It appears that my webcam isn't listed in "Select Camera Device", what do I do now?
My camera is Powerlogic 812h, it was working in Windows 10, how do I make it work in Manjaro.
Please help.
Hi and welcome to the forum :wink:
(Going by your way of asking)
To give any meaningful advice, you need to help others to help you:
  • Describe in as much details what application you are using, so people who want to help (or are able to) know where you don’t get that selection.
  • Provide info about your hardware
In System Settings>Removable Devices>Digital Camera>Add(Select Camera Device)
My camera isn’t listed (Powerlogic 812h)
manjaro-log-helper.logs
Generated on 2020-12-23 22:18:1608733082
#################### inxi -Fxzc0 ########################
System:    Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
           Desktop: KDE Plasma 5.20.4 Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: EMAXX model: EMX-A70FM2+iCafe serial: <filter>
           UEFI [Legacy]: American Megatrends v: 4.6.5 date: 04/13/2016
CPU:       Info: Quad Core model: AMD A8-7600 Radeon R7 10 Compute Cores 4C+6G bits: 64 type: MCP
           arch: Steamroller rev: 1 L2 cache: 2048 KiB
           flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 24761
           Speed: 1449 MHz min/max: 1400/3100 MHz boost: enabled Core speeds (MHz): 1: 1449
           2: 1484 3: 1397 4: 1397
Graphics:  Device-1: AMD Kaveri [Radeon R7 Graphics] driver: radeon v: kernel bus ID: 00:01.0
           Display: x11 server: X.Org 1.20.10 driver: ati,radeon unloaded: modesetting
           resolution: 1366x768~60Hz
           OpenGL: renderer: AMD KAVERI (DRM 2.50.0 5.9.11-3-MANJARO LLVM 11.0.0)
           v: 4.5 Mesa 20.2.3 direct render: Yes
Audio:     Device-1: AMD Kaveri HDMI/DP Audio driver: snd_hda_intel v: kernel bus ID: 00:01.1
           Device-2: AMD FCH Azalia vendor: Biostar Microtech Intl Corp driver: snd_hda_intel
           v: kernel bus ID: 00:14.2
           Sound Server: ALSA v: k5.9.11-3-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
           vendor: Biostar Microtech Intl Corp driver: r8169 v: kernel port: e000 bus ID: 01:00.0
           IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 465.76 GiB used: 44.97 GiB (9.7%)
           ID-1: /dev/sda vendor: Seagate model: ST3500414CS size: 465.76 GiB
Partition: ID-1: / size: 124.46 GiB used: 14.87 GiB (11.9%) fs: ext4 dev: /dev/sda1
           ID-2: /home size: 328.64 GiB used: 30.06 GiB (9.1%) fs: ext4 dev: /dev/sda3
Swap:      ID-1: swap-1 type: partition size: 3.91 GiB used: 40.2 MiB (1.0%) dev: /dev/sda2
Sensors:   System Temperatures: cpu: 16.0 C mobo: N/A gpu: radeon temp: 13.0 C
Info:      Processes: 200 Uptime: 39m Memory: 3.27 GiB used: 1.96 GiB (59.9%) Init: systemd
           Compilers: gcc: 10.2.0 Packages: 1386 Client: KDE Plasma v: 5.20.4 inxi: 3.1.08
lsusb in Terminal
Bus 009 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 003: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 002 Device 002: ID 1c4f:0016 SiGma Micro USB Keyboard
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Edited for formating
I assume your camera is an USB device right?
Can you perform these steps:
  1. Make sure your camera is unpluged.
  2. Open a terminal.
  3. Execute journalctl -f
  4. Post the output you get after you plug your Camera in a USB port.
    (Use ``` on separate lines, before and after, the output)
-- Logs begin at Tue 2020-12-22 13:21:48 PST. --
Dec 24 01:29:10 Lighthal rtkit-daemon[1237]: Supervising 7 threads of 4 processes of 1 users.
Dec 24 01:29:36 Lighthal rtkit-daemon[1237]: Supervising 7 threads of 4 processes of 1 users.
Dec 24 01:29:36 Lighthal rtkit-daemon[1237]: Successfully made thread 30959 of process 26141 owned by '1000' RT at priority 10.
Dec 24 01:29:36 Lighthal rtkit-daemon[1237]: Supervising 8 threads of 5 processes of 1 users.
Dec 24 01:30:21 Lighthal systemd[1025]: Started Konsole - Terminal.
