Unfortunately I only have arm devices with Linux ATM. Both running manjaro so none actually have controller fully working until now. When I performed the test, I disconnected the usb dongle for the controller and rebooted. I ran the lsmod command and then recorded the readings. After plugging the dongle in, I took the reading again. Controller now appears to be working great with the new modules added to the kernel. I had to adjust rainway settings and have hardware encoding set to CPU. It runs pretty smooth doing it that way. It did not freeze this time and controller worked ok.
I also modprobed xpad as requested. Here’s a PIC of the results. Again this was all done on the rpi4 with manjaro as I do not have another working desktop that has controller working on Linux.
