Getting kbct to work with Manjaro Sway
I’ve switched over from I3 to Sway on Manjaro.
I’m trying to remap my capslock to leftctrl
My research finds that kbct is a utility that doesn’t rely on X, which I’m trying to stay away from and use Wayland only.
I’ve installed kbct, did modprobe uinput followed by systemctrl start kbct. I followed up with systemctrl enable kbct.
I’ve got two config file, one at /etc/kbct/config.yaml and one at ~/.config/kbct.yaml
They are both set as follows:
  • keyboards: [“Logitech MX Keys”]
    keymap:
    capslock: leftctrl
  1. When I do ps -e | grep ‘kb’, I don’t see a kbct service.
  2. The mapping I want is not happening
Any help would be much appreciated
Not familiar with all the formatting codes. the bullet before keyboard is really minus.
capslock: leftctrl is indented correctly below keymap:
Ok. I found a solution that works. It doesn’t require kbct at all.
Step 1 Find the input device Identifier for your keyboard using swaymsg -t get_inputs . (you need that ‘.’ at the end
Step 2 Add this to entry to ~/.config/sway/config:
input "<the identifier from step 1>"
(indented) xkb_options ctrl:nocaps
Step 3 reboot
