Hi guys,
I got manjaro and endeavourOS in VirtualBox.
GhostNET was working fine before. Now it always throws the same error.
Tried in both manjaro and endeavourOS. Same result.
Are you able to run the script successfully?
To those of you more experienced, what is the error exactly pointing to?
What possible fixes can you recommend?
After i issue ghostnet start the internet connectivity is cut off.
When i do [anon ~]# ghostnet status
The following error Traceback is thrown.
File "/usr/lib/python3.10/urllib/request.py", line 1348, in do_open
h.request(req.get_method(), req.selector, req.data, headers,
File "/usr/lib/python3.10/http/client.py", line 1282, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/lib/python3.10/http/client.py", line 1328, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/lib/python3.10/http/client.py", line 1277, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/lib/python3.10/http/client.py", line 1037, in _send_output
self.send(msg)
File "/usr/lib/python3.10/http/client.py", line 975, in send
self.connect()
File "/usr/lib/python3.10/http/client.py", line 941, in connect
self.sock = self._create_connection(
File "/usr/lib/python3.10/socket.py", line 824, in create_connection
for res in getaddrinfo(host, port, 0, SOCK_STREAM):
File "/usr/lib/python3.10/socket.py", line 955, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
During handling of the above exception, another exception occurred:
File "/usr/bin/ghostnet", line 463, in <module>
check()
File "/usr/bin/ghostnet", line 446, in check
main()
File "/usr/bin/ghostnet", line 460, in main
DoJob(job)
File "/usr/bin/ghostnet", line 137, in __init__
self.status()
File "/usr/bin/ghostnet", line 178, in status
DoJob.check_status()
File "/usr/bin/ghostnet", line 117, in check_status
getip = urlopen('http://ipinfo.io/ip').read()
File "/usr/lib/python3.10/urllib/request.py", line 216, in urlopen
return opener.open(url, data, timeout)
File "/usr/lib/python3.10/urllib/request.py", line 519, in open
response = self._open(req, data)
File "/usr/lib/python3.10/urllib/request.py", line 536, in _open
result = self._call_chain(self.handle_open, protocol, protocol +
File "/usr/lib/python3.10/urllib/request.py", line 496, in _call_chain
result = func(*args)
File "/usr/lib/python3.10/urllib/request.py", line 1377, in http_open
return self.do_open(http.client.HTTPConnection, req)
File "/usr/lib/python3.10/urllib/request.py", line 1351, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [Errno -3] Temporary failure in name resolution>
