Gambas3 linked to webkit-qt4
#1
gambas doesn’t start:
[gigi@manjaro ~]$ gambas3
gb.gui.qt.webkit: unable to load ‘gb.qt4.webkit’ component
ERROR: #2: Cannot load class ‘HelpView’: Cannot load parent class: Cannot load class ‘WebView’: Unable to load class file
#2
Which gambas package are you referring to exactly?
gambas3-runtime requires gambas3-gb-qt5-wekbit
#3
It works well over here. I find this project very interesting. Have it installed for quite awhile, but I never actually used it!
#4
Me too, you issue was solved?
#5
Is this answer for me? I never had an issue because I never actually got to use it. If you mean webkit-qt4 I don’t have it installed because I installed gambas3-gb-qt5-webkit
Actually I have gambas3-gb-qt4and gambas3-gb-qt4-ext but I don’t need it. I guess I need to do some cleanup.
#6
Actually my respon for @firillo :grinning:. I install all package gambas3 and I got that issue too, what should I do?
#7
Ahh I just uninstall package gambas3-gb-qt4 and gambas3-gb-qt4-ext, gambas can launch now. Thanks for the clue :rofl:
#8
yessss!
thanks!
