeon RX 580 Series (RADV POLARIS10) driver: N/A device-ID: 1002:67df
    surfaces: xcb,xlib
  Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:7ad0 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon RX
    470/480 / 570/580/590] vendor: XFX Pine driver: snd_hda_intel v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0
    class-ID: 0403
  API: ALSA v: k6.11.11-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0 chip-ID: 8086:15f3
    class-ID: 0200
  IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
  Local Storage: total: 5.91 TiB used: 1.38 TiB (23.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 35.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 2000GB
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 04RL scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD20SDRW-11VUUS0 size: 1.82 TiB block-size: physical: 512 B
    logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 1034 scheme: GPT
  ID-1: / raw-size: 50.04 GiB size: 48.95 GiB (97.83%) used: 20.89 GiB (42.7%)
    fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-3: /home raw-size: 1.76 TiB size: 1.73 TiB (98.37%)
    used: 69.02 GiB (3.9%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p2 maj-min: 259:2
  System Temperatures: cpu: 29.0 C mobo: N/A gpu: amdgpu temp: 51.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 746
  Memory: total: 64 GiB available: 62.54 GiB used: 3.53 GiB (5.6%)
  Processes: 378 Power: uptime: 23m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 24.99 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: pm: pacman pkgs: 1356 libs: 375 tools: pamac pm: flatpak pkgs: 0
    Compilers: N/A Shell: Zsh v: 5.9 default: Bash v: 5.2.37 running-in: konsole
    inxi: 3.3.37
I ran
sudo mhwd -a pci free 0300
and got
Skipping already installed config ā€˜video-linuxā€™ for device: 0000:01:00.0 (0300:1002:67df) Display controller ATI Technologies Inc Ellesmere [Ra
deon RX 470/480/570/570X/580/580X/590]
Does this mean I already have the latest driver?
Why do you think that?
Updating an AMD driver means updating the entire kernel, since the driver is part of the linux kernel. OpenGL, Vulkan, OpenCL and HW video de/encoding is implemented with Mesa3D, i.e. 3D acceleration. So what AMD offers on its site are most likely the ā€œpro driversā€, which provide additional instruction sets on top of Mesa3D for OpenCL/Cuda, i.e. Rocm, which you donā€™t need for normal use. So it is rather additional API.
At least I can say that the problem is most likely not the GPU, since GIMP doesnā€™t support GPU acceleration like Photoshop.
Yes. The user space driver is up to date. The kernel space driver is integrated into the kernel and is updated with the kernel version.
Megavolt, I added the information about running mhwd while your answer was on the way. Thank you.
Good information. I appreciate it.
Iā€™ve ordered another 64 gigs memory to double what I have just in case that solves the problem (I donā€™t think it will).
Note that this Kernel is EOL, you should add one of the LTS ones (linux66 or linux612, currently) and remove linux611, otherwise you will experience such issues with updates.
Maybe try linux613 and see if that works better for you.
Yes ā€¦ unless you want to change branches and/or kernels thereby getting slightly newer kernels/modules to the extent they would be any different (I have not checked that they would be).
My search-fu says you have BIOS updates available, including some listed for ā€˜stabilityā€™.
Thanks, Iā€™ll update the bios.
XY Problem detected: Youā€™re asking about your attempted solution rather than your actual problem. This leads to enormous amounts of wasted time and energy, both on the part of people asking for help, and on the part of those providing help.
Please see:
Please edit your topic title appropriately.
I tried the kernels and may have had a slight improvement with linux613 but it introduced problems with my second (older) display ā€“ running linux66 now and tried but failed to remove linux611 because ā€œremoving linux611 breaks dependency 'linux611' required by linux-meta.ā€ Any suggestions?
The obvious thing - remove the *meta package(s).
( They were acquired due to the system retaining a defunct kernel - linux-meta and any related packages would have been automatically installed in an attempt to remedy that. )
Using sudo mhwd -a pci free 0300 will activate the default video-linux kernel module (driver). I too have an RX 580 which performs exceptionally well (at least, for me) using video-linux.
There is generally no requirement to use amdgpu, though it is possible; I have an ASUS Z490-A; albeit a slightly older generation board, there have been no issues such as described.
The additional RAM will no doubt be helpful, but I would be remiss if I didnā€™t note that your BIOS is rather old ā€“ perhaps not in years, but in iterations.
If the following link reflects your mainboard, there have been twelve (12) BIOS releases since version 2305 that you currently use.
The latest (available from the ASUS site) appears to be version 4101 released on 2025/01/14.
Updating the BIOS is often overlooked, whereas it can potentially solve many apparent problems.
It might be interesting to browse through the descriptions of each BIOS to see respective security updates and improvements that youā€™ve missed. :slight_smile:
Thank you. I didnā€™t realize I was so far behind on the BIOS.
With so many iterations in such a relatively short time, Iā€™m guessing the BIOS in question had a lionā€™s share of issues; typically, we see fewer updates over the lifetime of any given firmware.
Cheers.
Updated BIOS to latest (4101), still no joy on the Gimp problem, but of course it was important to do ā€“ much obliged to you for catching that.
Now Iā€™m waiting for the memory to get here to see if that solves my Gimp problem. Iā€™ll report when I get it in.
UPDATE 20250125:
Doubling system memory (64 to 128 gig) did not help. Still sluggish and creaky whenever I make a selection in a photo. Experimenting with swappiness and cash pressure no help (midranges and extremes tested).
sudo sysctl vm.vfs_cache_pressure=150
vm.vfs_cache_pressure = 150
sudo sysctl vm.swappiness=110
vm.swappiness = 110
Update of latest BIOS no help.
Exhaustive editing of Gimp preferences no effect.
OS is up to date.
Everything else on the computer is speedy, especially since doubling the ram. It still looks to me like GPU problem. (Opened the same file in Ubuntu/Gimp that Iā€™ve been using to test and performance was about the same. This is one of the reasons I suspect GPU.)
Iā€™m out of ideas and donā€™t know what to try next.
System as of 20250125:
  Kernel: 6.6.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    part-nu: SKU uuid: <superuser required> UEFI: American Megatrends v: 4101
    date: 12/03/2024
    status: discharging
    microcode: 0x37
    temp: 57.0 C
    polaris10 LLVM 18.1.8 DRM 3.54 6.6.65-1-MANJARO) device-ID: 1002:67df
    surfaces: xcb,xlib
    v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7ad0
    class-ID: 0403
    class-ID: 0403
  API: ALSA v: k6.6.65-1-MANJARO status: kernel-api with: aoss
    class-ID: 0200
  Local Storage: total: 4.09 TiB used: 767.3 GiB (18.3%)
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 36.9 C
    scheme: GPT
  ID-1: / raw-size: 50.04 GiB size: 48.95 GiB (97.83%) used: 13.11 GiB (26.8%)
    used: 68.97 GiB (3.9%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
  Kernel: swappiness: 110 (default 60) cache-pressure: 150 (default 100)
    zswap: yes compressor: zstd max-pool: 20%
  System Temperatures: cpu: 24.0 C mobo: N/A gpu: amdgpu temp: 57.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 753
  Memory: total: 128 GiB available: 125.54 GiB used: 6.44 GiB (5.1%)
  Processes: 387 Power: uptime: 53m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 50.2 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: pm: pacman pkgs: 1354 libs: 375 tools: pamac pm: flatpak pkgs: 0
    inxi: 3.3.37
Noted.
