Okay thanks
Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=4dabba46-d73a-4342-96f5-859c2418cd86 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Desktop System: Gigabyte product: B460MDS3H v: N/A serial: <filter>
Mobo: Gigabyte model: B460M DS3H v: x.x serial: <filter>
UEFI: American Megatrends v: F3 date: 05/27/2020
RAM: total: 15.56 GiB used: 922.4 MiB (5.8%)
Info: 6-Core model: Intel Core i5-10500 bits: 64 type: MT MCP
arch: Comet Lake family: 6 model-id: A5 (165) stepping: 3 microcode: EA
cache: L2: 12 MiB bogomips: 74427
Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:1c82 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 94 size: 521x293mm (20.5x11.5")
diag: 598mm (23.5")
OpenGL: renderer: NV137 v: 4.3 Mesa 21.2.1 direct render: Yes
Device-1: Intel vendor: Gigabyte driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a3f0
class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Device-3: Corsair CORSAIR HS60 HAPTIC Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-6:5 chip-ID: 1b1c:0a5f
class-ID: 0300
Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: no
vendor: Gigabyte driver: r8169 v: kernel port: 4000 bus-ID: 03:00.0
Device-2: Realtek RTL8192EE PCIe Wireless Network Adapter driver: rtl8192ee
v: kernel port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:818b class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Local Storage: total: 1.03 TiB used: 10.83 GiB (1.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Gigabyte model: GP-GSTFS31120GNTD
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 61.3 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM010-2EP102
type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Kingston
model: DataTraveler SE9 size: 14.64 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 111.49 GiB size: 109.18 GiB (97.93%)
used: 10.83 GiB (9.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 4dabba46-d73a-4342-96f5-859c2418cd86
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 4D27-D28D
ID-1: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ntfs label: DATA
uuid: 0C0E8D9D0E8D8086
ID-2: /dev/sdc1 maj-min: 8:33 size: 14.64 GiB fs: vfat label: MISO_EFI
uuid: E08E-BD72
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Hub-2: 1-3:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-3.1:4 info: SINOWEALTH Wired Gaming Mouse type: Mouse,Keyboard
driver: glorious,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 480mA
chip-ID: 258a:0036 class-ID: 0301
Device-2: 1-3.2:6 info: Holtek USB Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 04d9:a01b class-ID: 0300
Device-3: 1-3.3:9 info: SHARKOON Mechanical Keyboard type: Keyboard
power: 500mA chip-ID: 1ea7:0077 class-ID: 0301
Hub-3: 1-4:13 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-4.3:14 info: Micro Star MSI Gaming Controller type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 1462:3fa4 class-ID: 0300 serial: <filter>
Device-2: 1-5:15 info: Kingston DataTraveler SE9 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 0951:1689 class-ID: 0806 serial: <filter>
Device-3: 1-6:5 info: Corsair CORSAIR HS60 HAPTIC Gaming Headset
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 1b1c:0a5f class-ID: 0300
Hub-4: 1-9:8 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-5: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.0 speed: 5 Gb/s
Hub-6: 2-3:2 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
System Temperatures: cpu: 27.8 C mobo: 16.8 C gpu: nouveau temp: 35.0 C
Processes: 251 Uptime: 8h 4m wakeups: 0 Init: systemd v: 248 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1044 lib: 303 flatpak: 0 Shell: Bash
v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06
oh one sec, someone messed with my ethernet cables - thats got the wrong network settings, it says there is no internet there but there was before - i’ll fix that, one sec.
oh shoot it seems like its downloading… maybe something got fixed? it downloaded
