hi there! there’s an update currently on my machine that simply wouldn’t run till the end. it’s the AUR gcc 12 update.
this is what it gives in the end:
make: Leaving directory '/var/tmp/pamac-build-arnonart/gcc12/src/gcc-build/gcc'
==> Tidying install...
-> Removing empty directories...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Stripping unneeded symbols from binaries and libraries...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> WARNING: Package contains reference to $srcdir
usr/lib/gcc/x86_64-pc-linux-gnu/12.5.0/f951
usr/lib/gcc/x86_64-pc-linux-gnu/12.5.0/libcaf_single.a
usr/bin/x86_64-pc-linux-gnu-gfortran-12
usr/bin/gfortran-12
==> Creating package "gcc12-fortran"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: gcc12 12.5.0-2 (pe 29. elokuuta 2025 14.36.55)
==> Cleaning up...
is there anything to do?
Thanks.
