Hey Guys I Am Getting Error While Installing AUR Package In Add/Remove Software
Error While Configuring β¦
Can Anyone Tell Solution Of This Problem
Trying to download wifi driver
This Is Must Needed Package For Me Bcz It Is Essential For My Wifi Dongle
NGr
January 21, 2021, 2:34pm
2
Have you tried pamac build <name of package>
? You might get more details of the actual error.
Please add more information. Like what was the problem, what u wanted to install, what did u try and stuff.
https://aur.archlinux.org/packages/8188fu-kelebek333-dkms-git/
Getting error with
Error: no operation specified (use -h for help)
What errors did u get? Did you try to build it?
I always use these commands:-
git clone https://aur.archlinux.org/packages/[package-name].git
cd [package-name]
makepkg -i
git clone https://aur.archlinux.org/packages/8188fu-kelebek333-dkms-git.git ξ² 128 β
Cloning into '8188fu-kelebek333-dkms-git'...
fatal: repository 'https://aur.archlinux.org/packages/8188fu-kelebek333-dkms-git.git/' not found
Throws This Error
Try this:-
pacman -S 8188fu-kelebek333-dkms-git
systemctl enable wpa_supplicant@wlp0s20f0u2
sudo pacman -S 8188fu-kelebek333-dkms-git ξ² 1 β
error: target not found: 8188fu-kelebek333-dkms-git
chomsky
January 21, 2021, 2:46pm
10
pamac build 8188fu-kelebek333-dkms-git
NGr
January 21, 2021, 2:47pm
12
It works here, so the link is correct
git clone https://aur.archlinux.org/8188fu-kelebek333-dkms-git.git
remote: Enumerating objects: 58, done.
remote: Counting objects: 100% (58/58), done.
remote: Compressing objects: 100% (46/46), done.
remote: Total 58 (delta 12), reused 54 (delta 10), pack-reused 0
Unpacking objects: 100% (58/58), 20.46 KiB | 952.00 KiB/s, done.
pamac build 8188fu-kelebek333-dkms-git ξ² β
Preparing...
Cloning 8188fu-kelebek333-dkms-git build files...
Checking 8188fu-kelebek333-dkms-git dependencies...
Warning: downgrading package 8188fu-kelebek333-dkms-git (r86.21813e9-1 => r84.b01ebdf-1)
Resolving dependencies...
Checking inter-conflicts...
To build (1):
8188fu-kelebek333-dkms-git r84.b01ebdf-1 (r86.21813e9-1) AUR
Edit build files : [e]
Apply transaction ? [e/y/N] y
Building 8188fu-kelebek333-dkms-git...
==> Making package: 8188fu-kelebek333-dkms-git r86.21813e9-1 (Thu 21 Jan 2021 08:17:55 PM IST)
==> Retrieving sources...
-> Updating 8188fu git repo...
Fetching origin
-> Found blacklist-r8188fu.conf
-> Found dkms.conf
8188fu ... Skipped
blacklist-r8188fu.conf ... Passed
dkms.conf ... Passed
==> Extracting sources...
-> Creating working copy of 8188fu git repo...
Cloning into '8188fu'...
done.
==> Starting prepare()...
==> Starting pkgver()...
==> Entering fakeroot environment...
==> Starting package()...
==> Tidying install...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Stripping unneeded symbols from binaries and libraries...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "8188fu-kelebek333-dkms-git"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Adding install file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: 8188fu-kelebek333-dkms-git r86.21813e9-1 (Thu 21 Jan 2021 08:18:03 PM IST)
==> Cleaning up...
Checking keyring... [1/1]
Checking integrity... [1/1]
Loading packages files... [1/1]
Checking file conflicts... [1/1]
Checking available disk space... [1/1]
==> Unable to remove module 8188fu/r86.21813e9 for kernel 5.9.16-1-MANJARO: Not found in dkms status output.
Deleting module version: r86.21813e9
completely from the DKMS tree.
Done.
Configuring 8188fu-kelebek333-dkms-git... [1/1]
Creating symlink /var/lib/dkms/8188fu/r86.21813e9/source ->
/usr/src/8188fu-r86.21813e9
DKMS: add completed.
Error! echo
Error while configuring 8188fu-kelebek333-dkms-git
Your kernel headers for kernel 5.9.16-1-MANJARO cannot be found at
/usr/lib/modules/5.9.16-1-MANJARO/build or /usr/lib/modules/5.9.16-1-MANJARO/source.
You can use the --kernelsourcedir option to tell DKMS where it's located.
Error: 8188fu-kelebek333-dkms-git: command failed to execute correctly
Arming ConditionNeedsUpdate... [1/2]
Install DKMS modules [2/2]
==> Unable to install module 8188fu/r86.21813e9 for kernel 5.9.16-1-MANJARO: Missing kernel headers.
Transaction successfully finished
makepkg -i ξ² β
==> Making package: 8188fu-kelebek333-dkms-git r84.b01ebdf-2 (Thu 21 Jan 2021 08:19:35 PM IST)
-> Cloning 8188fu git repo...
Cloning into bare repository '/home/ayush/8188fu-kelebek333-dkms-git/8188fu'...
remote: Enumerating objects: 11, done.
remote: Counting objects: 100% (11/11), done.
remote: Compressing objects: 100% (11/11), done.
remote: Total 864 (delta 4), reused 0 (delta 0), pack-reused 853
Receiving objects: 100% (864/864), 8.85 MiB | 2.16 MiB/s, done.
Resolving deltas: 100% (434/434), done.
-> Found dkms.conf
8188fu ... Skipped
done.
==> Updated version: 8188fu-kelebek333-dkms-git r86.21813e9-1
==> Finished making: 8188fu-kelebek333-dkms-git r86.21813e9-1 (Thu 21 Jan 2021 08:19:49 PM IST)
==> Installing package 8188fu-kelebek333-dkms-git with pacman -U...
[sudo] password for ayush:
loading packages...
warning: 8188fu-kelebek333-dkms-git-r86.21813e9-1 is up to date -- reinstalling
resolving dependencies...
Packages (1) 8188fu-kelebek333-dkms-git-r86.21813e9-1
Total Installed Size: 9.33 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [######################] 100%
(1/1) checking package integrity [######################] 100%
(1/1) loading package files [######################] 100%
(1/1) checking for file conflicts [######################] 100%
(1/1) checking available disk space [######################] 100%
(1/1) Remove upgraded DKMS modules
Done.
(1/1) reinstalling 8188fu-kelebek333-dkms-git [######################] 100%
Error! echo
error: command failed to execute correctly
(1/2) Arming ConditionNeedsUpdate...
(2/2) Install DKMS modules
Damn, hire a professional man, this is beyond us.
NGr
January 21, 2021, 2:52pm
16
You need to install the kernel headers, in your case it will be linux59-headers
Which kernel are you currently using, which desktop environment, and is your manjaro up-to-date?
that should depend on it.
kernel : linux 5.9.16-1 (linux 59)
enviroment : gnome
and fully updated
chomsky
January 21, 2021, 2:56pm
20
That kernel is EOL I would switch to linux510 or linux54 and install the kernel headers then execute the pamac build command again.
