Gamepads are not always detected by the system
So basically overnight the system stopped detecting my PS4 compatible USB Gamepad (there was no update). I thought it was the controllers fault, I bought another one, an XBOX compatible Gamepad, same results. Right before posting about this issue I run lsusb several times while the gamepads were connected, the results:
[oracle911@home-pc ~]$ lsusb
Bus 001 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 001 Device 003: ID 0b05:1872 ASUSTek Computer, Inc. AURA LED Controller
Bus 001 Device 004: ID 04e8:6860 Samsung Electronics Co., Ltd Galaxy series, misc. (MTP mode)
Bus 001 Device 005: ID 062a:4c01 MosArt Semiconductor Corp. 2,4Ghz Wireless Transceiver [for Delux M618 Plus Wireless Vertical Mouse]
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 032: ID 054c:09cc Sony Corp. DualShock 4 [CUH-ZCT2x]
Bus 001 Device 034: ID 054c:09cc Sony Corp. DualShock 4 [CUH-ZCT2x]
Bus 001 Device 035: ID 0079:181c DragonRise Inc. GT-60
Any idea what caused this bug and how to prevent it?
Check hardware. Try it in a different usb port, and if you’re plugging it into a usb hub then try without the hub.
I did not use hub for gamepads and I tried different ports with same results. So…
It’s very strange that it started happening with no update or other change to your system. That usually indicates some kind of hardware failure in my experience, not a bug.
Look for messages about the device in the log. For the PS4 controller
journalctl -b --no-pager | grep 054c
[oracle911@home-pc ~]$ journalctl -b --no-pager | grep 054c
mar 14 14:35:14 home-pc kernel: usb 1-3: New USB device found, idVendor=054c, idProduct=09cc, bcdDevice= 1.00
mar 14 14:42:28 home-pc kernel: usb 1-3: New USB device found, idVendor=054c, idProduct=09cc, bcdDevice= 1.00
mar 14 14:57:40 home-pc kernel: usb 1-3: New USB device found, idVendor=054c, idProduct=09cc, bcdDevice= 1.00
The only thing I can think of which isn’t hardware-related and could be causing this is USB autosuspend. But again, it would very strange for that to suddenly change for no reason.
Anyway you can try either disabling it completely or just blacklisting your device as described in the link above.
OK, thanks, I will look into it
Edit: I do NOT have this rule, file respectively
No-one has that file by default. Create it and add the rule.
