Hello,
Since my latest update I’ve got a problem with my system. Games are being rendered at high FPS but even though I have a 240hz I only get to see 60fps. The issue is only present when I have other screens plugged in aswell. I’d much prefer being able to play games at high fps without having to unplug/turn off my other screens. Does anyone know what option or configuration is tripping me up?
Kernel: 5.10.181-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=d49ece73-c2ab-457c-9def-fad054c75d42 rw quiet splash apparmor=1
Desktop: GNOME v: 44.1 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.1
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 3.70
date: 06/09/2020
System RAM: available: 15.64 GiB used: 7.22 GiB (46.2%)
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 4199 high: 4200
min/max: 2200/5627:5471:5320:5164:6095:5939:5783 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 4200 2: 4200 3: 4200
4: 4199 5: 4200 6: 4200 7: 4200 8: 4200 9: 4200 10: 4200 11: 4200 12: 4200
13: 4200 14: 4200 15: 4200 16: 4200 bogomips: 134457
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: eVga.com. driver: nvidia
v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 26:00.0
chip-ID: 10de:1b06 class-ID: 0300
Display: x11 server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
screens: 1
Screen-1: 0 s-res: 6400x1440 s-size: <missing: xdpyinfo>
Monitor-1: DP-0 pos: middle-r res: 1920x1080 hz: 60 dpi: 92
size: 531x299mm (20.91x11.77") diag: 609mm (23.99") modes: N/A
Monitor-2: DP-4 pos: primary,top-center res: 2560x1440 dpi: 65024
size: 1x1mm (0.04x0.04") diag: 1mm (0.06") modes: N/A
Monitor-3: HDMI-0 pos: bottom-l res: 1920x1080 hz: 60 dpi: 92
size: 531x298mm (20.91x11.73") diag: 609mm (23.97") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce GTX 1080
Ti/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GP102 HDMI Audio vendor: eVga.com. driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 26:00.1
chip-ID: 10de:10ef class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 28:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Yamaha Steinberg UR22mkII driver: snd-usb-audio type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9.1:4
chip-ID: 0499:170f class-ID: 0103
API: ALSA v: k5.10.181-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
Device-1: Realtek RTL8192EE PCIe Wireless Network Adapter driver: rtl8192ee
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 21:00.0
chip-ID: 10ec:818b class-ID: 0280
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: down mac: <filter>
Device-1: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive
Info: report: N/A blocks: 1948779648 chunk-size: N/A
Components: Online: N/A Spare:
1: sdc5 maj-min: 8:37 size: 1.81 TiB state: S
Local Storage: total: 4.09 TiB used: 355.47 GiB (8.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EFRX-68AX9N0
tech: N/A serial: <filter> fw-rev: 0A80 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD20EFRX-68AX9N0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A80
scheme: MBR
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 355.47 GiB (77.8%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: d49ece73-c2ab-457c-9def-fad054c75d42
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: 1C00-9DB6
ID-1: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: ext4 label: N/A
uuid: d6eeb44c-82ef-4cfd-ae31-e806aafdd066
ID-2: /dev/sdc3 maj-min: 8:35 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
Hub-2: 1-8:2 info: Genesys Logic Hub ports: 2 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
Hub-3: 1-9:3 info: Microchip (formerly SMSC) ports: 1 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA chip-ID: 0424:2422
Device-1: 1-9.1:4 info: Yamaha Steinberg UR22mkII type: audio
driver: snd-usb-audio interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0499:170f class-ID: 0103
Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Logitech G910 Orion Spectrum Mechanical Keyboard
type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c335 class-ID: 0300 serial: <filter>
Device-2: 3-2:3 info: Logitech G502 Proteus Spectrum Optical Mouse
type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
chip-ID: 046d:c332 class-ID: 0300 serial: <filter>
Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 69.0 C mobo: N/A
Processes: 451 Uptime: 44m wakeups: 0 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1615
pm: pacman pkgs: 1577 libs: 497 tools: gnome-software,pamac pm: flatpak
pkgs: 24 pm: snap pkgs: 14 Shell: Zsh v: 5.9 running-in: gnome-terminal
inxi: 3.3.27