Dec 24 01:30:24 Lighthal kwin_x11[1118]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29593, resource id: 16901180, major code: 3 (GetWindowAttributes), minor code: 0
Dec 24 01:30:24 Lighthal kwin_x11[1118]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 29594, resource id: 16901180, major code: 14 (GetGeometry), minor code: 0
Dec 24 01:30:33 Lighthal kwin_x11[1118]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31091, resource id: 98566155, major code: 18 (ChangeProperty), minor code: 0
Dec 24 01:32:49 Lighthal baloo_file_extractor[31452]: kf.baloo: Not busy, fast indexing
Dec 24 01:34:37 Lighthal kernel: usb 3-3: new high-speed USB device number 2 using ehci-pci
Dec 24 01:34:37 Lighthal kernel: usb 3-3: New USB device found, idVendor=1d6c, idProduct=0103, bcdDevice= 0.10
Dec 24 01:34:37 Lighthal kernel: usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 24 01:34:37 Lighthal kernel: usb 3-3: Product: webcam
Dec 24 01:34:37 Lighthal kernel: usb 3-3: Manufacturer: webcam
Dec 24 01:34:37 Lighthal mtp-probe[31688]: checking bus 3, device 2: "/sys/devices/pci0000:00/0000:00:12.2/usb3/3-3"
Dec 24 01:34:37 Lighthal mtp-probe[31688]: bus: 3, device: 2 was not an MTP device
Dec 24 01:34:39 Lighthal kernel: usbcore: registered new interface driver snd-usb-audio
Dec 24 01:34:39 Lighthal kernel: uvcvideo: Found UVC 1.00 device webcam (1d6c:0103)
Dec 24 01:34:39 Lighthal kernel: input: webcam as /devices/pci0000:00/0000:00:12.2/usb3/3-3/3-3:1.0/input/input15
Dec 24 01:34:39 Lighthal kernel: usbcore: registered new interface driver uvcvideo
Dec 24 01:34:39 Lighthal kernel: USB Video Class driver (1.1.1)
Dec 24 01:34:39 Lighthal mtp-probe[31745]: checking bus 3, device 2: "/sys/devices/pci0000:00/0000:00:12.2/usb3/3-3"
Dec 24 01:34:39 Lighthal mtp-probe[31745]: bus: 3, device: 2 was not an MTP device
Dec 24 01:34:40 Lighthal systemd[1025]: Reached target Sound Card.
Dec 24 01:34:42 Lighthal rtkit-daemon[1237]: Supervising 8 threads of 5 processes of 1 users.
Dec 24 01:34:42 Lighthal rtkit-daemon[1237]: Successfully made thread 31764 of process 1208 owned by '1000' RT at priority 5.
Dec 24 01:34:42 Lighthal rtkit-daemon[1237]: Supervising 9 threads of 5 processes of 1 users.
Dec 24 01:35:35 Lighthal systemd[1]: flatpak-system-helper.service: Succeeded.
Dec 24 01:35:35 Lighthal kernel: audit: type=1131 audit(1608744935.070:197): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=flatpak-system-helper comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 24 01:35:35 Lighthal audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=flatpak-system-helper comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 24 01:37:53 Lighthal baloo_file_extractor[32250]: kf.baloo: Not busy, fast indexing
Dec 24 01:39:00 Lighthal baloo_file_extractor[32398]: kf.baloo: Not busy, fast indexing
Dec 24 01:40:02 Lighthal kwin_x11[1118]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 4823, resource id: 25166433, major code: 73 (GetImage), minor code: 0
Dec 24 01:40:02 Lighthal kwin_x11[1118]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 4824, resource id: 25166433, major code: 73 (GetImage), minor code: 0
Dec 24 01:40:02 Lighthal kwin_x11[1118]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 4825, resource id: 25166433, major code: 73 (GetImage), minor code: 0
Does v4l2-ctl --list-devices show the device?
Yes
webcam (usb-0000:00:12.2-3):
        /dev/video0
        /dev/video1
This part was the info asked for :wink:
Which shows the Camera is recognized by Linux.
The output you provided of the command from @pobrn confirms that fact even more…
As can be seen in those log-lines above, your camera is recognized as a “webcam” made by “webcam”, there is no mention of “Powerlogic 812h” there.
Maybe you expected it to be listed like that instead?
Never mind, I installed “Kamoso”, my camera worked. I didn’t know that Manjaro doesn’t have this app out of the box like Windows 10.
Thanks for your time.
This topic was automatically closed 8 hours after the last reply. New replies are no longer allowed.
