This happens very randomly , Previous with CSGO and now with Apex legends. I can sometimes play for hours without any problem and sometimes it would crash in 30 minutes or even 5 minutes after launching the game. Sometimes the audio works and the display freezes completely but most of the times everything freezes including audio and voice chat in discord or teamspeak, and only fix is REISUB.
This is what I found in my journalctl before I REISUBed :
Apr 18 13:02:22 poop kernel: audit: type=1334 audit(1650267142.010:110): prog-id=0 op=UNLOAD
Apr 18 13:02:22 poop kernel: audit: type=1334 audit(1650267142.010:111): prog-id=0 op=UNLOAD
Apr 18 13:02:22 poop audit: BPF prog-id=0 op=UNLOAD
Apr 18 13:02:22 poop kernel: audit: type=1334 audit(1650267142.026:112): prog-id=0 op=UNLOAD
Apr 18 13:02:22 poop kernel: audit: type=1334 audit(1650267142.026:113): prog-id=0 op=UNLOAD
Apr 18 13:02:22 poop kernel: audit: type=1334 audit(1650267142.026:114): prog-id=0 op=UNLOAD
Apr 18 13:02:23 poop kernel: sr 2:0:0:0: [sr0] tag#14 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age>
Apr 18 13:02:23 poop kernel: sr 2:0:0:0: [sr0] tag#14 Sense Key : Not Ready [deferred]
Apr 18 13:02:23 poop kernel: sr 2:0:0:0: [sr0] tag#14 Add. Sense: Medium not present - tray closed
Apr 18 13:02:23 poop kernel: sr 2:0:0:0: [sr0] tag#14 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00
Apr 18 13:02:23 poop kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_se>
Apr 18 13:02:23 poop kernel: sr 2:0:0:0: [sr0] tag#8 unaligned transfer
Apr 18 13:02:23 poop kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 >
Apr 18 13:02:23 poop kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Apr 18 13:02:23 poop kernel: sr 2:0:0:0: [sr0] tag#9 unaligned transfer
Apr 18 13:02:23 poop kernel: blk_update_request: I/O error, dev sr0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 >
Apr 18 13:02:23 poop kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Apr 18 13:02:23 poop kernel: sr 2:0:0:0: [sr0] tag#10 unaligned transfer
Apr 18 13:02:23 poop kernel: blk_update_request: I/O error, dev sr0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 >
Apr 18 13:02:23 poop kernel: Buffer I/O error on dev sr0, logical block 2, async page read
Apr 18 13:02:23 poop kernel: sr 2:0:0:0: [sr0] tag#11 unaligned transfer
Apr 18 13:02:23 poop kernel: blk_update_request: I/O error, dev sr0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 >
Apr 18 13:02:23 poop kernel: Buffer I/O error on dev sr0, logical block 3, async page read
Apr 18 13:02:23 poop kernel: sr 2:0:0:0: [sr0] tag#12 unaligned transfer
Apr 18 13:02:23 poop kernel: blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 >
Apr 18 13:02:23 poop kernel: Buffer I/O error on dev sr0, logical block 4, async page read
Apr 18 13:02:23 poop kernel: sr 2:0:0:0: [sr0] tag#15 unaligned transfer
Apr 18 13:02:23 poop kernel: blk_update_request: I/O error, dev sr0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 >
Apr 18 13:02:23 poop kernel: Buffer I/O error on dev sr0, logical block 5, async page read
Apr 18 13:02:23 poop kernel: sr 2:0:0:0: [sr0] tag#19 unaligned transfer
Apr 18 13:02:23 poop kernel: blk_update_request: I/O error, dev sr0, sector 6 op 0x0:(READ) flags 0x0 phys_seg 1 >
Apr 18 13:02:23 poop kernel: Buffer I/O error on dev sr0, logical block 6, async page read
Apr 18 13:02:23 poop kernel: sr 2:0:0:0: [sr0] tag#20 unaligned transfer
Apr 18 13:02:23 poop kernel: blk_update_request: I/O error, dev sr0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 >
Apr 18 13:02:23 poop kernel: Buffer I/O error on dev sr0, logical block 7, async page read
Apr 18 13:02:28 poop kernel: sr 2:0:0:0: [sr0] tag#7 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=>
Apr 18 13:02:28 poop kernel: sr 2:0:0:0: [sr0] tag#7 Sense Key : Not Ready [deferred]
Apr 18 13:02:28 poop kernel: sr 2:0:0:0: [sr0] tag#7 Add. Sense: Medium not present - tray closed
Apr 18 13:02:28 poop kernel: sr 2:0:0:0: [sr0] tag#7 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00
Apr 18 13:02:28 poop kernel: blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_se>
Apr 18 13:02:28 poop kernel: sr 2:0:0:0: [sr0] tag#8 unaligned transfer
Apr 18 13:02:28 poop kernel: Buffer I/O error on dev sr0, logical block 0, async page read
Apr 18 13:02:28 poop kernel: sr 2:0:0:0: [sr0] tag#9 unaligned transfer
Apr 18 13:02:28 poop kernel: Buffer I/O error on dev sr0, logical block 1, async page read
Apr 18 13:02:28 poop kernel: sr 2:0:0:0: [sr0] tag#10 unaligned transfer
Apr 18 13:02:28 poop kernel: sr 2:0:0:0: [sr0] tag#12 unaligned transfer
Apr 18 13:02:28 poop kernel: sr 2:0:0:0: [sr0] tag#13 unaligned transfer
Apr 18 13:02:28 poop kernel: sr 2:0:0:0: [sr0] tag#14 unaligned transfer
Apr 18 13:02:28 poop kernel: sr 2:0:0:0: [sr0] tag#15 unaligned transfer
Apr 18 13:02:28 poop kernel: sr 2:0:0:0: [sr0] tag#16 unaligned transfer
Apr 18 13:02:33 poop xdg-desktop-por[1148]: Failed to get application states: GDBus.Error:org.freedesktop.portal.>
Apr 18 13:04:46 poop wpa_supplicant[872]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-49 noise=9999 txrate=4>
Apr 18 13:12:33 poop kernel: sysrq: Keyboard mode set to system default
Apr 18 13:12:34 poop systemd-journald[300]: Journal stopped
Apr 18 13:12:34 poop kernel: sysrq: Terminate All Tasks
Apr 18 13:12:34 poop systemd-journald[300]: Received SIGTERM.
The I/O error seems to be a CD/DVD drive error even though there are no disks , and I am not even sure if thats what causes the freeze.
neofetch:
OS: Manjaro Linux x86_64
Host: GL553VE 1.0
Kernel: 5.15.28-1-MANJARO
Uptime: 24 mins
Packages: 1301 (pacman)
Shell: bash 5.1.16
Resolution: 2560x1440
WM: i3
Theme: Sweet-Dark-v40 [GTK2/3]
Icons: candy-icons [GTK2/3]
Terminal: terminator
CPU: Intel i7-7700HQ (8) @ 3.800GHz
GPU: Intel HD Graphics 630
GPU: NVIDIA GeForce GTX 1050 Ti Mobile
Memory: 4285MiB / 15886MiB
inxi -G
Device-1: Intel HD Graphics 630 driver: i915 v: kernel
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] driver: nvidia
v: 510.54
Device-3: Realtek USB2.0 HD UVC WebCam type: USB driver: uvcvideo
Display: x11 server: X.Org v: 1.21.1.3 driver: X:
loaded: modesetting,nvidia unloaded: nouveau gpu: i915
resolution: 2560x1440~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 21.3.7
