EOL means???
End Of Life
You should have used xfce(or kde). as these two are the most tested and supported by manjaro and community. Errors on these de are instantly solved. Whether on gnome, it’s pretty slow and risky.
End Of Life
so whould i change kernel to another one …
if yes than which one
The DE is irrelevant in this case, the reason it won’t install is because the kernel headers aren’t installed.
I always use linux-zen as my kernel.
Going to change kernel to LtS And Recommend One
You will need to install the kernel headers for which ever kernel you are using before you can install the driver.
How to install it brother
I wouldn’t recommend that, as linux-lts is like for servers which don’t use modern hardware. On the other hand, the linux original kernel supports much more hardware and is recommneded for desktops and laptops which use modern hardware.
For you current kernel sudo pacman -S linux59-headers
Then try installing the driver again
https://wiki.manjaro.org/index.php?title=Manjaro_Kernels
Everything you need to know about kernels and headers…
from the comment AUR (en) - 8188fu-kelebek333-dkms-git, use the solution from Realtek WiFi Driver Installation (AUR) - Tutorials - Manjaro Linux Forum. That should do it. Just follow the instructions as per your needs.
Brother i know how to install driver in ubuntu but not in manjaro if you want i can give you cmds will it help or not🤔
Use the command above to install the headers (I think *ubuntu install them by default) then install the driver
sudo pacman -S linux59-headers ✔
[sudo] password for ayush:
warning: linux59-headers-5.9.16-1 is up to date -- reinstalling
resolving dependencies...
Packages (1) linux59-headers-5.9.16-1
Total Installed Size: 48.27 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [######################] 100%
(1/1) checking package integrity [######################] 100%
(1/1) loading package files [######################] 100%
(1/1) checking for file conflicts [######################] 100%
(1/1) checking available disk space [######################] 100%
(1/2) Remove upgraded DKMS modules
==> dkms remove --no-depmod -m 8188fu -v r86.21813e9 -k 5.9.16-1-MANJARO
==> dkms remove --no-depmod -m rtl8812au -v 5.9.3.2.r8.gb95e750 -k 5.9.16-1-MANJARO
==> Unable to remove module rtl8822bu/20180723 for kernel 5.9.16-1-MANJARO: Not found in dkms status output.
(2/2) Save Linux kernel modules
(1/1) reinstalling linux59-headers [######################] 100%
(1/4) Arming ConditionNeedsUpdate...
(2/4) Updating module dependencies...
(3/4) Install DKMS modules
==> dkms install --no-depmod -m 8188fu -v r86.21813e9 -k 5.9.16-1-MANJARO
stuck here
Final Solution (Provided By Community Memmbers):
Update You Kernel Headers
And Than Try Installing Driver See This
You Problem Gets Solved
Worked For Me😁
