Games are using Intel's integrated graphics instead of my dedicated AMD GPU
Hey guys I've just installed Manjaro xfce in my main rig, it has:
I7 6700
AMD Radeon Rx 480
16 gigs of ram
With a z170 mobo.
My setup is quite complicated (I think) I have 2 monitors one is using Intel's integrated graphics through mobo's VGA port and the other is using the DVI port of my rx 480.
When I first tried to launch a game CSGO performance was about 30fps and also low performance in all games, then I tried disabling the integrated GPU in the BIOS menu and then they performed as they should. Bad part is that I can't use my second monitor as usual.
Is there a way to tell the OS to use an specific GPU when running a game??
That way I could run games with my AMD card while using Intel's just for the second monitor.
Thanks in advanced, I'm kind of a newbie in the recent Linux gaming ecosystem but thanks to the community I have already solved a lot of issues I had.
Start with
$ inxi -Fxxxz
and
Important knowledge
When posting output do not use pictures. Pictures is a very last resort.
Please select the text in the terminal
Paste the text into a the post
Select the newly pasted text in the post
Click the </> icon in the post toolbar
This creates nicely formatted text which is readable and searchable for other users after you.
(Text was copied from @ linux-aarhus)
For helpful answers, just click on the heart ...
grafik
Try this
DRI_PRIME=1 [command]
And if posting pictures, please use another service instead of the forums to upload pictures. Bandwidth is costly :stuck_out_tongue:
for steam games it's
DRI_PRIME=1 %command%
in the steam launch options (%command% will stay that way, you really type in %command%, this is not a placeholder for something)
