Looking at some of the other posts here I probably just have the wrong driver installed. The default was not allowing me to search for wi-fi networks, and neither did the rtl88x2bu-dkms-git
package via pamac.
Hopefully helpful and relevant info:
KDE Plasma Version: 5.26.4
KDE Frameworks Version: 5.101.0
Qt Version: 5.15.7
Kernel Version: 6.1.1-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 16 × AMD Ryzen 7 5825U with Radeon Graphics
Memory: 15.0 GiB of RAM
Graphics Processor: AMD Radeon Graphics
Manufacturer: Acer
Product Name: Aspire A515-47
System Version: V1.01
Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek driver: N/A pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:b852 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 0bda:886b class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 18.37 GiB (3.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ512HBLU-00B00
lanes: 4 type: SSD serial: <filter> rev: FXM7301Q temp: 25.9 C scheme: GPT
ID-1: / raw-size: 343.24 GiB size: 336.78 GiB (98.12%) used: 18.32 GiB (5.4%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: a9cb4477-d674-4e06-9722-f8983705f919
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 55 MiB (21.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: ESP
uuid: F695-B7E3
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 128.43 GiB fs: ntfs label: Acer
uuid: 602896E42896B88C
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1024 MiB fs: ntfs label: Recovery
uuid: 7A8C98858C983D97
ID-4: /dev/nvme0n1p6 maj-min: 259:6 size: 4 GiB fs: vfat label: N/A
uuid: 3014-0061
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-3:2 info: Chicony ACER HD User Facing type: Video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 04f2:b773 class-ID: fe01 serial: <filter>
Device-2: 1-4:3 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA chip-ID: 0bda:886b
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 39.9 C mobo: N/A gpu: amdgpu temp: 34.0 C
Processes: 305 Uptime: 18m wakeups: 1309 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1259 libs: 422 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
sudo lshw -C network 1 ✘ 5s
[sudo] password for gray:
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:01:00.0
logical name: enp1s0
version: 15
serial: 08:8f:c3:6d:31:15
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=6.1.1-1-MANJARO duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 ip=192.168.0.32 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:81 ioport:3000(size=256) memory:c0904000-c0904fff memory:c0900000-c0903fff
*-network UNCLAIMED
description: Network controller
product: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:02:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress cap_list
configuration: latency=0
resources: ioport:2000(size=256) memory:c0800000-c08fffff
iwconfig 127 ✘ 15s
lo no wireless extensions.
enp1s0 no wireless extensions.
rfkill list ✔
0: acer-wireless: Wireless LAN
Soft blocked: no
Hard blocked: no
1: acer-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
2: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
I just installed the r8168-dkms and I’ll try restarting to see if that works. Thank you so much for your help!
