I have bought a Dell XPS 13 9300 last May and I have seen in ArchLinux wiki that the fingerprint sensor has finally a driver and that it works well on Ubuntu
So I followed the instructions
Rebooted
But then, when going in Gnome Control center
Users
FingerPrint login
I get the following message
Could not access any fingerprint readers
Please contact your system administrator for help.
Does anyone managed to successfully configure it ?
I’ve marked the below answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
P.P.S. As I’m an editor here on the site, I’ve also changed your links into clickable links…
