Hey,
today my 8Bitdo SN30 pro+ gamepad arrived. Worked like a charme when I tried it for the first time, bluetooth connected immediately and I started playing for two hours without problems.
Just wanted to start another session and I can’t connect it anymore (Input/output error). Deleted the gamepad from Bluetooth devices and rebooted, but it just won’t connect again. Playing via USB works, though.
May anyone help me troubleshoot? Thanks a lot!
inxi -Fazy:
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=195ea558-b5d4-4789-b440-595bf058771d rw quiet apparmor=1
security=apparmor resume=UUID=7f391a74-a843-4390-98a5-36e7b1d6322f
udev.log_priority=3 i915.enable_dpcd_backlight=0
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 info: plank wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: Dell product: XPS 15 7590 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0VYV0G v: A00 serial: <filter> UEFI: Dell v: 1.7.0
date: 05/11/2020
ID-1: BAT0 charge: 84.5 Wh condition: 84.5/97.0 Wh (87%) volts: 12.7/11.4
model: SMP DELL GPM0365 type: Li-ion serial: <filter> status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10) microcode: DE
L2 cache: 12.0 MiB
bogomips: 62431
Speed: 4289 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 4289 2: 4059
3: 1679 4: 2838 5: 3858 6: 3070 7: 3394 8: 1955 9: 2854 10: 3883 11: 3318
12: 1819
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 450.80.02
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1f91
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-12:5 chip ID: 0c45:6723
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11
driver: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.9x11.2")
s-diag: 581mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
Monitor-2: DP-1 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.2.3
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348
Sound Server: ALSA v: k5.9.11-3-MANJARO
Device-1: Intel Wi-Fi 6 AX200 vendor: Bigfoot Networks driver: iwlwifi
v: kernel port: 3000 bus ID: 3b:00.0 chip ID: 8086:2723
IF: wlp59s0 state: up mac: <filter>
Local Storage: total: 476.94 GiB used: 265.61 GiB (55.7%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: KXG60ZNV512G NVMe 512GB
size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 10604106 scheme: GPT
ID-1: / raw size: 459.85 GiB size: 451.64 GiB (98.21%)
used: 265.60 GiB (58.8%) fs: ext4 dev: /dev/nvme0n1p2
ID-1: swap-1 type: partition size: 16.79 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3
System Temperatures: cpu: 46.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2381 fan-2: 2377
Processes: 283 Uptime: 55m Memory: 15.26 GiB used: 1.39 GiB (9.1%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1370 lib: 403
flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.08
