Gammastep. I updated so X is gone
For the list of options:
gammastep -h
I just installed & ran gammastep -h on my mini-PC:
gammastep -h
Usage: gammastep -l LAT:LON -t DAY:NIGHT [OPTIONS...]
Set color temperature of display according to time of day.
  -h            Display this help message
  -v            Increase logging verbosity
  -q            Decrease logging verbosity
  -V            Show program version
  -b DAY:NIGHT  Screen brightness to apply (between 0.1 and 1.0)
  -c FILE       Load settings from specified configuration file
  -g R:G:B      Additional gamma correction to apply
  -l LAT:LON    Your current location
  -l PROVIDER   Select provider for automatic location updates
                (Type `list' to see available providers)
  -m METHOD     Method to use to set color temperature
                (Type `list' to see available methods)
  -o            One shot mode (do not continuously adjust color temperature)
  -O TEMP       One shot manual mode (set color temperature)
  -p            Print mode (only print parameters and exit)
  -P            Reset existing gamma ramps before applying new color effect
  -x            Reset mode (remove adjustment from screen)
  -r            Disable fading between color temperatures
  -t DAY:NIGHT  Color temperature to set at daytime/night
The neutral temperature is 6500K. Using this value will not change the color
temperature of the display. Setting the color temperature to a value higher
than this results in more blue light, and setting a lower value will result in
more red light.
Default values:
  Daytime temperature: 6500K
  Night temperature: 4500K
Please report bugs to <https://gitlab.freedesktop.org/CameronNemo/gammastep/issues>
Although I will be uninstalling it now, as Plasma’s System Settings (Night Light, and Day-Night Cycle) fit my requirements.
Can I get a gui front end?
