Glad to hear it helped.
I am also getting similar messages, but they scroll too fast for me to see them all.
Where are they logged? journalctl -b -1 doesnāt show them.
You will not get anything in your logs , that is the way Mine did . Maybe video record the screen with Your phone ?
I still get some messages , like " dismounting drive , shutting down
Try to find out what the message says and google it might be a solution you will uncover in your search
I found
journalctl -b -1 --boot
This shows messages well past unmounting /home, so plenty of good details. Will dig now to fix these errors.
I might be wrong but that message might not be a error message but just a information message .
Please someone correct Me if I am wrong for I am no expert here
I am also not even nearly and expert. However, after a small bit of Google-fu, it would seem that @brothergc is correct.
According to this page, the command to view errors is:
To get all errors for running services using
journalctl
:$ journalctl -p 3 -xb
where
-p 3
meanspriority err
,-x
provides extra message information, and-b
means since last boot
Hope this helps.
Iām getting the same messages and looking around it seems quit common.
sometime they disappear if i change the GPU with optimus manager,
but i donāt really mind them if it doesnāt affect anything.
does applying @Wollie solution has any downsides?;
does it just hides the errors?
maybe i would need to see those error at some point in the future if i change something in my configuration?
or any thing Iām not aware of?
AFAIK, and please someone, if Iām wrong tell me, thereās no down side.
IIRC the change even persisted through my kernel update earlier.
if you want to check for errors this is the proper command to run in a terminal
sudo journalctl -p 3 -xb
